For that you need to know your server ip. Go to your server then press windows key + R so you can see run then type in run "ncpa.cpl" without "" then press enter then you can see your lan connected icon right click on it then click on status then click on status then note ip address. Then you can access it with that ip. Click here Above link give you more info hoe to configure it. Let me know if you need further assistance. Thanks for using FixYa.
It is asking login and password. I entered the original login name and password but it doesn't accept it.
Try below default user and pass.
username: admin
password: password.99
It doesn't work. I typed admin to login, when I type the password cursor doesn't move. I type the complete password but like I said the cursor doesn't move.
Do you have any other solutions.
Any other solution?
Try with 1.2 or 1.4 or 1.5. This happens sometimes ...
I tried 1.1 to 1.9 but doesn't work
Do you have other solution
Is it a machine that you can physically access?
I tried to access directly but I can't Accessed.
No, I mean, can you go to the server to check its IP address? Or is it in a rack?
No, I can't check the IP address, I'm not able to comunicate with the server.
Have you tried rebooting it? (Physical reboot)
(How to get there? Open settings - Network - APN/Access point - New apn).
On internet settings try this first: Usually works but not always. Under are SMARTs own settings.
Connection name: Internet
Acces point name: Internet
NOTHING ELSE
Hope it helps.
I. GPRS/WAP Internet Settings
Connection name: SMARTGPRS
Data bearer: Packet data
Access point name: smart1
User name: leave this blank
Prompt password: No
Password: leave this blank
Authentication: Normal
Homepage: http://wap.smart.com.ph
Network type IPv4
Phone IP address: 10.102.61.46
Name servers: Automatic
Proxy server address: 10.102.61.46
Proxy port number: 8080 or 9201
(differs from one handset model to another)
Default access point: SMARTGPRS
Data bearer: Choose GPRS
Access point: internet
User name: (leave it blank)
Prompt p'word: No
Password: (leave it blank)
II. MMS Settings
Connection name : SMARTMMS
Data bearer:Packet data
Access point: mms
User name: leave it blank
Prompt password: No
Password: leave it blank
Homepage : http://10.102.61.238:8002
Network type IPv4
Access point: mms
Prompt p'word: No
Homepage: http://10.102.61.238:8002
I have chili box server, unfortunately since last week I'm not able to access it. IP address was 192.168.1.3 I tried the cobination of 1.1 to 1.9 but it doesn't work. I tried to connect to server using my other computer connecting directly via cable but I can't accessed.
