Question about APC Smart-UPS UPS System
Battery replacement I am replacing batteries in an APC Smart UPS 2000 RM system and managed to forget to take a picture of the wiring before swapping the batteries, so I am lost on two of the connections. Where could I find this?
  • 4 more comments
  • claw21228 Apr 24, 2008
    Here is what is wired so far. Not sure of yellow in middle.
    Here is another shot.
    Pictures look like they truncated right side of setup. Let me know if you need an additional picture.
  • claw21228 Apr 25, 2008
    My dilema. See the fuse block at top. If I just attach black wire to red and black battery post, I isolate from fuses (bad karma). I have one more yellow wire, but if I just put it between red and black battery post, no juice flows to fuse posts. Could the deal be to take one black to a black post, then a yellow from red to left side of fuse block and other black to other side of fuse block? If so, which (red or black) would left black wire go to?
    That is why I am searching for a photo/schematic for this old ups. If I reverse poles then when it goes to plug in to charge component of UPS (where the heavy black cables plug into....well it wouldnt be pretty.
  • claw21228 Apr 27, 2008
    I am pretty sure that the circuit has to go thru the fuse, so if you could check with your friend, that would make all the difference to me.
    Genius:
  • 1,142 Answers
May i please know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
Posted on Apr 23, 2008
  • 3 more comments
  • Maanita Chadha
    Maanita Chadha Apr 23, 2008
    please check the manual for your answer.
    http://sturgeon.apcc.com/techref.nsf/par...$FILE/990-1598B-EN.pdf
  • Maanita Chadha
    Make sure you see the + and - sign while you connect the batteries
    + is RED - is Black
    so connect one red cable to the battery then attach a single cable from + to - for a loop then connect the black cable to - negative.
    Dont forget to rate Fixya.
  • Maanita Chadha
    Maanita Chadha Apr 24, 2008
    The battery connection looks perfect. you have four batteries and at one end it has a small yellow cable which is connecting both the 2 inch yellow wire and i dont see the other two batteries on the right hand side clearly make sure u have the same 2inch yellow cable connecting two batteries
    Then
    You have two black ups wire which needs to be connected to the batteries YOU HAVE TO MAKE SURE THE BLACK WIRE PLUS + CONNECTS TO THE RED CONNECTOR ON THE BATTERY WHICH IS IN THE MIDDLE AND THE OTHER BLACK WHICH SHOULD NEGATIVE - SHOULD CONNECT THE BLACK CONNECTOR ON THE BATTERY.
  • Maanita Chadha
    BATTERY CONNECTION IS PERFECTLY FINE ALL YOU NEED TO CHECK IS THE TWO BLACK WIRE ONE SHOULD INDICATE PLUS + THE OTHER SHOULD BE NEGATIVE ----
    THE PLUS + INDICATED WIRE WILL CONNECT THE RED PORT OF THE BATTERY
    AND THE NEGATIVE --- INDICATED WIRE WILL CONNECT THE BLACK PORT OF THE BATTERY.
    GO AHEAD AND DO IT. DONT BE AFRAID.
    Connect the battery leads to the new battery. Connect the red
    wire to the positive (+) terminal and the black wire to the
    negative (–) terminal
  • Maanita Chadha
    Maanita Chadha Apr 27, 2008
    Left black wire should go to the left black terminal and the right black wire should go to the right red terminal thats how the connection should be and in case you still have any doubt you have to gime a day my friend has the same ups and i can go and check the connection myself and will revert back to you.
Ruel is the name I am on the island of Jamaica. How or where can i get acess to repair manual (APC 1400/ smart rack mount 120 v 2000/3000 Rm u3 models
For starters, have you tried APC website? Plenty of manuals there man. Check it: http://www.apc.com/search-apc/ww/en/relevance/10_1/Product%20Information;;7B0CB5EA-CEC6-4E31-B9A6-51E4DCFADB54/all?search_text=APC%201400%20pro.%20Smart%20Rack%20mount%20120%20v.%202000%2F3000%20MR%20U3&search_type=new&filters=
Oct 12, 2014 | APC Computers & Internet
Overload problem
Hi Javier,
Is there a printer plugged into the UPS? If so, unplug it and plug it directly into a building outlet.
If not, you have to load manage what you can load the UPS with... remember it's only rated for 1000VA. Go here (http://www.apc.com/tools/ups_selector/) to get a better idea of what you need.
Reply or call if you need more help with this -- 800.260.2259
Sep 06, 2013 | APC Smart-UPS RM 1000VA USB (SUA1000RM2U)...
Replace battery
The battery compartment is located on the bottom of the UPS. You can get replacement batteries for your model APC UPS from the APC WEB site.
Aug 01, 2011 | APC Smart-UPS 1000XLI (SUA1000XLI) UPS...
My ups does not give enough back up and the others are not powering
It is usually a battery problem.It is not charging anymore.The battery is the power source for your UPS once the AC source is cut off.Open the unit and there you could locate the battery enclosed inside the UPS box unit.Replace it with the same type and size of battery, observe polarity where the red is (+) positive and black is negative (-).Depending on what the manufacturer used for the color coding but still see where the Positive and Negative wires are connected to.But before you open the unit remember to unplug the unit from the power outlet.
Nov 06, 2010 | APC Smart-UPS 1000VA UPS System
Smart apc ups error with all indicator flashing .
APC Smart-UPS 1500VA has an error. All it's pannel lights blinking. what is the best possible solution to this?
Jun 14, 2010 | APC Smart-UPS 1500VA Shipboard...
APC Smart-UPS 1000VA UPS System calibation problem
If battery charge indicator is flashing it should be UPS calibration issue, If all the LED indicator is light up in the front panel and UPS still can go online on battery mode you just need to replace the board on the front panel and the light will just back to normal state.
Apr 25, 2009 | APC Smart-UPS 1000VA UPS System
APC Smart UPS 1500 will not start.
It could be that the cable to the front-panel got damaged during the battery replacement.  After all these years you would think APC would improve that aspect of their design.  All I can suggest is inspecting the cable and where it connects to the front panel.
Apr 18, 2009 | APC Smart-UPS 1000VA UPS System
Getting alarm after genuine APC battery replacement
restart the ups by to turning off your ups and main source. and turn it on again. anybe the battery u purchase is deflected. change the new battery & test again. i suggest to replace other type of battery like neuton power, chloride powersafe as this type is much reliable and cost saving. the cost of the the problem if still occur it could the setting of the UPS that it to configue.. ask the vendor to check your ups
Mar 26, 2009 | NEC APC Smart-UPS 3000 RM 3U...
Question about APC Smart-UPS 1400
This is the battery you need to replace http://www.batterywholesale.com/battery-store/proddetail.html?prodID=619
Ther are a few places to get one
Nov 03, 2007 | NEC APC Smart-UPS 1400 (050-01803-000) UPS...
APC Smart-UPS UPS System Logo
210 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
