Konica Minolta 7450 hasa a error message "service callof34" what does this mean?
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
  • 16 Answers
SOURCE: konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
Posted on Jul 19, 2008
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
  • 6595 Answers
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
Posted on Jul 25, 2009
  • 6595 Answers
SOURCE: what does code 2454 mean on the konica minolta
Developing motor for the Black, working in conjunction with Toner Control Sensor.
Posted on Jul 31, 2009
What is service code 36 on a Konica Minolta 7450
there si no such code..please send again what is your error code
Jul 26, 2017 | Konica Minolta Office Equipment & Supplies
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ... > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from
Error code C-B116, what does it mean? - Fixya Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
Konica Minolta Magicolor 7450 II laser error Y
replace the printhead which house the LASER for the yellow image unit
Feb 17, 2014 | Konica Minolta magicolor 1690MF All-In-One...
My Konica minolta 7450 leaves vertical creases on A3. Any ideas?
Check the paper vertical transport section(clutch,rollers) and the fusing unit lower pressure roller.
Apr 15, 2013 | Konica Minolta magicolor 7450 Laser...
How to enter service mode konica minolta magicolor 7450
1. Display [SERVICE MENU] on the menu screen and press the MENU/SELECT key.
2. [ENTER PASSWORD] message is displayed.
3. Set first digit of password with the up key??/down key?? and press the right key??.
4. Repeat the above procedures to set up to seventh digit of password.
Enter "KMM7450" for service password. Press the MENU/SELECT key.
5. Press the MENU/SELECT key.
Jun 20, 2012 | Konica Minolta magicolor 7450 Laser...
42 people viewed this question
