BRADY 300X PLUS THERMAL PRINTER DRIVERS
I am trying to print to my BRADY 300X PLUS THERMAL PRINTER FROM Auto CAD. Some drivers dont work at all and the one that I do get to work prints with poor resolution. This was working properly up untill about 3 weeks ago when a windows update came in and both of my Brady printers stoped working. any ideas?
5 Suggested Answers
shortyz1123
  • 9 Answers
SOURCE: Smudges on Brady labels
i say about 60
Posted on Jan 07, 2008
  • 97 Answers
SOURCE: Brady 600x Plus II Date Code Is Off
mmm...Maybe try updating the firmware. That printer is a Zebra Z96XiIII Plus printer. Zebra made a change in their code for the onboard clock in version 60.13.0.5 See if you have that version and if not, you can to to www.zebra.com and download firmware for the printer.
Hope that helps !
Posted on Apr 26, 2010
  • 14 Answers
SOURCE: Error message: codesum: C47B72 memory error
Your printer firmware got corrupted or if yu tried to upgrade, it did not complete successfully. Most probably you will have to do a firmware install
Posted on May 24, 2010
  • 8 Answers
SOURCE: Brady ID Pal. Display says:
Brady printers have a sensor that reads information from the cartridge. The printer will not work if a connection cannot be made to the cartridge.The most common cause of failure is in the cartridge and switching to a different cartridge usually fixes that problem. Having the same problem with two cartridges is starting to indicate there is a failure in the printer, although it is possible (but not likely) to have two cartridges in row fail. A good first step is to be sure the printer is clean. If that doesn't work you'll most likely need to send your printer in for repair. A good source of free tech. support for the Brady ID Pal is Graphic Products. They even help people who are not their customers, They also do Brady printer cleaning and some repairs. They have an online for for requesting tech. support located at: http://www.graphicproducts.com/request-support.php or you can call 1-888-326-9244.
Posted on May 25, 2010
Print preview looks fine but just get a blank label from label mark. prints ok when not done from pc
You likely need to use Brady's software to create the label on the PC, and your PC will need the correct printer drivers to communicate with the Brady. The software and drivers should be available from Brady.
Apr 02, 2015 | Brady TLS 2200 Label Printer
I looking Print head for Brady Model 1344 please find to me .
The Brady 1344 printer is really a Datamax E4304 printer with 300dpi print head. A google search will produce numerous companies selling this printhead
Hope this helps
May 15, 2011 | Brady 1344 Thermal Label Printer
I can't prin't from Auto CAd 2009 ( Windows 7) to HP Laser jet 11004. But I can print from another application only printing from Auto Cad is not working.
There are no software drivers available for the HP Deskjet 1280
Lucky for us because this printer is great.
You can use the HP Deskjet 1220C drivers for this printer.
Feb 14, 2011 | HP DeskJet 1280 InkJet Printer
Is there a way to test the thermal print head
In the manufacturer YES they can do it, for a freelance technician, the only way to test the themal print head is to remove and put it in the same unit with good condition.
Jan 05, 2011 | Brady LABELIZER PLUS INDUSTRL SYSTEM...
Dose not print
All you need to do is to remove the drivers of the printers and reboot the computer.
Re-install the drivers with the CD that came in with drivers and again give a reboot to the computer.
Thats All.
Thanks
Jimmy
May 29, 2010 | Brady 1344 Thermal Label Printer
Hope that helps !
Apr 26, 2010 | Brady BP-THT-600X+ Thermal Label Printer
The labeller spits out the label but nothing is printed on it. Everything is loaded properly.
It sounds like the thermal print head has failed. Support from a company that repairsLabelizer Plus printers is available free at: http://www.labelingproducts.com/request-support.php
Jan 07, 2010 | Brady LABELIZER PLUS INDUSTRL SYSTEM...
Re Printer error
You have to set this online connection type from the SETUP-ONLINE-ConnectionType and set this to SERIAL if you are using a serial cable. Hope you have selected the port to the correct serial port or you have run the Port detection utility with the printer connected and switched ON while setting up the driver.
Nov 05, 2008 | Brady GlobalMark MultiColor (76800) Label...
I can not print when I connect to my jetdirect print server.
Hi, sorry for late answer, I have been offline for a while.
Connect RJ45 to router and parallel to computer
You need to download Software here first selecting 300x and windows version.
Then you can use the HP JetDirect Wireless Setup Wizard
to setup your printer on network.
You may also be required to install printer drivers, to do this use printer CD or download them from the Internet.
Regards
May 01, 2008 | HP JetDirect Print Server
129 people viewed this question
jasbo
jasbo
