sounds like my friend is you have a dirty which means you will have to rebuild it or you have water in your gas tank dump gas by new gas dont use the same gas
No problem as to which port you plug in, but make sure the Com port/RS-232/USB Port is enabled to detect the hardware. The device won't detect the hardware if you haven't made the changes in BIOS or port enabled in device manager (system properties>hardware). Hope this solves the query.
Connect your Sansa MP3 player to more than one USB port on your computer. Ensure that your computer USB port is not corrupt or disabled by testing at least two available ports. This is especially useful when you possess no other USB-based equipment.
Inspect your USB ports' status to ensure they are enabled on your computer. Right-click "My Computer" and launch "Properties" to verify the availability of such connections. Select "Device Manager" from the Hardware tab and click the "Universal Serial Bus Controllers" from the list shown. If a red "X" is shown, the USB ports are disabled.
Ensure your computer is updated by clicking "Start" and launching "Windows Update" from the Programs menu. Alternatively, inspect your USB port connectivity through your motherboard BIOS settings. Note that BIOS access and settings varies by mother board manufacturer.
Scan your computer for new hardware changes. From the Device manager, click the "Action" menu and select "Scan for hardware changes" while your Sansa MP3 player is connected. Allow your computer to attempt to find any physical component recently added in the event it failed to previously detect it.
Connect your Sansa player to a different computer. Test the connection on a different system's USB port to verify that the Sansa device's own connection has not been damaged. Inspect the USB ports on the computer in question as well to eliminate the possibility of both systems having problematic USB ports.
Change your Sansa MP3 player's USB plug. Sometimes the head of the plug may lose contact with the appropriate circuits. Obtain a secondary USB port at your local retail store and test it on an updated computer system.
You need to download or install the drivers for the audio. Did the headset come with a CD? IF so install by using the CD. If not go to www.logitech.com and download the appropriate drivers for your headset. Can also go into system, hardware and install/search for driver. BTW do you get a message that new hardware has been installed when you plug in the USB plug to your USB port?
Inspect your USB ports' status to ensure they are enabled on your computer. Right-click "My Computer" and launch "Properties" to verify the availability of such connections. Select "Device Manager" from the Hardware tab and click the "Universal Serial Bus Controllers" from the list shown. If a red "X" is shown, the USB ports are disabled. Ensure your computer is updated by clicking "Start" and launching "Windows Update" from the Programs menu. Alternatively, inspect your USB port connectivity through your motherboard BIOS settings. Note that BIOS access and settings varies by mother board manufacturer.
Try reinstalling the usb drivers for your computer. You can also check to see if its a hardware issue by pluging a usb powered device like a cooling pad in the usb port. If it gets power, chances are its a software issue. If no, then its a hardware issue.
You can check from the Device Manager and see if you can enable it from there. Right click on your My Computer and choose Manage. On the left panel click on Device Manager. From your right, expand the Universal Serial Bus controllers. Right click on each on the list and choose Enable.
Also so you can go and check on your BIOS settings and see if the USB port is enabled.
Your problem was cut off but I'm assuming it's that you've lost your USB ports. If this is the case then either you have a virus interfering or a Windows file is corrupt. First run these AVGFREE, MALWARE BYTES and SUPERANTISPYWARE. Once you've insure the machine is clean then goto Start, Run and type SFC/scannow. This will put all the Windows files back where they belong. You will need your original Windows disk.
This can only mean on thing that the USB port on your computer is not properly working, what you can do here first is to run the setup CD for your motherboard so all the software including the driver for the USB port will be reinstall, if after that still not working the USB port of the computer is already bad...
It is more like an inside electronic problem like;loose connections/failure in circuit board, make sure your power supply/source is earthed or earth the pc independently.Earth the pc thru a copper wire to a grounded metal object thru the screws and bolts at the back of your casing.
