Question about Nova Development Video Explosion Deluxe for PC
VIDEO explosion delux mpg2 unlock codes for dvd authoring software
  • 2 more comments
  • Anonymous Jul 19, 2008
    I need the unlock codes for mpg2 clips for Video Explosion Deluxe
  • GeoMaree Oct 28, 2008
    Has anyone found the unlock codes yet? I'm in South Africa and don't want to phone - waaaaay too expensive. But I'm stuck because I can't open mpeg files or avi because of unlock codes.
  • Anonymous Nov 29, 2008
    The program is useless without the codes and the registration isn't up and running so I'm screwed.
  • Jumeira Dec 16, 2008
    Reinstalled video explosion deluxe after 5 years and I cant get my code from Nova site as it no longer exists.
I had the same problem. The following sequence had it resolved within 12 hours:
1. Go here: http://www.novadevelopment.com/Support/Support_Options.aspx
2. Submit your problem/question online, i.e. "need unlock codes for MPEG-2 support"
3. You will get a confirmation email almost immediately just to confirm your inquiry.
4. A second email should follow with the code.
5. Open the software. When prompted for the code, copy and paste the Activation Code directly from
the email.
Posted on Dec 27, 2008
I can give you my code. The problem is that it is on my external hard drive that I accidently started to format. I am looking for good reliable software to restore my data. Do you know any software that works? I've downloaded several and they won't even recognize the drive. At least windows recognizes the drive.
Posted on Apr 30, 2009
  • rwk0127 Apr 30, 2009
    Call this number; 818-591-6245 They will email you a new key to open the software. No, I wasn't put on hold. They were friendly and fast.
2 Suggested Answers
SOURCE: Unlock codes for Video Explosion Deluxe
To work with MPEG-2 files, you must do a separate, one-time online registration. Video Explosion will automatically prompt you to register the first time you add or create an MPEG-2 file in Video Explosion. They will send you the unlock keys. Since the company no longer supports it, I guess nothing can be done. I got my keys awhile back and enjoyed doing videos for events. I am running Vista now which cannot take Video Explosion Deluxe so I'm screwed as well.
Posted on Aug 09, 2008
Tip
Using VirtualDub as a FrameServer with TMPGEnc for MPEG2 Logo Removal
'VirtualDub was originaly codec for MPG4 video with XVid and DivX codes but it can be used with the MPG fcchandle plug-in to open an MPG2 video stream and then use the same Logo removal filters designed for AVI all you then need to do is export the frames TMPGEnc to produce a HQ MPG2 video stream for DVD authoring.
USING VIRTUALDUB FOR LOGO REMOVAL
To use VirtualDub as a FrameServer you must install the DLL files to enable this, to do this double click the AuxSetup.exe file in the VirtualDub folder.
Once this has been done all you need to do is Start the FrameServer in VirtualDub's menu the TMPGEnc v2.525.64.184 FE it has its own VFAPI Client plugin that will read the VFP that VirtualDub's FrameServer will produce. All you need to do then is to select a suitable template to encode your DeLogo video into DVD standard MPEG file Variable Bitrate will give you the best file quality. Unfortunately this MPG2 encoder will only allow you to encode the audio track into LPCM (large), MP1 or MP3 if your original audio track is AC3 (dolby) you may experience audio lag errors and have to compensate using an audio lag in the Virtualdub
I then use ConvertXtoDVD4 from VSOsoftware to author the DVD as my preferred choice.
You will notice that the FrameServer number of Frames Served will always be slightly ahead of the receiving FrameClient this is normal if the Client only recieved some of the Frames it is likely to fail on the MPG2 conversion.
If the MPG2 encoder that you are using won't allow you to open the default VDF file that is used then you need to enable the AVIProxy by importing the proxyon.reg tweak included with VirtualDub then start the FrameServer then open the AVI file in your mpg2 editor
You can also use these two alternative codec free encoders from RealMedia and WindowsMedia if TMPGEnc is not for your needs.
http://www.realnetworks.com/free_producer.aspx registration required
http://download.microsoft.com/download/8/1/f/81f9402f-efdd-439d-b2a4-089563199d47/WMEncoder.exe
on Feb 04, 2010 | Philips DivX DVD Player
MemoriesOnTV won't burn DVD without Unlock Code
Call (818)591-6245 to purchase a unlock code from Nova Development.
Jan 10, 2010 | Nova Development Photo Explosion Deluxe...
Unable to use unlock code
Well I suggest typing in the Letters in UPPER CASE and do not use the letter "O" if you see this it is a ZERO the Number 0
Apr 14, 2009 | Nova Development Photo Explosion Deluxe...
Burning movie using memories on TV3
If you burnt a DVD + , try getting a DVD - and burn to that or vice versa. Some DVD players play both the DVD + and the DVD -. Other DVD players will only play one of the two types of discsl
I burn all mine to a DVD +.
Jul 23, 2008 | Nova Development Photo Explosion Deluxe...
Jul 19, 2008 | Nova Development Video Explosion Deluxe...
Photo explosion deluxe 3.0 -memories on tv
use nero 7 i have full verison if u have yahoo msg works way bbeter slide shows dvd menus videos u did if your talking about burning dvdv u rent u need dvd fab i have that also for 10 bucks
Jan 24, 2008 | Nova Development Photo Explosion Deluxe...
I'm having the same problem... apparently you have to purchase the code... I'm going to call Nova Development customer service and I will let you know what they say... if you'd also like to call, the number is: 1-800-395-6682
Oct 06, 2007 | Nova Development Photo Explosion Deluxe...
Nova Development Video Explosion Deluxe for PC Logo
1,091 people viewed this question
Top Nova Development Computers & Internet Experts
David Payne
David Payne
Computer Links
John Hong
John Hong
Are you a Nova Development Computer and Internet Expert? Answer questions, earn points and help others
