MOST LIKELY, if convergence will not adjust in some part of the screen and or is bowed looking:
You need to locate the two convergence chips (usually STK-392-020 OR -040 THAT this set should use.
Most of these smaller Samsung sets they are located on a small circuit board mounted above the main boards--see photo of typical chip---should be two side by side.
If they are not located on that separate board, it will be much harder to remove/ replace them.
If the photo or this information helped you rate this solution as very helpful as I do this here for free.
SD TECH
THIS IS A TYPICAL CONVERGENCE CHIP--YOURS WILL HAVE A DIFFERENT NUMBER LIKE STK-392-040 OR -020.
TOTAL PARTS COST ON EBAY WOULD BE UNDER 20 DOLLARS.
