Question about Toshiba 43H70 43" Rear Projection Television
Picture is getting dimmer
I have had my 43H70 for about 8 years now and it seems that my picture is getting dimmer. I have increased the brightness level but no luck. Do the CRT's burn out?
After 8 years use, perhaps the lenses and mirror could do with a good clean.
Posted on Jun 18, 2008
    Genius:
  • Toshiba Master
  • 1,689 Answers
Yes! CRT's do go weak with age and use. It is very possible that the CRT's are the problem.
The service tech can take voltage readings of the power supply, and biases to the CRT's to know if they are actualy weak.
From your description, I would thing very strongly that the CRT's are the problem.
Jerry G.
Posted on Jun 13, 2008
What is it when the picture is too dark and won't adjust any lighter?
The brightness level after many years of use gets dimmer. TV's are much cheaper now. Just buy a new TV.
Oct 31, 2015 | Mitsubishi WD-65737 65"" rear projection...
Tip
Increase the life of CRT of a monitor/TV
To increase the life of a picture tube reduce the filament voltage slightly by connecting a 2 watt wire wound resistor in series with the filament supply. The value of the resistor should be chosen experimentally connecting 1 ohm to 4.7 ohms so as to get a fair bright picture. Though startup delay will be there,the color, contrast and clarity of the tube will last double than the normal. I am using a TV for more than 12 years and still the picture clarity is as comparable with a new TV.
on Jun 22, 2008 | Intel P4 System Configurator (P4SDRAM1) PC...
Best quality picture
This is likely a simple settings issue.
A lot of people don't realize that backlight settings can affect the picture.
Go to the menu (press menu on your remote)
The menu will show picture options. Just toy with different settings until you find what you want. It may be on a preset setting that doesn't work. If you are in a bright room, you will need to increase brightness and contrast and perhaps backlight.
Usually an unclear picture is due to the contrast, backlight, and brightness settings being too low. You can also increase sharpness.
I suggest a contrast setting of 70, a brightness setting of 60-80, and a backlight setting of above 80.
Good luck.,
Mar 08, 2014 | Hisense 50 Class LED HDTV - 1080p, 1920x...
Jvc 61g787aa picture too dark on night scenes
Did you try going into the menu and increasing the picture brightness?
Jan 30, 2014 | JVC Televison & Video
What is the correct picture setting for a vizio smart tv model E322AR?
Contrast = 60 to 80%.
Brightness = 40 to 55%
Color = according to personal viewing taste.
Sharpness = 15 to 20%
The best way to tune to a perfect picture is, set the color to Zero first. Without any colour, increase the contrast to at about 65%. Adjust the brightness to get a perfect picture in B/W. Then increase the color, according to your viewing taste. Compare the skin tone of a person. That's all.
Oct 07, 2013 | Vizio Televison & Video
My picture isn't as bright as it used to be. Is there somethning that can be cleaned or lamp changed?
Ur tv is a DLP projection tv?Yes,the tv projection lamp is dying,sould be replaced.If this is a LCD or Plasma tvs is notthing u can do,as the tv getting older the screen brightness will get dimmer and dimer as tv ages,only thing u can do is to go into the Menu goto PICTURE SETTING.Go go down to Brightness increase it and the Contrast increase it too.
Mar 16, 2011 | Televison & Video
I have installed dimmer switches in the living room. They started off reasonably bright, but after time the maximum brightness is considerably reduced. I have replaced one of the dimmer switches, which...
when you dim a light it increases the resistance,when you increase resistance it causes heat, the more watts you are trying to dim the more heat you create, heat will cause anything to break down, so add up all your light bulbs and make sure your dimmer can handle that many watts, use lower wattage bulbs and maybe a higher wattage dimmer
Dec 30, 2009 | Electrical Supplies
Picture getting dimmer (?)
Hi, yes it`s time to replace the lamp, and remember to turn maxxed out brightness to normal once you replace the lamp :) good luck, video-tek
Jun 29, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
46GW945 Dim picture
Check the lamp timer to see how many hours are on it.  If is is near the estimated end of life for your TV replace the lamp.  It will get dimmer as it approaches its end of life.  The lamp timer should be in your menu.
Jan 17, 2009 | GE 46GW945 46" Rear Projection Television
Picture is dark
Does not seem like a bad tube alone. Could also be that the Video output Transistors Supply Filter capacitor having dried out. It is a 100mfd 160V capacitor, which on replacement will improve the brightness of the immage. And yes, you could also try increasing the heater voltage (Filament Voltage)of the Pictuire tube, this will definitely increase brightness, but will reduce the life of the Picture tube. You gotta think - 10 year old TV, should I repair or exchange and get a new one???
Mar 03, 2007 | Zenith Z27X22D 27" TV
Toshiba 43H70 43" Rear Projection Television Logo
70 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
