Question about Amana AFD2535FES Stainless Steel Bottom Freezer French Door Refrigerator
Stopped Working I left my door ajar last night and I woke up to find the refrigerator not working. The control panel does not work. Is there a reset button or something?
    Scholar:
  • 149 Answers
If theres a circuit board look for a fuse that probably blew out.
Posted on Apr 23, 2008
Samsung rb215abbp won't stop beeping. I recently switched the door from the right side to the left. Now my fridge says 66 degrees but is cold. Light is on only when I unplug and plug it back in.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Sep 30, 2016 | Samsung Refrigerators
The refrigerator makes 6 beeps after dispensing water. Everything seems to be working normally so I do not understand why it beeps after the paddle returns to its normal position.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Apr 05, 2015 | Refrigerators
Why does my Hotpoint ff187e frost free fridge freezer lights flash and the alarm sound even after reseting them as per manual. rest them ok for a while but then restart what's the problem?
Jul 27, 2014 | Hotpoint Refrigerators
Our bottom freezer, frenchdoor whirpoolgold 2008 refrigerator stopped cooling the refrigerator last night. The freezer works fine. What do I need to do. I emptied the refrigerator, vacumnned off the...
It has a motor mounted above the evaporator that pushes air up into the fresh food compartment. That fan motor might not be working. To get to it you need to remove the bottom door and get the food out. Remove the ice maker and shelves and then the rear access panel can be removed. Before going through all that though you can check the continuity of that fan at the control board located behind the ice box. I have a repair manual HERE
Jan 19, 2010 | Refrigerators
Water and Ice despensor stopped working last night.
You have a little control valve in the right lower back of your ref.It should be at the bottom.If it is bad you will not get water to your ice maker.If that is not it your ice maker is bad They are not that hard to replace.Cost for little control in back is about$30.Ice maker is about $90.
Aug 21, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
We left the frig door ajar for 6 hrs, now the frig isn't working but the freezer is... where is the reset button? Thanks!!
Hi, No reset button. Check and make sure the evaporator fan motor inside the freezer is running. While checking that, look and see if there is any frost build up on the rear panelin the freezer. Please let me know if any of these are the case so I can asist you further.
Thanks
Vic
May 23, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
Ice Maker stopped working
You need to defrost the freezer. By the door being ajar, there was excessive ice build up on the coil that was not removed during a system defrost resulting in a blocked coil. This caused the temperature to rise in the freezer above twelve degrees that is why the ice maker stopped.
May 19, 2009 | Sub-Zero 561 / F
JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Freezer left open and now won't work
Try to unplug the unit from the wall and let it sit for a few minutes then plug back in. May reset the door alarm lock out. Also, moisture in the air can be drawn in and freeze up the whole thing. That means turning it off with doors open for about 36 hours... Moisture is a killer in a freezer, freezes and blocks up every air circulation vent, etc.
Sep 16, 2006 | Samsung RS2534 Side by Side Refrigerator
Amana AFD2535FES Stainless Steel Bottom Freezer French Door Refrigerator Logo
278 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
