Question about Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Canon EF-S 17-85MM F/4-5.6 IS, Canon 28-300 L IS
Hi, have been getting intermittant error 99 during shooting with both lenses. Only after removing lens and battery several time does the problem dissapear, only to surface on the next shoot. It seems to happen when I take the first few shots on a job. Ant advice? I have downlaoded firmware version 2.0.3
  • 2,985 Answers
You will have to refer to Canon re this - it possible the firmware update did not take or was the wrong one.
Posted on Apr 24, 2008
My canon ds6041 displays err 99 when i try to capture light aur object in sun light.What should i do i'm using 70-21-mm lense
Usually this is cased by shutter failure or failure of the aperture unit in the lens. Try another lens and see if you get the same error message - that will tell you if the problem is in the camera body or lens
Apr 05, 2013 | Canon Digital Rebel / EOS-300D Digital...
My cannon rebel eos DS6041 displays error 99 when
'Error 99' indicates some problem with the AF contacts. This is a common error in Canon lenses. It could indicate a very simple problem like dirty contacts or a much serious one like the breakage of USM cable.
As a first step, you can try cleaning the lens and body contacts (the metal contacts between the lens and body) using a pencil eraser. Be careful to hold the body facing down so that no dust falls inside. After cleaning both the lens and the body contacts, re-attach the lens and try shooting. If the AF does not work still, you need to take the lens to an authorized service center.
Jun 01, 2010 | Canon Digital Rebel / EOS-300D Digital...
Lens not communicating with camera
contact problem or lens diaphram blades problem. First try to clean the contact with the pencil eraser. If the problem isn't solved. send it to canon it should cost you about 100.00 to repar.
Mar 14, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
EF-S 17-85 AF jumping around causind err 99
The AF motor is hunting. Clean the contacts on the end of the lens and the camera body with a pencil eraser and try again.
Jan 20, 2010 | Canon Cameras
My canon EF-S 17-85 IS USM lens will cause an error 99 when in wide angles at 35mm or less. The iris closes but will not open until I "re-boot" the camera. Other lenses work fine on the camera and the...
Zborn, did you find any solutions? I have had same lense for 2-3 years, taken maybe 10000 shots and just yesterday started to get error 99. Spent most of today trouble-shooting to repeat problem and it seems that when I set to less than 35mm I get the error 99. other settings and my other lense has no problems.
Dec 18, 2009 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
I have a Canon EOS, 1000D which I purchased in Feb 09. I have an error message coming up on the screen everytime I take a shot (which doesn't record). The error is a Err 99, "Shooting is not possible. Turn...
I did some digging and found that this error is most often a lens communication error. Are you, by chance using a non-Canon lens?
Try the following:
1. Remove the lens and take a picture without any lens on. If you get an ERR 99, then it is a camera issue and you will need to contact Canon for further troubleshooting or repair (ie. not the lens).
2. If you do not get the error with the lens off, try it with a Canon lens or any other lens. If no error, it is a problem with the original lens.
3. If the error occurs on both lenses, clean the lens contacts both on the lens and the camera (refer to your manual).
Hope this helps.
Nov 21, 2009 | Canon Rebel XS / Eos 1000D Digital Camera...
Err 01 during slow shutter speed shooting
I having a similar problem and send back to the Canon service centre for repair. Subsequently, it was confirmed that the aperture diaphragm is faulty and need to be replaced.
Dec 02, 2008 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Error 99 in canon 400D
You will get that error when using some lenses other than Canon. A lot of the older Sigma lenses have that issue. Do you get this error when using newer Canon EOS lenses?
Apr 01, 2008 | Canon Digital Rebel / EOS-300D Digital...
Error 99
Trouble shooting Error 99
1. Solution: Remove and replace the battery.
Power the camera off
  1. Remove the battery.
  2. Wait 15 seconds.
  3. Replace the battery.
  4. Power the camera on.
2. Clean the lens contacts.
Clean the lens contects on the rear portion of the lens with a clean pencil eraser.
  • Mount the lens on the camera.
  • Take a picture.
If the error persists, the camera and/or lens may need be serviced by a qualified Canon Service Technician.
3. Remove the 3rd party accessory.
Please remove the 3rd party accessory and replace it with genuine Canon Accessory.
4. Solution: Remove third party lens and try with Canon EF or EF-S lens.
Remove third party lens and try with Canon EF or EF-S lens This link will bring you to the camera page on Canon's website: More trouble shooting, drivers and downloads Best of luck. Could you please rate this advice. Thanks so much!
Mar 27, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon EF-S 17-85MM F/4-5.6 IS USM Lens Logo
242 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
