Can I tie specific inputs to buttons on the remote, to save having to cycle through multiple inputs
  • 1,512 Answers
Yup you can, but your remote generally need to be able to do what is called a macro. It can be programmed to do several button presses in sequence for you to setup different arrangements for your AV. What model remote control do you have? I can check it out for you. Make and model is good :)
regards
Graeme
Posted on Apr 23, 2008
How to source AV Input on remote
Search Results
    How do I change the input on my television? ' FAQ ' Cogeco ...
    https://www.cogeco.ca/.../how-do-i-change-the-input-on-my-tele...
    CogecoClick on the TV button near the top of the remote. Click on the video source button on the bottom left corner of the remote. Using the arrow keys to highlight/select the inputyou want. Some televisions may require pressing the source button multiple times to change the inputs.
    Understanding Inputs - Harmony Support - MyHarmony
    https://support.myharmony.com/.../understanding-different-input-changi...
    Televisions, AV receivers, soundbars and other home electronic devices switch ...Devices with toggle (or cycle) inputs have a single button on their remote that ... In the below example, you would press the Source button to bring up a list of ...
    Changing AV input on TV using Sky remote ' AVForums
    www.avforums.com > ... > Satellite TV, Sky TV & FreeSat
    Changing AV input on TV using Sky remote. Discussion in 'Satellite TV, Sky TV ...VSX-924 LG simplink changing AV source to TV. Posted By djrobmac In AV ...
    Selecting the DVD, VCR, Game Console, HDTV, Camera, or ...
Feb 08, 2016 | Venturer KLV39150 15" Under Cabinet LCD TV...
How do you change to hdmi video source
There are several ways to change your video input source for the E421VO. First: the lowest button on the side of the TV will cycle through the inputs. (The power button is the top button.) The original remote has the Input button to the left of the Zero button at the bottom left of the number area. With both just press the key multiple times to go through all of the inputs. Alternatively, press the Menu button and look for the Source sub-menu. Use the arrow keys to move to the chosen menu. (On the TV, the menu button is below the power button. On the remote, Menu is the button to the top right above the arrow keys.) If you are using a universal remote, you may need to find one that matches the Input or Menu functions for your TV. A different code may help if the remote has either button. Otherwise, you'll need a different remote.
The manual for the Vizio E421VO is available from Vizio's product site: http://www.vizio.com/e421vo.html . Click on the Support/Manuals tab. The direct link to the manual is http://www.vizio.com/documents/downloads/hdtv/E421VO/UM_E421VO.pdf . All of these options are shown in the manual.
I hope this helps.
Jan 17, 2016 | Vizio E421VO - 42in Lcd 1080p 60hz Hdtv
How do I get rid of a no signal sign on my tv
You may have the wrong input source selected. There are a number of different source connections on the back of today's TV sets. Using the remote's SOURCE button, cycle through the different inputs until you find the one that your input device is attached to. It is common for users to inadvertently cycle off the correct input when pushing remote buttons.
Mar 02, 2015 | Televison & Video
I have a no signal prompt on my jvc flat screen, the Verizon fils box is working, how do I fix it?
Make sure you have selected the correct INPUT. Many TVs have several from which to choose. Locate the INPUT or A/V button on the TV or remote. Press it once and wait up to 3 seconds to see if the picture appears. Repeat to cycle slowly through all inputs until picture appears. Some TV / remotes have buttons labeled AV1, AV2, AV3, etc. or similar do go directly to the specific input as opposed to cycling as above. Press each - one at a time - and wait up to 3 seconds for picture to appear.
If unable to display a picture, check A/V cables at cable box and TV. Note which input is being used on the TV for the cable box. Then select the same AV input on the remote that is being used on the cable box.
If still no picture, contact cable company / Verizon for service.
Jun 26, 2013 | Televison & Video
How do set the resolution on a samsung 50" plasma (ps50q7hx)
make sure that the tv is in "HDMI" mode. If there are multiple HDMI ports on your tv then check to see which one it is. You should see HDMI 1, HDMI 2, etc. Then when you are sure what port it is in on either your tv directly or using the remote press the input button until the desired input is selected. So for example, if you have it in HDMI port one, press the INPUT button on either your tv or remote and cycle up or down until you select HDMI 1 and that should do it! sorry if it doesn't!
Dec 13, 2012 | Samsung Televison & Video
Channel is stuck on my driveway
From the video, there is only a picture of a security feed. Please be specific as to model, type of equipment, description of problem and desired solution.
Oct 19, 2012 | Televison & Video
The set was left to play DVD and I do not know how to get it 'back' to be able to view TV
Which TV do you have? For most "modern tvs", there will be an input or source button on the remote. Press this button to switch inputs and eventually get back to the TV source. Some TVs have a button for the Input or Source on the TV itself. On a few older TVs, the button was marked TV/Video but did the same thing.
An exception: if you have a cable or satellite set top box, you may need to do an extra step. These require you to set the TV on a specific channel depending on the box (Ch3, 4, 60 (Dish Network)) Thus you need to change the input and then the channel if needed.
If you have a tv that uses the input button on the remote but does not have a matching button on the TV, then you need to replace the remote with one that has the feature. Some original remotes are available from remotes.com (search using the tv model number but not the manufacturer). Universal remotes may have a matching button except for the cheapest ones. However, you will need to try multiple codes to find the one that enables the input button. The universal remotes that can be programmed via a USB connection with a computer are the fastest to set up.
For a combination TV, you may need to press a TV/VCR or TV/DVD button on the remote.
I hope this helps. If you need additional assistance, please add a comment with your TV model number and brand. I may have the manual available.
May 20, 2011 | Televison & Video
WHICH IS THE HDMI BUTTON ON THE 37WLT 58 MODEL TOSH TELE
There is no HDMI button however there is a single INPUT button that cycles through all of your available inputs both on the tv and on the remote. As I looked up the remote directly it is very complex and I would encourage you to look over the user manual for it as there are more then one remote for this device. And the manual you have will be device specific, also will have diagram's for un-labeled buttons.
May 09, 2011 | Televison & Video
I have been struggling to get the tv to move to the correct input when I switch from watching TV with Tivo to watching a DVD. I thought I'd made the correct selections, but end up either having to use the...
There are 5 types of input switching methods that you can come accross for each device. In the Software is says there is certain input switching methods that go with certain manufacturers - This is NOT the case. The following is the list of all the inputs:
1) Toggle (Method 1): You only use one button on your original remote to cycle through a set of inputs.
2) Discrete (Method 2): You have multiple buttons on your original remote where each button goes to a particular input and stays there, no matter how many times you press this button.
3) Menu Toggle (Method 3): A menu pulls up where you can scroll through the set of inputs and select which input you would like.
4) Menu Discrete (Method 4): A menu is pulled up where you use another set of numbers to select which input you would like. (you do not cycle through each input)
5) Multi Method (Method 5): A combination of any of the above. This can also mean that you have multiples of one of the above input switching methods.
Make sure you follow through the prompts for them but the Method 5 - you would have to contact Logitech Directly to get it added!
Jan 18, 2010 | Logitech Harmony 890 Universal Remote
Lost remote to 27in rca tv, how can i switch my tv to input/output mode so i can watch movies on my dvd playter? i have a rca univeral remote, but it will not change my tv to input or output.
using the menu button on the t.v. set an alarm for 1 min in the future. have the t.v change to channel 00 or the input channel @ that time. turn off the t.v and wait until the alarm turns the t.v on.
Aug 11, 2007 | RCA 27F534T TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
