Question about Dishwashers
The normal light on my Whirlpool DU1101XTPQ7 is blinking. Service company installed a new circuit board but this did not solve the problem. Now they are saying it's the control panel (after the third visit to my home to fix this).
  • 145 Answers
A blinking indicator light means the thouch key that geos with that light is stuck. So yes you need a control panel since the touch pad assembly is installed on it at the factory. I would have them put your old control board in with the new touch pad. It should work but sometimes they both go out.
Posted on Apr 23, 2008
Whirlpool dishwasher model# gu2200xtss3 normal light flasing all the time turning power off does not help in a few minutes back on flashing
The light blinking is an error code--usually it will blink a certain number of times, pause, then blink another sequence(ex. 4 times, then 3 times)in a binary error code. There is a chart in the service manual to decipher the code(s) and locate the issue. It could be anything from a heater circuit failure to the drain pump being jammed. Try to see how many times the light blinks, and which ones blink--there could be, on the first part of the sequence, normal light, then, 2 or 3 lights blink-- I need to know which ones are lit. Thanks! You can try to look up the light combinations on the net with a search for your model number and error codes.
Oct 12, 2015 | Whirlpool Dishwashers
Whirlpool adp 6515ix dishwasher start button is flashing in 4 time cycles-what does this tell me please. None of the manuals indicate what the flashing could be signalling.
Error CodeConditionCheck/RepairShop PartsClean light blinks 7 timesHeater circuit failure. Control didn't detect the expected rise in water temperature.Check the heating element and related components (wiring and control board) in that circuit.
Heating element, Electronic control board, Thermistor, Circuit wiring
Console light blinks rapidlyThe control detects a stuck button on the control panel.A failed control panel or a malfunctioning electronic control board can cause this code. Check the buttons on the control panel using a volt/ohm meter. In most cases, the control panel must be replaced. If that doesn't solve the problem, the electronic control board might be at fault.
Control panel, Electronic control board
Start/Resume light blinks slowlyIf the dishwasher door is opened or power is interrupted during the cycle, the dishwasher won't start again until the door is detected as closed and the Start/Resume button is pressed.Check the door latch and switch assembly. A failure in the Start/Resume button also can cause this problem.
Door switch assembly, Control panel, Electronic control board
Clean light stays onThe dishwasher won't start a new cycle unless it detects that the door opened after the previous cycle.Turn off power to the dishwasher by shutting off the breaker and restarting. If that does not work, the door switch assembly is stuck and must be replaced.
Control lock LED is on but not accepting key pressesAccidentally turned on or control detected keypad problem.Press the Heated Dry key for 5 seconds to turn off control lock feature. If that doesn't work, replace keypad.
Keypad
Sanitized LED blinks at end of cycleControl couldn't confirm that the dishes were sanitized.Check voltage to the dishwasher and the temperature of incoming water. Check the diverter motor, the heater and the OWI/thermistor.
Diverter motor, Heater, Thermistor
May 23, 2015 | Whirlpool Dishwashers
Dropped my 8900 blackberry curve in water. i let it dry and reinstalled the battery. Now all i get is a flashing red light.
Hello Friend, Red light is the sign of danger as all we know in case of your phone there is a short circuit into the mobile circuit board so this red light is blinking you have to go to the any expert mobile repairer or company service center for further query and dont install your battery as because of its more damage to IC of phone may occur n there may be the permanent die of your mobile.
Hope this will solve your problem...
Jun 23, 2010 | Cell Phones
My sony ke-mx42a1 shuts down and the stanby
Normally, this happens when the TV detects a bad circuit board and goes into " Protection Mode ". The blinking red light should be a error trouble code. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Jul 14, 2009 | Sony KE-MX42A1 Television
F1 appears after I start my load. Sometime not right away
You need a new control board, contact your local maytag or whirlpool authorized service company and see if its under mfg warranty, a new board WILL solve the problem
Jul 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
TV clicked and went blank...no picture, no sound. Power light blinks ten times in one second intervals and then pauses for about five seconds.
Most problems with TV not turning ON is a power supply related problem. The relay click are a normal process that powers up the circuit boards. Right now the TV is most likely in " Protection Mode ". The TV detected a bad circuit board and it will prevent the TV from fully turning ON. This keeps the other circuit board from being damaged. The power light blinking is a code.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet. This will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, blinking light codes, test points, and part# lists. Usually, cost under $20.
Jul 05, 2009 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Washer won't start.
I solved this by buying a new washer. In talking to customer service, they believed over the phone that the control board had gone out.
Jun 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Code F50 and absolutely no spin cycles at all. Anyone have a solution?. Don't call the service centers, there's no help there. Is it cheap circuit boards?
I didn't solve the problem, so I have to wait for the circuit board to come in and the tech to install it. Really hope this solves the issue.
Mar 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool GU2400XTPT6
Check the Tech Sheet you will find it behind the kickplates On many models, this sequence will work: Heated Dry, Normal, Heated Dry, Normal. Press this key sequence within six seconds to activate service mode.let me know if it helps
May 06, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
118 people viewed this question
Top Dishwashers Experts
