Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Password I have a WBR 1310 Dlink router. I want to setup a password. When I enter the pin number (I got from the web) it asks me a password and a username... I totally forgot about this... What can I do ?
I tried that, but will try again.
Posted on Aug 20, 2008
  • 1,342 Answers
The username is admin
There is no password
Posted on Apr 23, 2008
I have lost my disk and need to program a password, due to nieghbours using my wireless. How do I do this
Hi evan,
Basically you don't need a CD if you want to change the password or put a password on the network all you need to do is to access the Wireless Settings Page of the Router and put or change the Network Key. To access your router you need a working computer connected to the router then open a Browser then type the Username is admin and the password is blank. Go the the Wireless Settings Page and under Wireless Security Mode you can change the Security Mode to either WEP, WPA or WPA2 then input your desired password.
Rate me if this helps so i can help others.
Thanks for using Fixya.
Feb 04, 2011 | D-Link 802.11g Wireless Router WBR-1310...
I want to set a password for my dlink wbr-1310 router put i dont have the set up disk
Go to D-Link - TechSupport FAQ and get the driver.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Jan 21, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Need to enter code for roku
what's the exact model of the ROKU It will be asking for the wireless security pass code for your wireless router , I have a M1001 and you can set that up if known from the wireless configuration - after it asks for SSID - it then asks if security enabled say - yes and enter the code - IF you do know the code
Your Wireless signal may already be secured by the manufacturer and often the wireless code is printed on a label stuck to the router itself
IF not already set here is how you can see the wireless security code. Log into the setup of the router - to do that open a web browser, use Internet explorer (some routers setup pages do not work correctly with other browsers) In the browser address bar - type:
Different manufacturers use different default address to To access the Web-based Utility of the Router and log into the setup pages
DLink Type:
A setup login screen should now appear requesting a user name and the password - use admin for both username and password - default setting for the d-link Now you can goto the wireless section or secruity section and see the type of encyption to WEP, WPA, WPA-PSK and the code used
Apr 10, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Unsecured network
  • You need to log into the router setup screen - you do this by connecting a PC to the Router via a cable connection and then using Internet Explorer (IE) you log into the router.
Using the default settings
  • Open a web browser and enter and press Enter. When the login window appears, set the user name to admin and leave the password box empty. Click OK to continue.
  • Goto the Wireless security section to set the security type and the password
Section 4 of the manual - see below deals with setting the wireless security This is the support site for that router
Click on the Support Resources - that will take you to the manuals for different Version of that model - click on the model you have to get to the online manual
Apr 09, 2010 | D-Link 802.11g Wireless Router WBR-1310...
How can i place a password on my dlink wireless wbr-1310?
OK... type the following into the browser of choice...
On p.14 in the manual it tells you that the default user is Admin and password is blank
Jul 31, 2009 | Linksys Wireless-G WRT54G Router
Go the router setup page,, type admin as the user name and password as the password (default, if you have changed these use your login info).
Then on the wireless page change the SSID (router name).
You can also add a security key on this page.
more info from D-Link:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 12, 2009 | D-Link 802.11g Wireless Router WBR-1310...
How do i secire my dlink wbr 1310 router
print.gif Step 1 Open a web browser and type the IP address of the WBR series router into the address bar (default is
Step 2 The default username is admin (all lower case) and the default password is blank (nothing). Click on OK.
Step 3 Click on the Setup tab at the top and then click on Wireless Settings on the lefthand side.
Step 4 Select the type of WPA encryption you would like to use with your wireless adapters from the Security Mode dropdown menu. Note: Your wireless adapters must support the form of WPA encryption you select.
Step 5 In the WPA Personal section, configure the following:
Select the Cipher Type
Select the PSK or EAP
Enter your Passphrase
Re-Enter your Passphrase
Step 6 Click the Save Settings button to save your settings.
You should also reset the admin password when you are done to something besides the default.
Click here to see how:
Don't forget to rate this solution!
Feb 03, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I forgot the username of dlink wbr-1310 wireless router
As an initial info try to do a hard reset on the unit, this process will restore the system into a original settings. you can find the reset switch on either on the left of right sight of your router.
you may visit this SITE to recover again your current password without erasing or removing the current settings made.
Reset Password.
Hope this idea helps you.
Thank you for using fixya.
Nov 20, 2008 | D-Link 802.11g Wireless Router WBR-1310...
You are supposed to only type in "admin" for the password, the username isnt necessary. Try it.
Apr 25, 2008 | D-Link AirPlus DI-524 Wireless Router
How do I secure my dlink wireless connection?
Type (you can type the router address if you have changed) and enter on browser's addressbar. Router's interface will appear.
Click on SETUP and Click on the WIRELESS SETTINGS at left side. on the page you will see the option of WIRELESS SECURITY by drop down menu you can choose the Security mode that you wish. here is the link for the emulator
Please post your question if you need further assistance
Good Luck
Jan 19, 2008 | D-Link 802.11g Wireless Router WBR-1310...
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
596 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
