Performance meintanance is not located under my control panel. where can i find it? also, my mouse does not hold the selected cards when i am playing card game such as free cell or solitaire.
    Guru:
  • 1,342 Answers
1. Go to control panel and click on Tools at the top of the window, choose Folder Options, make sure "Use Windows Classic Folders" is NOT selected.
2. You have to hold down the left mouse button to drag the cards to where you want them.
Posted on Apr 23, 2008
How can I get my pointer to click on as it used to
Which operating system you could use the system restore but f its a hrdware fault the fault might return or not be fixed.
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
Click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
Click on >> control panel all control panel items mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp.
In windows 7 click start control panel hardware and sound mouse you will see the same tabs and options as with xp
Change Touchpad Settings
Nearly every modern laptop computer comes with a touchpad for on-screen interaction. Depending on your operating system and touchpad driver versions, you can update the speed, sensitivity, tap speed and clicking functions of your computer's touch pad.
Accessing these settings and updating them to meet your needs is a quick and easy process with both the Microsoft Windows and Apple OS X operating systems.
Open the Control Panel by clicking the Windows Start button and selecting "Control Panel." Depending on your Windows configuration, this option may be located within the Start Menu's "Settings" sub-folder.
Double-click the Control Panel's "Mouse" icon.
Click the Touchpad tab.
This tab can have one of several names, depending on your computer manufacturer, your operating system version and your device drivers.
However, the most common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see any option resembling these, you may not be able adjust your laptop's touchpad settings.
Refer to the "Warnings" section if this applies to your computer. Locate the "Scrolling Settings" area within the touchpad properties tab.
Adjust the settings to meet your needs and then click "OK" to close the dialog boxes and confirm your changes. Change touchpad settings in Mac OS X
Click the Apple menu and then select "Preferences."
Click the "Keyboard & Mouse" icon.
Select the "Trackpad" option from the top of the Keyboard & Mouse dialog box.
Adjust the trackpad settings to meet your needs, and then close the dialog box to confirm your changes.
Enable a Mouse for a Laptop
Without the ability to drag and drop and point and click, a laptop computer is merely a desk ornament.
Most laptops are manufactured with a built-in mouse in the form of a touchpad.
If the touchpad fails or if you just prefer working with a mouse, it is easy to enable a mouse for use with your laptop.
Purchase a mouse that is compatible with your laptop.
You can find compatibility information on the manufacturer's website.
If the mouse is wireless, make sure that the USB receiver is included, or purchase it separately. The mouse will not function without the receiver.
Insert the batteries in the mouse if you are installing a wireless mouse.
The battery compartment is generally located on the bottom of the mouse.
Connect the USB mouse to the USB port on the computer.
If you are using a wireless mouse, connect the USB wireless receiver to the USB port.
Turn the computer off and then on again if you are enabling a standard mouse with a wire.
This will instruct the computer to run the "new hardware" wizard, which will walk you through the installation of the mouse, and your mouse will be enabled.
Turn the wireless mouse over, and locate a small indentation with a button.
You may need to use the tip of a pencil or pen to depress this button.
Simultaneously press the button on the mouse and the small button on the USB receiver.
This will initiate communication between the mouse and the receiver.
Hold the buttons down for about 5 to 10 seconds until the light on the mouse comes on.
Test the connection by moving the mouse.
If the cursor moves, you have successfully enabled the mouse.
If not, check that you have the batteries installed.
Try pressing the buttons independently of one another.
Press the button on the receiver until the light blinks and release it.
Press the button on the bottom of the mouse until the light on the mouse is lit.
This should enable your wireless mouse.
sign up
http://ftp.pisd.edu/guide/wireless-keyboard/wireless-keyboard.pdf
Nov 19, 2013 | eMachines E Machines E525 Laptop Computers
Mouse not working model 26-141
Make sure the batteries are inserted correctly and have charge if applicable usually located on the underside of the mouse there might be small plastic sticker with a phillips head screw under it rub your fingernail over the top to see if it has a screw or make sure the usb device is properly inserted for wireless or ps2 is inserted correctly I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7 in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar Click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver Click on >> control panel all control panel items mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp. In windows 7 click start control panel hardware and sound mouse you will see the same tabs and options as with xp
Feb 09, 2013 | Computers & Internet
Doesn't work
Hope this helps.
Dec 01, 2012 | Computers & Internet
Troubleshoot iHome optical travel mouse
which operating system xp windows vista or 7 ?
make sure you have the right mouse select in control panel
make sure you have the right mouse selected click start control panel mouse hardware you will see which mouse is selected
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
click start control panel administrive tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark ! or question mark ? or a red x
right click you will need to update the driver
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall
make sure you have the right mouse selected click start control panel mouse hardware you will see which mouse is selected in xp
for the double click this will be in the folder options follow previous to get to control panel items
click start control panel navigate folder options tick in the double click to open circle
hope this helps
Sep 15, 2012 | iHome Optical Mini Travel Mouse W...
There is a problem to upload image in facebook
this might be a mouse problem
make sure the batteries are inserted correctly and have charge if applicable
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
click on >> control panel all control panel items mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
in windows 7 click start control panel hardware and sound mouse you will see the same tabs and options as with xp
hope this helps
Sep 14, 2012 | Fujitsu Computers & Internet
Swann mouse not working
hope this helps
Aug 02, 2012 | Swann Communications Opti-Glo Mouse
Stop mouse blinking when start open windows and over screen color resolution and size
make sure the mouse Ps 2 or the usb plug has a good seating if applicable or if its batteries that are good
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
You might need to upgrade your graphics card drivers
you might have to remove your graphics card to make sure the socket is clean
restart your computer the reinstall it this should activate found new hardware wizard
if your computer came with a mother board disk the drivers could be on it
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Jul 20, 2012 | Computers & Internet
Logitech M310 Mouse
hope this helps
Jul 13, 2012 | Logitech 910-002484 M310 Mouse
My laptop hp7 I have no control or my mouse it jumps all around and games are hard to play
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
((if applicable))
make sure the battery is good ((has full charge))also you might test the usb device for the mouse is inserted correctly into the usb port ((if applicable))
click start control panel administrive tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark ! or question mark ? or a red x right click you will have options to update driver software disable uninstall scan for hardware in xp changes and properties
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall also
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop then you will see the desktop in the bottom toolbar select the 2 arrows then all control panel items then select mouse this is in WINDOWS 7 in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
hope this helps
Apr 19, 2011 | Computers & Internet
Every time I click the mouse it " double clicks" . Can't play card games or move to previous page using back button
try and change the doubleclick speed in the mouse properties , in windows XP it is under Control Panel > Mouse > Buttons.
Sep 22, 2009 | Logitech Cordless Mouse
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
