Question about InFocus ScreenPlay 4805 Multimedia Projector
Fixing an Infocus X2 Light Tunnel Problem...
I get the "usual" dark band on the right side which seems to be the light tunnel not-so-infrequent problem...
Can I fix that myself by putting the tunnel back in place, or do I absolutely need a professional ?
Thank you !
  • Anonymous Apr 28, 2008
    i am using 4805 model screenplay Tunnel Problem...is show bothside dork shade in the pitcher problem,
  • menace2223 Jan 15, 2009
    i have the same problem. i have a dark band on the right of the picture and the projector is fairly new and the lamp seems to be ok
  • 3 Answers
I have managed to get hold of a few light tunnels for the optoma X1,X2,X3 projectors if you need to get a replacement drop me an email at Sales @ herefordict. co.uk, Ive had the same problem except the silver coating the tunnel flaked away.
Posted on Feb 07, 2010
  • 563 Answers
Hi JF1226
This quite a tricky job , but not impossible.
You will see once you've taken out the light tunnel ( also known as the packlight pipe module ) that there is one or two of the small mirrors that has come loose as a result of the lamp's heat.
Glue them back with Super Glue that dries very fast.
Do them one by one , always try to build them back in from edge to edge i.e. - If the top one and left side one is loose , do the side one first and then the top one - just makes it easier.
Remember you only have one shot at this , so do it carefully.
Good luck and thanks for using Fixya.
Posted on Apr 25, 2008
Dark haze left side of screen about 4 to 6 inches wide only in the wider screens not in the native
Its a Light Tunnel failure. Go to www.avsforums.com and search for 4805 Light Tunnel. There are instructions to open the PJ and repair the Tunnel. Also, I posted a DIY replacement option in lieu of fixing the very fragile tunnel.
http://www.avsforum.com/avs-vb/showthread.php?t=1304694
Jan 02, 2011 | InFocus ScreenPlay 4805 Multimedia...
Left hand side of image appears darker than rest of image as if a shadow is caused from somewhere. Unsure if this is a lamp problem or a camera problem
If it looks like a dark orange/brown band, its likely to be a Light Tunnel Failure. The Tunnel can be fixed thru the manufacturer, but it will cost plenty. You can also do it yourself.
For additional info, go to www.avsforum.com and search for "4805 Light Tunnel" and you will see threads about the problem...as well as DIY repairs.
I also posted a DIY replacement option since new Tunnels are virtually non-existent:
Dec 24, 2010 | InFocus ScreenPlay 4805 Multimedia...
Have Infocus X2 projector. When on a dark shadow line appears down the left side of screen. Could it be a bad lamp?
no it is not lamp problem. it must be light tunnel problem.
after lamp there is tunnel for light travel, made from 4 pieces of mirror.
this tunnel is glued. glue tend to break in time so the tunnel is no longer doing its purpose.
open this part of projector, there should be 2 little screws holding it. repair it by reposition mirrors and glue them from outside by little drop of temperature resistant and elastic glue. that's it !
Oct 03, 2010 | InFocus Projector Lamp for LP340, LP340B,...
X2 OHP mounted on ceiling fixture. Image is dark on right side
Yes it will have to come off the ceiling. It sounds like the light tunnel has collasped. This is located under the colorwheel. If you can get a new tunnel , be careful removing the colorwheel so no segments break off of it...make sure the new tunnel is pushed against the "lip" before screwing the tunnel clip back into place.
Aug 02, 2010 | InFocus X2 Projector
Need help looking for the part.
Hi:
Seems you broke the part called the color wheel assembly. Usually the color wheel can be replaced by you or a qualified TV servicer.
Mar 03, 2010 | InFocus ScreenPlay 4805 Multimedia...
I have an infocus X2 projector that has a shadow on one side of the image. After reading other posts, this appears to be indicative of a light tunnel collapse. Is this problem repairable in an X2 and if so...
the light tunnel has collapsed and needs to be replaced. it's pretty simple to repair. there are directions on the "tips" part of my profile. so, you can get the part from an infocus service center and do it yourself or send it in to them for repair. either way, try www.avsolutionsny.com. they're really good.
Jan 29, 2010 | InFocus Office Equipment & Supplies
Infocus X2 shadow on right side
You are describing a light tunnel failure. Unfortunately, Infocus has decided to discontinue any parts for the X series. Your only recourse is to repair the tunnel with superglue. Or buy a new projector. If you do attempt repair, note that the corners do not line up, rather the sides are offset slightly.
Apr 15, 2008 | InFocus ScreenPlay 4805 Multimedia...
How much does a light tunnel repair cost?
Hi there
The light tunnel is not a expensive part to have replaced and it is better to do it than to keep on buying new lamps.
You can easily find your nearest Authorised Service Dept online.
Tip : Don't let just any monkey do this type of work on your unit , rather pay a bit more with the authorised agents.
Mar 25, 2008 | InFocus ScreenPlay 4805 Multimedia...
InFocus ScreenPlay 4805 Multimedia Projector Logo
1,622 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
