Question about Dell OptiPlex GX280 PC Desktop
How to detect two IDE drives with same brand
I was using Dell GX280 with Seagate 80 GB Barracuda IDE hard disk and now I have purchased new Seagate 320 GB Barracuda IDE hard disk but my system is not detecting two drives at the same time. How can I do it ?
  • babakhan Apr 28, 2008
    I have tried following ways,
    1) placed jumper at master position on 80GB and removed jumper from 320 GB and then tried to detect but BIOS did not detected.
    2) placed jumper at master position on 80GB and cable select position for 320 GB and then tried to detect but BIOS did not detected.
    3) placed jumper at cable select position on 80GB and removed jumper from 320 GB and then tried to detect but BIOS did not detected.
    4) placed jumper at cable select position on 80GB and cable select position on 320 GB and then tried to detect but BIOS did not detected.
    5) removed jumper from both HDD and then tried to detect but BIOS did not detected.
    now if you have any solution please let me know.
    Regards
    Genius:
  • 1,027 Answers
Put both drives on the same ribbon cable, both drives set to cable select <CS>. the bios will then detect them as primary and secondary.New drives are RAW and therefore not detected by any Operating system until formated. You can use seatools from seagates website to install and format the drive or use disk manager in windows.
Partitioning the drive in Windows XP / Windows 2000 (for systems where this is the 2nd drive in the system).
  1. Boot into Windows XP.
  2. Open Computer Management and select Disk Management.
  3. Initialize the drive.
  4. Partition the drive.
  5. Format the drive.
  6. Assign the drive letter.
  7. Initiate changes.
Posted on Apr 23, 2008
  • Dell Master
  • 1,183 Answers
There are two things you need to do
As you have connected the 320 GB, go into the system BIOS , by pressing the F2 key five times on the DELL logo screen, once there press ALT+F keys , to reset the BIOS to reconganise your new hdd. Need to check the same under Primary drive and secondary drive section. If after the reset also the drive is not listsed you may need to install the driver that came with the 320 gb hdd.
Second case : If the hdd is seen in the BIOS but not under my computer, Right my computer icon on the desktop and click manage >go to disk management , you new hdd should show there , right click and create a new partision for the hdd and format the same
http://www.softwaretipsandtricks.com/forum/windows-xp/1610-adding-second-hard-drive-xp-pro.html
  • 242 Answers
You need to set one of the drives to be 'master' and the other to be 'slave'.
This is done by positioning jumpers on the back of the harddrives.
Pretty sure that on the drives is explained somewhere how to position the jumper, for several options.
Good luck,
Please post some feedback.
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Barracuda (ST380215A) 80 GB IDE (ULTRA ATA) 7200.10 Hard Drive Problem While installing Windows Xp sp3 hard drive not detect @ partition screen System configuration is as: Processor:- AMD Athlon XP...
Seems like your hard drive is malfunctioning, try another HD. That 80gb is already obsolete and the circuit board might have some defect.
If you could pull out the underside circuit and clean the gold contact points and try it again, if still not working...... buy a new one!
Check also the jumper and cable it must be in the "master" configuration.
Hope that helps you out!
Thanks for asking FixYa!
Aug 09, 2011 | Seagate Barracuda (ST380215A) 80 GB IDE...
Seagate Barracuda 7200.7 ST380011A "a disk read error occured"
Might be a damaged sector. Otherwise i would think you (by accident) created a seperate partition on your C:\ (? main) HD. The cause of damage can be many things, certain types of certain brands or more sensitive in how fast these sectors get damaged. But you can at least try to repair them with the disk repair utility in Win XP, called ChkDsk ("check disk"). However, what may end up happening is that ChkDsk will mark the sector as bad (instead of attempting to recover any information) and your hard drive will no longer 'hover' over top of that area of the drive, making it impossible to recover any data on the sector. Maybe try to google for (free) BETTER third party software for this first. So what caused it is hard to discover after it happened, but you can try to repair it.
Nov 05, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
I wanted to know whether ASUS A7S266-VM/U2 will support seagate 7200.10
M/Boards support all makes of hard drive
Are you sure you connected it correctly
The wide ribbon cable that goes in the rear of hard drive should
1) Be connected to M/board in the No 1 connector with the stripe on cable to the No 1 pin
2) the stripe on cable should go next to the 4 pin power plug on hard drive
Also ensure your BIOS is set to Auto detect of driives
Aug 30, 2008 | ASUS A7S266-VM/U2 Motherboard
Hard Disk hangs
You have to give it for reairing or buy a new hard disk..
Aug 22, 2008 | Seagate Barracuda (ST380215A) 80 GB IDE...
Hp compaq dc7600sff
750GB Seagate Hard Disk Drive IDE ATA100 7200rpm 16MB
available at http://www.microdirect.co.uk/(17679)750GB-Seagate-Hard-Disk-Drive-IDE-ATA100.aspx
1TB (1000 GB) Seagate Barracuda SATA II 300 32MB cache
also available at http://www.microdirect.co.uk/(23250)1TB-1000-GB-Seagate-Barracuda-SATA-II-300.aspx
Both HDD`s are what i consider to be best in there range and very good value for money
Nov 19, 2007 | Computers & Internet
Hard disk I/O error cannot formate harddisk shows no fixed disks how to solve
Please try to check with your cmos system if it was detected, if not means your harddrive was absolutely damage.
Please rate me solved!
Best regards,
Philip
Nov 16, 2007 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Dell OptiPlex GX280 PC Desktop Logo
461 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
