Powerware 9120 UPS System Logo
Posted on Jul 26, 2010
Help me!!! my eaton powerware 9120 6kva have a problem: low op/v (low output voltage). i have change all IGBTs . i nedd a circuit diagaram.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 24, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1121
Points
@hrvatmahir- may i know the part number of IGBT of powerware 9120 6000i? thanks.
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Sep 16, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1890
Points
Chek the optocoupler 3sd12
I have a "low A/C output" message. Is this related to a faulty DVR or another board?
From the user manual: http://lit.powerware.com/ll_download.asp?file=Eaton%20FERRUPS%20User%20Guide.pdf page 108.
The output voltage is below the alarm setting as determined by setup parameters 59 and 60.
Verify the output voltage using a voltage meter. If correct, verify setup parameters 59 and 60. If alarm condition continues, bypass the UPS and turn the UPS switch off. Call your service representative.
Powerware 9120 ups high output voltage massege
You have more devices/draw on your device than it is rated for - disconnect some of them.
Pawerware 9130 alarm 191
need to change batteries.
cannot hold charge
Replacement batteries were installed but were not Powerware brand. The brand put in is DataSafe P/N of Powerware is PWHR12120W3FR and I need the cross reference to the DataSafe type.
I don't know the exact cross reference number for you but Eaton tech support should be able to help you. Eaton bought Powerware 6 years ago but retained their service support personnel.
Toll Free: 1 800 843 9433
International: +1 919 871 1800
E-mail: [email protected]
1helpful
Low/o/p/v problem with eaton 9120 6kva , all IGBTs are changed....
Duplicate of question:
http://www.fixya.com/postanswer.aspx?thid=5390242&prdid=584807&ctgid=57&ref=unsl
2answers
Hi we have problem with 6kva 9120 eaton ups,
Maybe you have many overvoltage situations at your area, that the UPS can't handle. It's a good idea to put before the ups an overvoltage protection or a stabilizer. Ask the manufacture for the overvoltage protection of the ups that can handle.
Stelios.
Hi i jus need box and speaker specs for the dual 2 ohm 10pw3
General Information Manufacturer: Eaton Corporation
Manufacturer Part Number: 103004248-5592
Manufacturer Website Address: www.eaton.com/EatonCom/Markets/NorthAmerica
Brand Name: Eaton
Product Series: PW3105
Product Model: PW3105 700
Product Name: Powerware PW3105 700VA Tower UPS
Product Type: Standby UPS
Technical Information Plug/Connector Type: NEMA 5-15P
Receptacles: 4 x NEMA 5-15R - Battery Backup System
Switching Time:
  • 6 ms
  • 6 ms
Dataline Protection: RJ-45 Internet
Power Description Load Capacity: 700VA/420W
Input Voltage: 110V AC
Input Voltage Range: 0V AC to 160V AC
Output Voltage: 115V AC
Frequency:
  • 50Hz
  • 60Hz
Management Overload Protection: Circuit Breaker
Interfaces/Ports Interfaces/Ports: 1 x USB
Battery Information Batteries: Maintenance Free Sealed Lead-acid
Backup/Run Time: 3 Minute 420W Full-load
Physical Characteristics Form Factor: Tower
Dimensions:
  • 4.4" Height x 11" Width x 7" Depth
Weight: 9.7 lb
Miscellaneous Certifications & Standards:
  • Safety: UL 1778 3rd Edtion/CSAC22.2 No107.3, Designed to meet UL497A
  • EMI: FCC Class B
  • Software Included: Powerware LanSafe Software
    Green Compliance: Yes
    Green Compliance Certificate/Authority: RoHS
    Top Powerware Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
