Question about Car Audio & Video
Trying to hook up a amp to my 05 Tahoe
I have an 05 tahoe with the touch screen nav system, where do I hook up the remote wire to turn the amp on?
  • csantino Apr 24, 2008
    Thanks for the help
  • channingmill
    channingmill Jan 24, 2012
    im having the same problem
    Problem Solver:
  • 6 Answers
If u cant find a wire specifically for the amps remote turn on then u can always connect it to a switched fuse in the fuse box
Posted on Apr 24, 2008
05 tahoe blower motor do not stop
check blower motor resistor connector could be burnt or resistor it self
Jan 30, 2015 | 2005 Chevrolet Tahoe
Spark plug wiring diagram for 05 tahoe
Greg Bernett 2821 Solutions February 14, 2010
You didn't post your engine size so please pick the applicable diagram:
1996-98 4.3L Engines Firing Order: 1-6-5-4-3-2Distributor Rotation: Clockwise
1996-98 5.0L, 5.7L and 7.4L Engines Firing Order: 1-8-4-3-6-5-7-2Distributor Rotation: Clockwise
4.3L Engines Firing order: 1-6-5-4-3-2 Distributor rotation: Clockwise
4.8L, 5.3L and 6.0L Engines Firing order: 1-8-7-2-6-5-4-3 Distributorless ignition system (one coil on each cylinder)
5.0L, 5.7L and 7.4L Engines Firing order: 1-8-4-3-6-5-7-2 Distributor rotation: Clockwise
Source: spark plug wiring diagram for 98 tahoe
    ledsled378 2926 Solutions July 24, 2010
01f93b7.jpg ..............................
Source: Need diagram for spark plug wiring for 1997 Chevy
Testimonial: "Thank you for your prompt response. Saved my husband from some distress!"
Was this solution helpful? Yes No
    Dennis Weid. 44272 Solutions September 16, 2008
This was all I could come with, hope it helps.
Feb 27, 2013 | 1998 Chevrolet Tahoe
I need the wiring diagram for the IAT Sensor in my 2005 Chevy Tahoe. I nned it to hook up one of those cheap little "chips" just to see how it works before I spend $ 300 for a Superchip.
Wouldn't you be better to spend $300 on tools ,reference material,
test equipment or a code reader, than that nonsense & possibly
ruin your vehicle & most certainly accomplish nothing
Learn how vehicles work & how to diagnose them & in 20 years
you can play with a race car or something
Feb 07, 2013 | Cars & Trucks
Fuse number 9 (prkinglmps) blows. taillights, dash lights, and parking lights donty work. why? i replaced the fuse 12 times. same ****. went with 30 amp instead of 20 . blown. what the ****? why does it do...
You have a wire touching to ground (the frame or metal part of the vehicle) somewhere. Do you have a trailer light hook up? If so I'd start there, look for bare wires, or damaged wires. Do you have any broken tail lights or parking lights? Look for bare wires there too, or it could be a bad bulb. Good luck. Don't put a bigger fuse in the system, the wires will burn up. The wires will only handle so many amps if you put in a higher amp fuse the wires will get hot and start the vehicle on fire.
Apr 05, 2010 | 1995 Chevrolet Tahoe
What is the size of the 2002 chevy tahoe stock stereo? I want to put in a pop-up Nav. system and cant figure out if it will fit...
i do not know stop by your local GM dealership in the parts department and they be able to tell you
Dec 17, 2009 | 2002 Chevrolet Tahoe
Problems with 98 Tahoe misfiring on hills & passing gear usually cylinder 5
Sounds like a bad spark plug or spark plug wire and if thats not it try checking the fuel injector
Sep 05, 2009 | 1998 Chevrolet Tahoe
98 tahoe wont hold charge
Sounds like you have a bare wire somewhere that is touching metal and grounding out. Probably a starter cable. Try unhooking the battery, check the voltage of the battery, then hook the cable back up, watching for sparks from the cable. After you get it hooked back up, check the voltage again. If you see a small spark, it is normal. If you see a big spark, you have a wire that is touching something it is not supposed to.
Jul 02, 2009 | 1997 Chevrolet Tahoe
2001 tahoe will not shift from second gear
this is known as "limp mode"
there should be a fuse in the dashboard fuse panel, or possibly the one under the hood.. one will be labeled trans or tcm - something of the like...test ALL fuses in the fuse boxes for good measure, and change the fuses if you find any blown.
ALSO....
Did you recently have a remote start system installed? If so, they need to hook up the smaller white wire in the ignition harness to turn on with the ignition power from the remote start unit. If the ignition wire and the white wire (transmission control) are not powered at the same time, the trans will go into limp mode.
Dec 18, 2008 | 2001 Chevrolet Tahoe
2004 Chevy Tahoe stereo wiring diagram
BLACK-ground
RED-accessorie
YELLOW-power 12v
PURPLE-left rear
GREEN-right rear
WHITE-left front
GREY-right front
BLUE-REMOTE
and the other blue one is for remote antenna..
Dec 04, 2008 | 2004 Chevrolet Tahoe
99 tahoe with remote start no start problem.
Sounds like you may have a cable issue. You should have two positive cables one supplying power to starter and one powering vehicle. if the starter power wire is not getting good connection but other is then it will only click. check this wire for corrosion inside cable
Nov 14, 2008 | 1999 Chevrolet Tahoe
Car Audio & Video Logo
117 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
