Question about Lexmark X5470 All-In-One InkJet Printer
Cannot send or receive fax
Transmission error report:phone line error.called phone co.I able to speak & rec calls, but cannot fax.
I changed my phone line to timer warmer from at&t and now my fax machine won't fax out. I unplug my unit, turned it off, i them tried again to fax still didn't works
    Genius:
  • 3,587 Answers
You may wish to try this link, and see if you find what you are seeking
www.lexmark.com
Posted on Apr 29, 2008
ECM error message
Noise in the phone line, or low signal strength during fax transmission can result in fax failures. Noise or poor signal strength can cause a partial or complete loss of fax information during transmission. When Error Correction Mode (ECM) is on, the receiving fax machine checks the fax information for errors during reception. If the receiving fax machine detects an error, the receiving fax requests that the sending fax resend the information. Resending all or part of the information can make transmission times longer, but helps improve the quality of the received fax.
If the phone line quality or signal strength is extremely poor, sending a fax can fail. Turning off ECM can improve the ability of the product to send a fax successfully when the phone line quality is poor. However, the image quality of the received fax might be poor.
If ECM must be off to send faxes successfully, have the telephone service provider check the phone line quality. For an HP Fax, turning off ECM from the control panel does not necessarily mean that fax transmission will not use ECM. Fax products use ECM as follows.
  • All faxes sent in color use ECM.
  • All faxes sent at the highest transmission speed use ECM.
  • The ECM setting affects only sent faxes, not received faxes.
Enabling or disabling Error correction mode (ECM)
  1. On the product control panel, press the Menu button (c01743394.gif ).
  2. Use the arrow buttons (c01073166.jpg ) to select Basic Fax , and then press the OK button (c01335940.jpg ).
  3. Use the arrow buttons (c01073166.jpg ) to select ECM Mode , and then press the OK button (c01335940.jpg ).
  4. Use the arrow buttons (c01073166.jpg ) to select On or Off , and then press the OK button (c01335940.jpg ) to confirm the setting.
  5. Press the Back button (c01496476.gif ) twice to return to the main screen.
Mar 06, 2014 | HEWLETT-PACKARD HP 2140 Fax
My HP Laserjet 3050 used to print automatically after each fax sent a call report showing that the page(s) had sent. For some reason, after a service call, now it doesn't do that any more and I have...
Hi Dear
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming
Jun 01, 2011 | HP LaserJet 3050 All-In-One Printer
On my activity report, under comment is states TX ECM I know the TX is transaction (I think?) what does ECM stand for
ECM (Error Correction Mode)
The Error Correction Mode (ECM) is a way for the fax machine to check the integrity of a fax transmission while it is in progress. ECM transmissions are possible only between machines that both have the ECM feature. If they do, you may send and receive fax messages that are continuously checked for their
integrity.
Sufficient memory must be available in your FAX/MFC for this feature to work.ECM (Error Correction Mode) Detects errors during fax transmission and resends the page(s) that had an error.
If you have Call Waiting, RingMaster, Voice Mail, an answering machine, alarm system or any other
custom feature on a single phone line with your fax machine, it may create a problem sending or
receiving fax data.
For Example:
Your Brother machine handles the Caller ID and Call Waiting/Caller ID subscriber services.
However, if you subscribe to only Call Waiting or some other custom service and its signal comes
through the line while your machine is sending or receiving a fax, the signal can temporarily interrupt
or disrupt the fax data. Brother's ECM feature should help overcome this problem. This condition
is related to the telephone system industry and is common to all devices that send and receive
information on a single, shared line with custom features. If avoiding a slight interruption is crucial
to your business, a separate line with no custom features is recommended.
Jan 20, 2011 | Brother IntelliFAX 2800 Laser Fax
Getting Error TX Report: Result 'NG' - what does this mean???
It means No Good or Not Good, fax was never received for a number of reasons.
Oct 07, 2009 | Canon FaxPhone L75 Plain Paper Laser
Fax series 920, can receive but not send faxes, error code 344*
Do you have or are you sending a fax to a party that has a DIGITAL PHONE SERVICE?
Jun 04, 2009 | HP 920 Plain Paper Fax
Laserjet 3330 is resulting in fax Comm Errors 327, 232, 442, 356, 421 Comm Error 327 is always with fax # 780.467.6516. i can not fax to this number and when i receive from it, it always prints a Fax...
232-A communication failure has occurred between the two machines.
327-*Reattempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
356-The remote user has pressed the Stop key, causing the session to be aborted.
442-An error occurred during transmission after one or more partial pages had been sent. The transmitting machine was unable to restart the control channel (handshaking) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page but can also occur if the receiving fax is using a fax format that is incompatible with the HP fax machine (usually during color faxing).
Aug 15, 2008 | HP Computers & Internet
Fax confirmation set up
document.tlSearch.tx.value=unescape("") s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
Mar 31, 2008 | HP LaserJet 3050 All-In-One Printer
Is the fax also connected to the pc, it may be monopolising the line.
Jan 24, 2008 | Lexmark X4270 All-In-One InkJet Printer
Fax Confirmation Sheet
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
Vonage vs Brither 4100
Have you called your own fax line and just listened to the fax hand shake? might sound simple but I have called fax lines before and it just rang, or it was busy or static, if your not getting a clear fax hand shake, then it is the phone line, if there is no answer you may have turned your fax to manual receive mode, If you don't know how it should sound call a friends business fax line and listen to it. I have actually gone out to businesses that reported send or receive problems just to call the line and listen to a disconnect message, that would make it difficult to fax.
Jan 13, 2008 | Brother IntelliFax-4100e Fax
Lexmark X5470 All-In-One InkJet Printer Logo
152 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
