Olivetti Lettera 32 Typewriter Carriage Stuck Jammed Locked Up rigidly all the way to left.
Please excuse my lack of proper typewriter terminology, I'm new to this,
but I hit the "bing" button which releases the carriage to the left so I could start a new sentence, and the carriage jammed, seemingly as far as it could go to the left. It has been suggested to me that the carriage has gone off the rail, but I would think it might wobble about a bit if that were the case, or be at some angle, but it does not, it is absolutely rigid and immovable.
I feel like this is probably something really simple to solve, and I'm a bit of an idiot for asking, but any reply or help on how I can free this carriage back into order is greatly appreciated.
Thanks and regards,
Carl.
  • 1 more comment
  • benway May 29, 2008
    Nope, that didn't do, but thanks a lot anyway. I think I know the one you mean. Do you mean the thing on some typewriters that holds the carriage in the middle so it doesn't move when being transported?
    Thanks again anyhow.
    Oh, I meant "that didn't do it" not "that didn't do". It was a perfectly good idea.
    I solved the problem! It required a little bit of force, which I didn't want to use, but after many hours I got fed up. I did muck about with the little tab, as Ryan said to, to release the mechanism, so maybe that was a part of it, but on it's own it didn't work.
    Directly under the carriage, toward the right, built into the rail, is a little lever, which I had also been fooling around with. I messed with the initial tab, and pulled this little lever under the carriage, and whacked the left side of the carriage with my hand quite hard, while trying to sort of jiggle it, or get it to budge (although at first VERY lightly with a hammer, but I stopped because I didn't want to ruin it)
    and finally it moved to the right and now swings freely!
    I used the initial tab to get it into position, BUT
    there is a new problem.
    I can move the carriage with my hand, and it is still connected to the string, springs, and rails and all, but it doesn't lock, that is to type, it just swings back and forth freely. Tapping keys has no effect except to just whack.
    Does anybody have any clues about this? Any advice is appreciated as I would love to start typing with this!
    Thanks very much for your advice Ryan, and to anybody who might be able to help out.
    Regards,
    Carl.
There might be a little tab below the carriage wheel on the left of the machine. You should be able to move it up or down, and release the mechanism.
Posted on May 13, 2008
Olivetti Lettera 32 typewriter - a few problems!
Problem 1 means the the spring on the springdrum has unwound. It is a job winding it and hooking the carriage cord back up. Might want to have a pro do this one.
Prob 2..some lettera 32's had preset tabs every 10 spaces. Also you can type by a tab..it is not a margin..it just stops the carriage when they are set.
Jul 12, 2010 | Office Equipment & Supplies
I have an Olivetti Lettera 32 cursive typewriter
Basic typewriter restoration (Xavier University) - http://site.xavier.edu/polt/typewriters/tw-restoration.html
Advanced restoration techniques from The Typewriter Restoration Site - http://www.xs4all.nl/~catch55/
Olivetti Lettera 22 Instruction Manual care of Strikethru blog: http://www.strikethru.net/2009/11/blog-post.html (Olivetti Lettera 32 replaced the 22 model, so many of the functions will be the same).
May 28, 2010 | Olivetti Lettera 35 L Typewriter
Olivetti Lettera 32 typwritter carriage doesn't move
If the locking lever is off, then the carriage is bound, or one of the tabs is hung, try releasing all the tabs, pushing the space bar or the tab key while gently moving the carriage.
Try all of the function like shift while gently pushing on the carriage always to the right..
also check the that the margins are not locked.
This could be a lot of different things...
Dec 18, 2009 | Olivetti Lettera 35 L Typewriter
Olivetti Lettera 32 typwritter carriage will not move?
There is a lever in front of the right knob that is used to lock the carriage.
Aug 31, 2009 | Olivetti Lettera 35 L Typewriter
Can't find carriage lock on Olivetti Lettera 25
Learn how to unlock the carriage in Olivetti Lettera 22 Manual posted by Ed Cornish (Carriage Locking Lever 7). It is a different machine model, but the lock/unlock mechanism might be the same.
You can see the full manual at Ed’s Flickr account or you can download it from here: http://dl.getdropbox.com/u/1322442/Olivetti%20Lettera%2022%20Manual.pdf (temporary link)
Aug 28, 2009 | Olivetti Lettera 25 Typewriter
Cant move carriage lock lever on the olivetti lettera typewriter.
Try lubricating the lock lever with a drop of Marvel Mystery oil.It should slide from front to rear
Jan 01, 2009 | Olivetti Lettera 35 L Typewriter
it should slide from front to rear.Maybe it could use a drop of oil.I use Marvel mystery oil
Jan 01, 2009 | Olivetti Lettera 25 Typewriter
Olivetti Lettera 22 - carriage jammed
THERE IS A CARRIAGE LOCK ON THE MACHINE IF I REMEMBER RIGHT IT'S SO THE CARRIAGE DOSENT MOVE WHEN IT IN THE CARRING CASE. LOOK ON THE LEFT AND RIGHT END OF THE CARRIAGE JUST BELOW THE PLATEN KNOBS OR IT MAYBE A LEVER ON THE SIDE OF THE KEYBOARD
Aug 17, 2008 | Olivetti Lettera 25 Typewriter
Carriage release
try jiggling the carraige around a bit and then try using that lever thats on the right side of the carraige. you might even try both at once to see what frees it up. i had the same problem and it worked for me. That's the right tab, it may be in a jammed position so it wont open properly.
Apr 26, 2007 | Olivetti Lettera 25 Typewriter
1,010 people viewed this question
jasbo
jasbo
