Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Sears Craftsman Lawnmower 917.378072 I can only fill the gas tank half full of gas and than it leaks. How can I fix this?
  • mawitcher May 02, 2009
    6.25 craftsman; model 917.388340 (number won't bring up anything in Sears' site); won't keep running after warmed up; first try since winter; new gas; new air filter; plug cleaned; magneto assembly rusted, cleaned off; now won't start.
    Q: what are the gaps for the plug and magneto?
The carburetor on these mowers is artfully simple. There are usually two problems to examine for first: A stuck (or leaking, which could cause flooding) float. And secondly, there is a hair-fine pressure-relief hole in the bowl, so small that if it gets varnished from old gas -- or plugged for other reasons, it is nearly invisible. Make sure it's open. If it's not, the mower can start -- run a few seconds and stop because it has created a vacuum that won't allow gas to flow to the engine. Use a fine sewing needle, carefully to pick out the obstruction until you see through it. Never drill this hole, as any enlargement may send you back for a new carburetor.
Posted on Aug 14, 2009
I had the same problem and I had to replace the tank. Simple job, Sears sent me the replacement tank.
Posted on Aug 16, 2008
    Champion:
  • 313 Answers
Possible tank joint or cracked
Posted on May 31, 2008
Why does my 04 caravan drink a lot of gas?
Your fuel sending unit in tank is bad,may be incorparated with fuel pump or by itself.Car isn't going to drink gas that fast unless leaking.If tank reads a half,fill up to see if it's really half empty,and if it is half full,then your driving a gas hog.
Mar 10, 2013 | Cars & Trucks
My gas tank leaks and i need to take the tank out to find it
Leaks when it's half full - could be a seam leak.
Oct 02, 2012 | 1989 Chevrolet C1500
I have a new 650 sears craftsman self propelled 22" lawnmower that will not start. I have gone through the prime bulb instructions, still no luck.\r\nAny ideas? Walter in Alberta Canada.
could be the priming bulb gasket between the air-filter assy. and the carb.
I have the same lawnmower and if I prime with gas from a can it will start but stop after a few seconds. When I push the bulb I can hear air leaking in this area. You can replace the gasket by removing the back half of the air-filter assembly. I am looking to buy a gasket today I let you know how it works out! Thanks Ron
Oct 24, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
Leaky gas tank
There is not much that will stick to a plastic tank. you could get a plastic tank from a bone yard, and be in the same shape you are now, or a boat place where they have all sizes tanks, or sears. Taking it out is fairly easy, Of course you have to take the entire thing apart to get to it. You might be able to sneak it out through the back with just a panel or 2 out of the way. I have tried just about every adhesive made on gas leaks, aside from silly putty and POR, on metal only, there isn't one. A bar of soap will stop it but only temp. Hope this helps.
May 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
After about 15 minutes of operation my mower just cuts off as though it ran our of gas but has not. I have replaced the ignition coil, spark plug, air filter, fuel filter. I have a 17.5 hp Craftsman riding...
I have same problem only thing ive found is gas tank may not be venting properly. Fill tank about half full and leave cap off, if still stalls then probably engine problem
My tractor stalls like it is starved for gas although the gas tank is full. I,ve changed the fuel filter and the gas cap. I've cleaned out the gas tank, gas lines, and the carburetor bowl. The problem...
I had a similar problem with a sears tractor. close to the carbarator is a rectangle box with a rubber hose going to the engine block - remove the hose and spray carb cleaner in the hose wait a few mins and try again - its a vacuum for the carb
Jun 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
730 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
