Question about Sony KV-36XBR450 36" TV
Picture bowing up in middle
While watching straight lines like the sat. guide the picture is bowed up in the middle. anout 3/8" at the bottom and 1/4" at the top. Is there an adjustment in the back for this and can I do it myself? I do have alot of video savy as I build computers and have fixed some TVs before.
Thanks
  • Dirtys Apr 25, 2008
    Thank you. Since there is not a simple adjustment to fix the problem, checking caps and repairing such a problem is something I would not tackle by myself. But the info is important so when I call the repair shop I can describe the problem correctly. Pin Amp Distortion.
    D
    Genius:
  • Sony Master
  • 1,689 Answers
The most common cause for this are electrolytic capacitors in the pinn amp and scan amplifiers going out of spec with age and use. It is more rare, but it is still possible have other support components go defective in these areas. This fault is refered to as pin amp distortion.
I have repaired many of this type of problem over the years.
If you decide to troubleshoot this yourself, take care about the high voltages employed in the TV set.
Jerry G.
Posted on Apr 25, 2008
2001 Sony KP-53V90 53 in. Rear Projection Television has a problem related only to the picture, the top and bottom of the screen are bowed into the middle, the video feed label and volume scale are also...
This is probably the notorious "light engine" problem that all of these Sonys of this design run into sooner or later. It is usually more expensive to repair that what the TV is worth, sadly. A Sony authorized repair center can confirm this.
Feb 18, 2011 | Sony KP-53V90 53" Rear Projection...
SONY TV PICTURE WENT BLANK WITH A STRAIGHT LINE THRU IT
want to know wat straight line. 1.white line in the middle from left to right or 2.white line from bottom to top there is a big diffrence in these two lines if 1 then u have to check the cvertical section ,the o/put may gone bad if 2 then u have to check the scanning coil
Jan 09, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Rca r52wh74 . Double picture .
Go to menu then setup look for convergence if you do not see convergence then you have a open FUSE FL231 it will be on right side of FBT flyback transfomer there will be 3 ina roll they are small brown rectranigler looking caps but are FUSES. It will be the one in the middle.
Feb 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Watching TV and top 1/3 screen ghosted by colors
on this type of tv each gun is controled by hor.and ver. chip together. it is on the board that controls the convergence of the tv. some manufactors have recalls on problems like this. i dont know if this one does but it may. you can check with mitsub. i do know that this part is about 250.00
Jan 02, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Toshiba CX32G60 1/2" vertical inward bow center of video
change the electrolytic capacitors in the vertical section of tv. you do need a qualified tv tech to do this repair for sure
Nov 30, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
Slight bowing of picture
Only on newer TV's, yours (I dont think)has the adjustment, if it does it would be in the menu area.
Apr 22, 2008 | Sony KV-36XBR450 36" TV
Goofy intermitent picture (bows with wiggly fibers across screen)
Convergence amps are going bad replace these and you will fix your intermittent problem.
josh
Mar 02, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Bowing in the middle like an hour glass
OUCH!!!! Don't kick me...would be my response if I were your TV
Convergence amps problem.
If it works after a kick I'd say poor solder joints on the convergence amp leads
Dec 17, 2006 | Zenith IQB50M90W 50" Rear Projection...
Picture Distortion
you have a convergence problem.. If you understand how this works then you can go into the set find the convergence ic's and replace them and sometimes you need to do some alighnment as well. Its always best though to let a service tech do a job like this as he will have all the proper equipment to adjust and troubleshoot the set Good luck
Mar 30, 2006 | Sony KP-53HS30 53" Rear Projection...
Sony KV-36XBR450 36" TV Logo
73 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
