it seems that wireless is not supported, and you must use a USB cable. Check that the connectors are the correct ones; printer accepts a type B ('house') male connector (plug)
If uncertain consult Lexmark support, or the manual for this printer. Information (including probably a manual) can quickly be obtained from the webpage All Products Printers MultiFunction Lexmark X2650 Lexmark
The image shows two connectors (which may be on either end of a single cable, and what I think you need) lower is type B (printer end) , upper is type A (computer end, most commonly). Available in various lengths, you need USB 2.0 spec.
Please note that Lexmark does not recommend the use of refilled cartridges. Refilled cartridges tend to degrade in print quality and performance.
You may try to re-seat the cartridge and make sure it's properly seated in the cartridge carrier. Also note that once a cartridge is refilled, it can no longer register its ink level.
you can print print information
or you can check in the start> printer and faxes in the pc
righclick on the printer click advanced
select services
here you can see supply status
or you can connect to network
type the printer ip address on the browser
you will get all the information
If your looking for cheap ink, try buying a more expensive printer as ink for the expensive printers are relatively cheaper. I also tried refilling the inks for my printer but to no avail, it simply leaked out the bottom making a big mess
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Perhaps update your adobe reader software, or try opening your saved pdf through a web browser, although it still uses adobe maybe it will simply work that way? good luck.
Mohammed Mohiuddin Bangladesh +8801818788171 Lexmark X2650 Print problem…………
Fast time Print comment come Print the Alignment page
click print to pritn a page that will help you align and achieve the best quality.
I click print next come resend the print job
the recent print acrtidge chage modifed the forme of your print job.
evry time i print same problem. please solution & solve this problem.
