Question about Maytag MZD2766GES Side by Side Refrigerator
No water nor ice comes out
After changing the water filter, no ice nor water come out, I had to use a different filter in the back of the freg and installing a cab in the place of the old filter
  • johnhtrafcon Jun 19, 2008
    I changed filter, no ice nor water Help .
    Champion:
  • 210 Answers
Do you have water pressure to ref. water control valve? check voltage to water control valve assy. note: very difficult to diagnose these control valves, replace them both and be done with it.
Posted on Sep 15, 2008
New refrig 1 year old and it runs constantly. what can I do to correct this problem
if the freg make more ice the problem is th thermostat but if the freg run without good cooling thats mean you micro-gas leakage
Feb 12, 2015 | Frigidaire 20.6 cu. ft. Top Freezer...
Why water is not coming out of the line to the freg
First check to make sure the water valve from th water supply is on (usually under your sink), Second, hold the water despenser switch ON. You should hear a "Hum" sound, that's the Electric water valve in the "open" position. The air will have to be purged through the water line, Filter, And the water collection tank inside the frig. The water tank keeps about agallon of water Cold for the water despenser, and will supply cold water to the ice maker, so the ice maker can freeze the cold water much faster for your ice. When holding the Water despenser, and you do NOT hear the hum sound, there is NOT power to the water selenoid. Check the connections to be ure they are tight and secure. A volt meter can also be used to check the voltage. WARNING the voltage is around 120 volts A.C., Do NOT TOUCH with bare hands!
Jun 20, 2014 | KitchenAid KSCS25FKSS Side by Side...
I have a maytag mod# MFI2569VEM1 french style freg. and have ice in the back of the freezer and dont to know how to get the back or the freezer to defrost the ice. Have water randomly showing up on the...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 24, 2011 | Maytag MFF2557WH
I have a Kenmore side x side. I have changed the water filter and now water is coming from the water spout when water is needed to make ice. Just prior to changing the filter I noticed water coming from...
Sounds like the dual water inlet valve on the back where the water supply is connected, has gone bad and is leaking across to the other side. It may also put water into the ice maker when you use your dispenser.
Jan 13, 2011 | Kenmore 44103 Side by Side Refrigerator
My kitchen aid refrigerator model KSB251NBL..NO ICE
Problem could be a couple of things.One There is a little control in the very back,its should be on the lower right side looking at the freg. from the back.It has a water line running up to the ice maker.If that is ok,you will need to replace the ice maker.It is not a big problem on either.Cost is for the little controll about $30.For the ice maker about &90.
Aug 29, 2009 | KitchenAid Refrigerators
HAVE REPLACE THE FILTER, NO WATER OR ICE WHEN FILTER WAS OUT MADE ONE BATCH OF ICE THEN STOPPED NO NOTHING WATER IS ON NO KINKS IN HOSE WHAT IS WRONG THANKS ROSE
Try putting the old filter back in . Just because the " change filter " light comes on , does not mean to actually change the filter if your water dispensor is not just trickling out . If water was coming out fine before replacing filter , no need to replace it just because ot the indicator . I have found new filters which worked worse than the old filter . Just put the old filter back in and problem solved .
Jul 18, 2009 | GE Profile PSI23NCR Side by Side...
In my GE Performance refrigerator side-by-side Ice is being made, but no water is dispensing. The GE Smartfilter is atleast 5 yrs old (I never used/never changed) because we always bought water from...
The water that goes to the door actually is routed through the hinge on the freezer door. Take a look and see if you can't find where the tube comes out and goes into the water dispenser. I bet it has come loose and is rerouting the water down the side of the fridge and onto the floor; hence the puddle.
Also, just because you don't drink the water doesn't mean you don't drink the water! If you use ice from the ice dispenser then you ARE drinking the water. The water that feeds the ice trays comes through the filter, so you might consider changing it every 6 months rather you use the water dispenser or not.
Hope this helps, I have one too and its causing a different set of problems...
May 11, 2009 | GE Profile Performance 25.2 cu. ft....
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
79 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
