With a modem or any hardware pluged into the usb port works ok from 5 - 10 munuets, then cuts out?
    Guru:
  • 1,342 Answers
Try a different USB port. If it is the only one you have and it is going bad you may need to add a USB add on card in one of you empty pci slots, if you have one.
Posted on Apr 23, 2008
Sb5120
1.screw the cable line into the (F-connector)port in the back of the modem just like a tv does.2.then use the RJ-45 lan cable supplied with the modem,plug it into the RJ-45 port in the back of the modem.3.then plug the other end of the cable into the computers RJ-45 port.4.then power on the modem by pluging it in,and letting it boot and detect the internet signal and all lights are on and in working order.then start surfing.The only time you will need the install cd is if you need to use the usb hook up on the modem.
Jan 31, 2012 | Arris SURFboard SB5120 Modem
My usb modem [lemon 3g] does not get detected. when i plug the modem it does not show anything i.e usb icon detected hardware etc. when i clikc on cmy computer also it does not show any connection why is...
First, check for the power source, there should be a light indicator on the panel of the modem, else, power is a problem, check your adapter/power cable. Next, is use USB cable/USB port, try to use other USB cable/USB port. Another option is to check your Control Panel - Device Manager, see if there is a USB Modem currently installed. Remove/delete the device from your Device Manager. Going back to Control Panel, select Add Hardware. If still fails to detect, your Modem is dead.
Good luck.
TedMac
Sep 18, 2010 | Computers & Internet
The usb ports on my v2000 no longer work. When I plug in any usb device it is not recognized.
Try reinstalling the usb drivers for your computer. You can also check to see if its a hardware issue by pluging a usb powered device like a cooling pad in the usb port. If it gets power, chances are its a software issue. If no, then its a hardware issue.
May 21, 2010 | HP Compaq Presario V2000 Notebook
Slow dsl
The cable modem should be connected to the WAN port of the router. Then the computers should be connected to any ports from 1-4 at the back of the router.
Once they are connected properly. Reset the router. Just hold the reset button for 10 seconds. Then turn off the modem, router and all computers.
Then you need to turn on the modem first, wait for the lights to become solid green, then turn on the router. Once the WAN light on the router is on, turn on the computers and check if there is internet connection.
If still no internet connection, contact your ISP. They might need to clone the mac address of router to their end.
Hope this helps! Good luck!
Feb 08, 2010 | Linksys EtherFast Cable/DSL Router
Both printer and 9 pin serial ports not working
What has changed? One solution is to go into BIOS when you first turn on your PC hit <del> key. Make sure the ports are enabled. The second solution is to make sure you didn't add a device with serial ports or something which is sharing the same IRQs, which is 3 4 and 7 traditionally (for COM1/2 and parallel port).
If you tried all this and it doesnt work, then somehow the chip on the motherboard which handles these (the UART chip) has broke, you need to replace the motherboard or buy a card with serial and parallel ports on it (this should be quite cheap, ie 10-20 dollars).
Nov 07, 2009 | Intel Computers & Internet
Usb modems will not work see's modem but will not complete driver install. Even if you manually update. Tried 2 modem's
check to make sure that your USB ports are working properly. Best thing is to hook up a usb mouse or usb keyboard.
if it recognizes those and installs the drivers properly then you know your USB ports are fine, at this point you know that its got to be something with the modems, either they are not compatible or the modems are bad.
Try a brand new usb modem and make sure whatever type of usb port that the modem requires is the type of usb ports you havve on your server.
Aug 11, 2009 | Dell PERC6/E SAS Adapter for Dell...
Computer says my usb network adapter is not plugged in but it is ?
Try uninstalling the hardware and rebooting. Then move your adapter to another usb port. If it works you probably got a bad usb port. If it doesn't work you probably have a bad piece of hardware. Let me know
May 18, 2009 | Computers & Internet
Need help picking an external modem for an old Dell Insprion 2500
Any computer capable of running Windows ME is capable of supporting any external modem.
In the past, for "internal" modems, there were "hardware" modems and "soft" modems.
The "soft" modems had 50% of the hardware of the "hardware" modem,
and the rest of the "brains" of the modem were embedded
in a software device-driver that gets installed into Windows.
Fortunately, most external modems are *NOT* such "soft" modems.
There do exist external modems that connect to a USB port,
and external USB wireless-devices, if you want a higher-speed connection.
Apr 27, 2009 | Dell Inspiron 2500 Notebook
Motorola cell phone W230
I own MotoYuva W230 and am also struggling to do the same.
The W230 seems to have builtin modem.
First of all we need to install the drivers from www.motorola.com/support/w230 and download the file from link USB modem drivers. Install it and it will create a virtual COM port for the modem.
Open HyperTerminal and try to connect to the port it. You can check the actual port number from "device manager" on WinXP.
Once you connect it will say "AT command Interpreter ready"
Here you can give commands
at+cgatt
OK
at+cgact
OK
at+cgdata
OK
after last command if your GPRS is active, the icon on topline will change to connected.
This hints to presence of GPRS modem but I am still not able to connect using my phone.
Please update anyone can indicate way forward.
Taking From :
http://news.softpedia.com/news/Motorola-MotoYuva-W230-Entry-level-Music-Phone-78060.shtml
Mar 27, 2008 | Cell Phones
Open Questions:
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
