I HAVE A HISENSE HSLC8133A TV WHICH HAS A COMPONENT INPUT BUTTON AND HDMI BUTTON BUT THE REST OF THE INPUTS ARE CONTROLLED BY MAIN CH. BUTTON (INCLUDING THE ABOVE). I AM TRYING TO SET THE TV TO VGA INPUT VIA THE HARMONY REMOTE BUT IT WILL NOT GOT TO THE CORRECT INPUT BECAUSE THERE IS NO DIRECT BUTTON TO BRING UP THE VGA INPUT. WHEN YOU SET IT UP USING THE PROPER METHOD IN THE HARMONY REMOTE IT STILL WONT GO TO VGA.
5 Suggested Answers
  • 192 Answers
SOURCE: Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Posted on Jun 24, 2007
SOURCE: PC videocard-HDMI input not working any more.
There is acompany that makes such a converter BUT it is getting hard to get because HDCP (hd copy protection) can be bypassed with it. I will get the company name for you but search ebay for a hdmi to component converter. It works pretty well. You may need to get the HDMI to DVI converter cable for $8 as well.
Posted on Feb 10, 2008
MrBob84
  • 90 Answers
SOURCE: No Picture from Component Input #1 or #2 but do have audio via Surrond Sound
Simplest thing would be that your component cables are not HU'd correctly. Having them reversed would do this.
Mr Bob
Posted on Feb 13, 2008
SOURCE: Mitsubishi HDMI connection trouble
I have the same issue with my 73". Rather then going over all of my connections and equipment I'll just say htat I feel your frustration. I have been on the phone with Mitsubishi directly and it appears as though they have a free software upgrade that should address this problem. If you call 1-800-332-2119 and press 4 in the menu you will get someone to help you. Be patient. They will make you go through all of the fixes that you have already tried. They will mail you a flash drive that goes right into the front USB port of your TV. I hope this is of help. Good luck.
ret4good
Posted on Jan 05, 2009
doin12volt
  • 233 Answers
SOURCE: connect Macbook Pro to Component input
you should be able to use an SVGA to component rca connector on any component input - i have a wd-65513, and thats how I have my pc hooked up to it. I could also never get a clear picture using the SVGA plug on the back of the set.
Posted on Jan 12, 2009
No video or audio from HDMI inputs, (DirecTV and Xbox), rca aux input or Component input. Over-the-air HDTV from the Antenna is perfect audio & video
HDMI Input Problems - TV Not Showing Image - TV Repair ...
? 2:34
https://www.youtube.com/watch?v=ZtaUPX1tHP0
May 26, 2015 - Uploaded by ShopJimmy.com
Basic troubleshooting and replacement tips for HDMI inputs that are not ... video or audio from your HDMI port, you can take the source video ...
no signal? -hdmi - LG 55LE5400 tv - Forums - CNET
www.cnet.com > Forums > LG
CNETJun 14, 2014 - Sunday my husband hooked up an RCA ANT571 antenna with great results. ... The Roku first showed no signal on the TV. I tried hooking the Roku up to other HDMI ports, i changed the hdmi cables, .... Sound comes through, but not picture. ..... Video; All Video · Apple Byte · Carfection · CNET Top 5 · CNET ...
No sound on LCD TV - Desktop HDMI connection [Solved] - CCM
ccm.net > Forum > Hardware
Oct 11, 2012 - The video is excellent, but there is no sound coming out of my TVspeakers. ..... I also tried inputs besides the "HDMI 1" input and the other RCA ...
HDMI vs Component ' TVBlanket
Feb 03, 2016 | RCA Televison & Video
Dear Sir/Madam : Re: ONKYO HT-SR800 7.1 ch HOME THEATER SYSTEM The system will not deliver video output in television mode . Audio is fine . Initially , I press the...
Check the input selector on the TV, if you have audio only then it is a cable problem,
that means that cables are not connected in the right way.
Oct 10, 2008 | Onkyo Televison & Video
Hisense tv says no sign with blue screen
this simply means that the input you have selected is not being provided a picture signal , some common types of inputs would be labeled :
tv
cable
hdmi 1
hdmi 2
dvd
and so on
Jan 21, 2016 | Hisense Televison & Video
I have a TV, when switching to the component cable input it only displays a fully green screen. HDMI does not work at all. Would that be a sign of a failed T-Con board? TV is a Sony Bravia KDL-46WL135
Hello. Judging by your question, the on-screen graphics are working, since you are able to see what input you're on. If that is the case, the T CON is okay and the Main board (the one with all the inputs) is defective. Also an indication is different displays for different inputs. If the T CON were bad, the picture would remain the same, since the T CON doesn't know or care what input is being used. Good luck.
Oct 26, 2015 | Sony Televison & Video
HDMI Inputs broke? Can't seem to get a signal
Cheap way to get around it is to get a converter that takes your HDMI signals and changes them to other format such as composite signals that may be accepted by your set. If your set has other types of video inputs you might want to check this out. Otherwise, a trip to repair shop is in order.
Jul 18, 2015 | Hisense Televison & Video
I can't get audio to work on my Samsung UN40HU6950F UHD TV HDMI 1 input using the Time Warner Cable Cisco 4742HDC cable box.
if all 4 inputs work with another input source(i.e. your Motorola box) it indicates the issue is with the TWC input source. Also check your HDMI cable to be sure it is in good condition & properly plugged in on both ends.
Jan 12, 2015 | Samsung UN40HU6950 40 Inch Ultra Smart
Hdmi input not working
Video is different from HDMI. From what I have seen you should have video inputs and component inputs. instead of trying these video inputs, look for tv/component button on your remote or tv settings.
Feb 01, 2014 | Toshiba Regza 52XV645U LCD TV
No plug ins work other than what is in jack 1 why?
Try using the "source" or "input" button on your tv or remote control. That will cycle through any ports that are being used (hdmi, component, rca, etc)
Hope this helps!
Mar 09, 2011 | Televison & Video
How do I change my remote for TV to Input Video 1?
There should be a button on your remote denoting "Input." If you connect the DVD player to the TV on "video input 1" then push the input button on the remote or TV itself until the DVD appears on your TV (which will be Video 1). Some TVs must have the component (in your case) the "DVD" player connected to the TV before the TV will recognize it. Make sure the DVD is powered up and then push the input button until the DVD player appears on the TV. Depending on your TV inputs, there may be multiple inputs like, Video, Component, DVI, or HDMI. The above are listed in the respective order of "quality." HDMI being the best. Whatever input you hook the DVD player up to on the TV will be the "input" you will look for when pressing the input button. Hope this helps.
Oct 26, 2009 | Mitsubishi WS-48515 48" Rear Projection...
I just got a Vizio 37" TV from Walmart.When I turn it on, I get a blue screen that says No Signal. Help.I have Dish Network. What am I doing wrong?
Check that the connection where the dish box is connected to the TV is the selected input on your TV.
You should have either a component connection (5 cables) or HDMI (1 cable) connecting the dish box to your TV. The VX37 has two component inputs and two HDMI inputs (if I remember correctly). Use the INPUT button on your remote to select the correct input.
Once you confirm this and still have problems, post a response and I will follow-up.
Dec 21, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
