Low paper indicator when sufficient paper - Office Equipment & Supplies
  • 2,072 Answers
What make and model of copier/printer is this?
They uses various ways of detecting paper.
It is important to know the make and model so I can properly offer assistance.
Thank You
Posted on Apr 23, 2008
Why does the oil indicator light not come on when the oil is low?
Oil pressure sending unit may be bad or the wiring could be corroded/damaged. The light bulb may be burnt out. What is the vehicle info ?
May 19, 2016 | Cars & Trucks
Locked engine
ck. the fuel, make sure it had mixed fuel by sticking a piece of paper in the fuel, then let it dry, there should be oily residue left on the paper indicating oil in the fuel. if very little residue it probably ran without sufficient oil and seized up the engine.
Jun 23, 2013 | Husqvarna Garden
My 95 camry won't cold start unless I use starter fluid a couple of times then low rpms til warm up then runs find. Checked spark,iac,throttleprosition,changed fuel pressure bypass
Maybe needs new fuel filter, possibly new fuel pump. Check fuel pressure, low fuel pressure would indicate a problem with fuel filter or fuel pump. If fuel pressure is sufficient, fuel injectors may be shot. Use a stethoscope, or screwdriver, to listen to each injector to check for a clicking sound, signaling that the injector is operating.
Apr 27, 2010 | 1995 Toyota Camry
Red paper and ink lights blinking
red paper light is blinked as it is indication that plz insert paper in your printer, and ink light blinks because your printer is low on ink, kindly get your printer cartage refilled.
Mar 19, 2010 | Epson Stylus 1400 InkJet Photo Printer
Heater dont work properly not much heat comes out
1st check the coolant level. If it's low, you won't get sufficient heat. 2nd, what does the engine temp gauge indicate? If it is only in the low side (cool, or cold), the thermostat is probably stuck open, and the car will not warm up properly, so not enough heat. Let me know if this helps or not, there are other causes of not enough heat, 1st check the above and post what you find.
Dec 08, 2009 | 1992 Dodge Caravan
Coolant temp not sufficient for Fuel System etc fault keeps coming back
What does your engine temperature gauge indicate? Is it on the low side even after the engine runs for a while? If the temp is always on the low side of the gauge, you probably have a thermostat that is stuck in the open position (or possibly someone removed it and did not replace it). If the above describes your engine temperature, and you change the thermostat, it should 'fix' the fault code and shut it off for good.
Nov 19, 2009 | 1998 Chevrolet Cavalier
Magicolor 2400w won't feed paper
CLICK HERE for the manual
See page 55 for cleaning the media roller.
Jan 26, 2009 | Minolta magicolor 2400W Laser Printer
Paper jam indicated but I opened the back and can't see any paper
Sometimes while clearing the jam (if there was one) you may leave a bit of paper left behind which obscures a sensor causing it to think there is paper still in the paper path, or sometimes even paper dust can do it. Try a bottle of compressed air and blow the path out very well. Get a bright light (good flashlight) and very throroughly eyeball the paper path for any "foreign" objects. Most of the sensors are either a microswitch, or more commonly a light sensor (LED and photocell) which can easily become obscured or dirty with even a tiny bit of crud! also reload the printer drivers as the printer is not beem able to read that new cartridge has been installed. and dont just directly install the cartridge .install it through a mentioned in the printer properties .---ink cartridge replacement option----- as canon printers do very much drama to detect some cartridges and sometime just works fine.
Nov 21, 2008 | Canon PIXMA MP780 All-In-One InkJet...
95 people viewed this question
