My hotpoint aquaruis wf321 will not go on to the last spin, the on/off, mini load and reduced creases lights are flashing. also some water is left in the drum.
  • Anonymous Jun 02, 2008
    my machine goes through the wash cycle begins to spin then stops and all lights flash (crease guard, min load etc) on/off light also flashes but nothing happens. any answers
  • Anonymous Jun 28, 2008
    exactly the same problem. Machine in only 16 months old but has just had the bearings wear out ad replacd, just outside the 12 month warantee. I don't think we'llbe buying Hoptpoint again
    Meic
  • 101 Answers
The timer is bad, replace the timer.
Posted on Apr 23, 2008
My hotpoint washing machine WF560 mini load and reduced creases lights are flashing and also the on/off light is also flashing, please help. Thanks
Heating eliment or PCB, is this when doing a prewash? or a normal wash excluding pre wash?
if you can manualy pump out and manualy rinse and spin, my guess is heating eliment is broke £20-£30
Jan 27, 2011 | Washing Machines
Hotpoint WF541 problem
Technical Fault is Pressure switch jammed on empty: check switch & module... in laymans terms its either a blocked sump hose or faulty pressure switch/module
Mar 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Oct 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
I have a hotpoint aquarius WF250 1500 spin. The
I've just had this exact same problem. Can you tell me if you have had any success with fixing it please?
Thanks!
Dan
Sep 17, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Lights flashing on WF320P
i'm having same problem people have said empty filtter but i have done that and the water is running out but still flashing
so sorry wish i could help.
Sep 05, 2009 | Hotpoint Aquarius WF000 Front Load Washer
I've got a hotpoint wf220 wshing machine which is not spinning the pump is working and the on/off lights and mini load lights are flashing
i have a hotpoint wf321 water comes in and pumps out have flashing mini load light on and start light, but drum does not go round,
Jun 06, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Reduce crease and mini load lights flashing on hotpoint wf541g. had pump failier and have replace with new on but still not pumping water out.
I have encountered a similar problem. The following lights were flashing on and off:
  • On/Off.
  • Reduced creases.
  • Mini Load.
I also found that previously one of the 'lifters' inside the drum had broken off and someone had tried to put it back in place and continued to use the washing machine. After a short period of time the above mentioned flashing lights began.
I first suspected the pump, but this was fine. I then disconnected the hose which connects the hole from the drum to the pump and I found a child's sock blocking the hose. I removed the obstruction, put it back together and the machine worked perfectly. I also replaced the lifter (apparently these break quite often) and the machine has been working perfectly ever since that day.
I hope this helps. Good luck.
Mar 10, 2009 | Hotpoint Aquarius WF000 Front Load Washer
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
548 people viewed this question
Top Washing Machines Experts
