Question about Kenmore 44103 Side by Side Refrigerator
Compressor not running, front display flashing "CF"
Already replaced Pc board, main control, and the front cover assembly (includes user control board)
The fridge and freezer not working compressor not kicking on, the front freezer temp display is flashing " CF"
  • hopeitworks May 07, 2008
    yes getting voltage to compressor.............called the repair guy again..........
I need problem with the relayand overload
Posted on Jul 25, 2008
    Scholar:
  • 149 Answers
Have you tried to see if your getting voltage at compessor?? it sounds like relay/overload is bad have you replaced it?
if not, try that i'm suspecting that's the problem
Posted on Apr 23, 2008
Fix my problem get sy cf on my display
Hello Eric espy, thanks for your post!
From my understanding you used the icemaker on your Frigidaire refrigerator and now have a code of "SY CF" on the display. That code of "SY CF" stands for communication failure after power up. This could be a possible communication error between the UIB (User Interface Board) and main control board. I would suggest performing a reset, which should clear any false error codes. If you continue to receive the error I would suggest contacting a professional technician for proper diagnosis and repair. This may help you avoid unnecessary part purchases. -Matt
Feb 22, 2015 | Frigidaire Refrigerators
Tip
KitchenAid, Whirlpool side by side refrigerator remove the main control board...
Electrical Shock Hazard
Connect green ground wire to ground
screw.
Failure to do so can result in death or
electrical shock.
REASSEMBLY NOTE: Be sure to reconnect
the green ground wires; one to the compressor
terminal, and the other to the chassis (see the
previous steps).
7. To remove the main control board assembly:
a) Remove the unit compartment cover
b) Remove the two hex-head screws from
the rear of the main control board assembly
enclosure, and position it so
you can access the board.
c) Remove the wire connectors from the
main control board assembly.
KitchenAid, Whirlpool side by side refrigerator Component Location and removing cover
http://www.fixya.com/support/r5759997-kitchenaid_whirlpool_side_side
KitchenAid, Whirlpool side by side refrigerator removing Unit compartment cover method A
http://www.fixya.com/support/r5760017-kitchenaid_whirlpool_side_side
KitchenAid, Whirlpool side by side refrigerator removing Unit compartment cover method B
http://www.fixya.com/support/r5760029-kitchenaid_whirlpool_side_side
on Aug 27, 2010 | Refrigerators
Tip
KitchenAid, Whirlpool side by side refrigerator Component Location cover
Component Locations.
As you see the refrigerator on the top you can see the decorative panel.
Above refrigerator after you will remove the front decorative panel you will find the compressor on left side behind the inverter assembly and on right the Main control board assembly and behind it the condenser fan motor both secure inside silver aluminium boxes and located over the bigger box of the condenser.
KitchenAid, Whirlpool side by side refrigerator remove the main control board assembly
http://www.fixya.com/support/r5760103-kitchenaid_whirlpool_side_side
What does F70 mean on a front load dryer?
Hello Carol;
My name is Peter. I am a retired field service appliance technician.
F70:
No communication between the electronic control board and the user interface control board assemblies.
Unplug the dryer. Check the wire harness connections between the main electronic control board and the user interface control board assemblies. If the connections are sound, have a technician diagnose the cause of the communication failure. The main electronic control board and/or the user interface control assemblies might need to be replaced.
Dec 06, 2014 | Whirlpool Dryers
Frigidaire SY CF issues
Good Morning Jack, thank you for your question!
Typically error code SY CF indicates that your refrigerator has detected a communication failure after power up. The error code may possibly continue after replacing the part you have ordered. With this error code, a professional would need to check wiring between the main control board and user interface board. After proper diagnoses and if the error continues, the main control board may need replacing. Hope this information helps to some degree!
Dec 27, 2013 | Frigidaire Gallery Series GLHS269ZDB 36"...
DE error code on LG washing machine
Beyond that could just be the door latch itself.
Nov 23, 2013 | LG WM-2277HW Front Load Washer
Not running
Make sure it is not in "Demo" mode
Nov 23, 2013 | Electrolux E42BS75EPS 26 CuFt Built-In...
My frigidaire is displaying SY CF
Hello Angela Clark - Typically error code SY CF indicates that the refrigerator has detected a communication failure after power up. Contact a professional to move forward accurately. The wiring between the main control board and user interface board will need to be check and diagnose. Depending on the diagnoses the main control board may need replacing.
Dec 05, 2012 | Frigidaire FGHB2844L
F1 error code
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Affinity washer displays ERR. PAU and 43
HI. This is a strong indication of Main control board failure. Essentially, the board is having problems communicating with the other corresponding units in the washer. The necessary actions will be to replace the Main Electronic control board. The part number for your new control will be 137007000. I have also included a service manual for this unit, which will guide you through the replacement procedure. Click here to access the service manual.
The removal process for the electronic control assembly will be located on page 74 of the manual provided. Start on page 73, under "RELEASING THE CONSOLE" and work your way through page 74. Those instructions will help with the removal process of the control board.
Aug 10, 2010 | Frigidaire Affinity ATF7000E Front Load...
Kenmore 44103 Side by Side Refrigerator Logo
156 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
