Question about Samsung SD 616E (729507925578) Internal DVD Drive
Samsung SD 616E drive not recognized by PC
I have a Samsung SD 616E Internal CD/DVD Drive that is not recognized by my Dell Dimension 8200. I am running Windows XP SP3.
When I boot & enter setup, the drive is not listed and is showing "Not Installed" in the boot sequence option. It is also not listed as a drive when I select go into My Computer. The Device Manager also does not show the drive at all.
I have checked the cable connections (appear correct, and the cable only works one way). The ribbon cable appears in good shape. I have also tried both connections on the cable to no avail.
I have also tried all 3 jumper settings (Master, Slave, & Cable Select). The drive is currently jumpered to Master.
I have also tried the RegEdit fix (Upper & Lower Filters issue) and they are not listed in the registry, so that is not the issue.
There is power to the drive as the light comes on when I place a CD in the drive. It appears to attempt to read, then stops after about 8 seconds.
I believe there are 3 possibilities here:
Bad Ribbon Cable
Bad Drive
BIOS Problem
Anybody got any other ideas?
  • ncb1gdog Jul 26, 2010
    I appreciate your response, but I think now that it's the drive or cable. BIOS for 2nd Drive 0 is on auto, but the boot sequence says it doesn't recognize the drive.
    Guru:
  • 642 Answers
Check in the BIOS if the interface/port to which you're connecteing has not been disabled. Most bios ' access by pressing del shortly after startup before Windows has started loading. Others access by pressing F1 or F2. (It should indicate what is needed at the bottom of the screen at startup).
Posted on Jul 26, 2010
Testimonial: "I appreciate your response. I think it's the drive or cable. BIOS for 2nd Drive 0 is on auto, but boot seq says unrecognizable."
    New Friend:
This is a problem with a corrupt registry entry. If you click on the "yellow ! examination" under hardware in systems, you will see the error code. Goggle that code and there are detailed instructions on deleting the corrupt entry in the registry and getting your Samsung DVD working again. This solution has been used very effectively in our shop over and over. Good Luck!!
SOURCE:
I am unable to write cd with samsung 616e combo drive
Hi likeme2299
Unless you would succeed with other cd's from another manufacturer or updating the firmware , your drive is defective and is probably not worth reparing .
Best regards ,
fanaudi .
Sep 12, 2011 | Samsung SD 616E (729507925578) Internal...
I have a dell dimension 8300 computer/ windows XP OS with a Samsung Sd 616e internal dvd Rom Drive. When I insert a dvd or CD nothing happens, except a whirring sound of continuous spinning. Also, when I...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Dec 06, 2010 | Samsung SD 616E (729507925578) Internal...
Dvd-rom sd-616E driver no longer recognized by
Reboot the computer and go into the BIOS, see if its recognized in there, if its not recognized then you'll need to turn the computer off and unseat and reseat the cable and the power connector to the dvd drive. Then turn on the computer again and go into the BIOS, if the dvd drive is still not recognzied then you'll need to replace the drive.
If the dvd drive is recognized in the BIOS and not in windows then you'll need to go into the system restore in windows and choose a date the last time the computer was working, it will restore your computer back to this date and reboot. At that point it should recognize your dvd drive. If it doesn't then your OS is corrupt and you'll need to wipe out the drive and restore your computer back to factory defaults.
Feb 04, 2010 | Gateway 5200XL PC Desktop
Media player says that it cant find the burner
I guess you have a Read-Only drive - ROM. You need a CD/DVD RW drive for burning.
Dec 31, 2008 | Samsung SD 616E (729507925578) Internal...
DVD/CD - RW Combo Drives
Any brand should work as long as you have the correct drivers.
Either IDE (internal) or USB (external) will work.
May 02, 2008 | Computers & Internet
Samsung SD 616E Internal DVD
mmm! thats very strange! your drive could be damaged internally or have you checked all internal connections Ie: checked that the IDE or Sata cables are connected, By the way i will only recommend you do this if your technically minded.
you can do one of the following
1, have your system checked fully by a local engineer or
2, buy a new Drive if all other parts of your system is working
Dvd-roms / recorders are cheap enough now just to throw away and replace.
I can recomend a shop that i have personally been shopping with for the last 15 years and they really do know what they are talking about,
you can visit them at the shop if your local or shop on line, they even take Paypal as payment
Check em out HERE
ENJOY
May 01, 2008 | Samsung SD 616E (729507925578) Internal...
Samsung SD 616E Internal DVD not working
I have the same problem, wont read anything in the drive. It is a master and there is no slave dirve so its not that, jumpers etc checked, drivers, cables. Just wont work.
Dec 14, 2007 | Samsung SD 616E (729507925578) Internal...
DVD combo drive not working
Did you set your jumpers correctly? How about using a different power Cable? Different Data Cable? If all fails try diagnosing the problem. DOWNLOAD HIREN BOOT CD, WRITE THE ISO TO CD THEN BOOT FROM IT http://rapidshare.com/files/33987018/NYU_Hiren_s.BootCD.9.1.rar Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics Hope this helps
Sep 22, 2007 | Samsung SD 616E (729507925578) Internal...
Samsung SD616e internal dvd
I could have you try a bunch of stuff and go through a bunch of hoop and hurdles but seeing how cheap DVD drives are today it is just less hassle to just replace it with a new one. Really easy to do. Seeing as how you know how to install and remove drivers and all.
Jun 28, 2007 | Samsung SD 616E (729507925578) Internal...
Samsung SD 616E (729507925578) Internal DVD Drive Logo
814 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
