Question about Intel D845GRG Motherboard
Network card hi there, i formatted my computer and i lost the internet connection because the ethernet cable is not installed the motherboard is ethernet card d845grg can u help please
  • 655 Answers
Jo,
  • Click Here
  • Select your OS
  • And then you can download all the drivers including LAN
Thanks
Iqbal
Posted on Apr 23, 2008
  • 85 Answers
Hi jo
after the formatting process i guess you reinstall the operating system.
1. if your ethernet card is located directly on the motherboard,all you need to do is to run the motherboard driver on your system.it will install/activate all available resources on the motherboard and that includes the ethernet adapter.
2.if your card is not mounted direcly to the motherboard,connect your ethernet card on the pci slot of your motherboard and make sure the system detect it and then install any driver that come with it.
How Do I connect to internet with my desktop without Ethernet cable
To connect wireless to a network ..you need a wireless router or access to a near by one ..and you need to install a wireless card on computer if it has non ..This can be a pci card and you will install it on a pci slot inside and install its driver and after that connect to the network available ..or use a wireless card on usb ..
If you do not have a network free near by ..you can connect using the wireless card to another computer connected to the internet ..or install a wireless router on your Ethernet cable ..and a card in computer or a usb one ..
In my opinion the wireless card and router is the best way cause connecting trough another computer can be tricky and slow..
another way ..if you do not have any other means is to use a wireless modem on usb from a mobile network ISP (internet service provider )
This can be the same provider as your mobile phone one ..
Dec 18, 2011 | Dell Dimension 4500 PC Desktop
KV8-X motherboard. I have a network card installed, but I keep getting new hardware found for ethernet. I try to disable the ethernet card via system. I can't connect to internet.
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
hope this helps or you could download
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access Controller (MAC) with a triple-speed Ethernet transceiver, PCI Express bus controller, and embedded memory. With state-of-the-art DSP technology and mixed-mode signal technology, it offers high-speed transmission over CAT 5 UTP cable or CAT 3 UTP (10Mbps only) cable. Functions such as Crossover Detection & Auto-Correction, polarity correction, adaptive equalization, cross-talk cancellation, echo cancellation, timing recovery, and error correction are implemented to provide robust transmission and reception capability at high speeds.
hope this helps
Apr 26, 2011 | AMD ASUS K8V-X (MBASUSK8VX) Motherboard
I am trying to get an ethernet connection to my isp provider(Sprint) on my home computer. However, they said that I need to install a network card in order to get connection. How do i install this? Or is...
Hi hdixon530,
Your motherboard should have an ethernet port ready to go so you shouldn't need a network card (see atached picture)
The only thing you need to get internet acess is for them to come to your house, install the router and the internet line and then configure your pc for it's use.
Mar 10, 2011 | Dell OptiPlex GX270 PC Desktop
The ethernet light on my modem turned off despite the fact that it is connected by wire (tried numerous cables as well) and that the internet service is working. The internet will not connect, and the...
Seems like your computer ethernet adapter (network card) is not working correctly/not installed or mis-configured. Open Network Connection and look for Local Area Connection:
* Does it state Disable underneath it? -> Right-click on it and choose Enable.
* Doesn't exist -> Open Device Manager and look for Network Adapters. Is it there? Do you see any yellow question mark or exclamation mark? If so, reinstall the network card driver! If you don't see any of this then the network card is either not connected firmly to the motherboard or it's defective. Connect it firmly (after shutting off the computer and disconnecting the power cord!) or replace it with another network card!
* Exists and enabled -> Right-click on it and choose Properties. Click Configure, go to Advanced. On Media Type, make sure it's set to Hardware Default or AutoSelect.
Cheers,
Pelu.
Mar 13, 2010 | Linksys EtherFast Cable Modem with USB and...
Ethernet controller and USB are missing on XP
Yes, the device-drivers can be downloaded from the Internet, to one computer, and then burned onto a CD-writable, or written to a USB memory-stick, and then the files can be physically moved to the other computer.
But, "which" device-drivers is completely dependent on which computer that you have. Some motherboards have "integrated" network-adapters and "integrated" USB-ports.
Easiest solution is to take an add-in PCI network-adapter card, and install it, and connect the Ethernet cable to its socket.
Hopefully, Windows will recognize that card, and automatically load the correct device-drivers from the C: drive, i.e., without Internet access.
Or, if you buy an add-in card, it may come with a CD-ROM that contains the device-driver.
Once the device-drivers have been installed, you will have Internet connectivity. Access: http://WindowsUpdate.Microsoft.com
and click "Custom" scan, and then click "Optional Hardware".
Windows Update should find the device-drivers for your motherboard, and install them. Then, you can remove the add-in card, and connect the Ethernet cable to the "on-mother-board" network socket.
Dec 14, 2009 | Microsoft Windows XP Professional
How can i connect a toshiba runniung windows me. to the internet via ethernet cable? is it possible with just the cable and no card? is there a programe i can download to help my laptop? what can i do?
It should have a LAN (network card) built in to the laptop.
First of all make sure you have the LAN (network drivers) installed. You can do this by checking in device manager.
To open device manager click Start, point to Settings, and then click Control Panel.
Double-click the System icon. Click the Device Manager tab and look in the list for network adapters/controllers.
If the driver is installed you should be able to directly connect the ethernet cable to your laptop.
I'm not quite sure where the ethernet port is on that particular laptop but it will be on the back or sides of the unit and it will be the only port the ethernet cable fits into.
From there you should be good to go, if you can't get a connection reset the modem by removing power from it for 2 minutes, connect the power again, wait another 2 minutes for the device to settle and try the internet connection again.
Regards.
Oct 01, 2009 | Toshiba Satellite 1715XCDS...
The Intel core2 duo cpu E4600 is not detecting the speakers in my system . I have formatted my system - After that it is not detecting the exteranl speakers that I had connected. But the speaker was...
i would start with getting all the updates for the computer ... check your device driver to see any errors . or if you have the recovery discs you could pull the drivers from there . hope this helps ... if not let me know
Jul 31, 2009 | HP Pavilion a6460t Notebook
Install ethernet card optiplex gx260
That slot is actuall not accessable externaly. The open bay is for the AGP slot right next to it. Directly to the left of that slot you have a riser board the provides 2 additional horzontally mounted pci slots. You'll have to use one of these.
May 11, 2009 | Dell Ethernet Card Network Adapter
About ethernet
If you computer has already a ethernet card installed on it, just need to get a ethernet cable and connect it to your modem and the other to the computer and make sure the USB is disconnected already, then power off your modem and restart the computer then power the modem back on and check if internet is already working, if its not working you may need to contact your ISP and tell them to enable the ethernet connection of your modem....
Sep 14, 2008 | SMC Abocom ExpressCard to Ethernet Network...
Intel D845GRG Motherboard Logo
156 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
