Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
MIELE G7859 DISHWASHER FAULT CODE
By steveharding on Apr 23, 2008
MIELE G7859 DISHWASHER FAULT CODE F26
Best Solution
posted on May 14, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had this same fault code on the same machine and managed to fix it...............Turn off the power...then take out the bottom white basket so you can see the bottom inner of the dishwasher, then take out the centre filter and remove the silver L shaped plate so you can see down into the lower white inners......(may have water in it) on the left you can see a small white double dome with a silver clip going over it.....release the clip and pull off the dome inside you will find a pump wheel check this spins freely by flicking it round with your finger......if you cant see it due to water then either feel for it or remove the water.........if it does'nt spin...free it...if it does spin easily then put it all back together and do this...... turn the control dial so it points upwards to the Hazard warning shape.........then turn on the power......wait a minute and then turn the control to the water drain symbol (arrow pointing to water) then hit the green start button...all being well you should hear the pump you've just checked spinning and pumping the water out I did this and its worked fine since p.s. the machine reset button is hidden under the 2 plates at the lower front of the machine but the screws are tricky to get to. try the pump and control part first.
Solution #2
posted on May 10, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
MIELE G7859 DISHWASHER FAULT CODE F26 anyone know what this code means and how to fix it ?
Solution #3
posted on Jun 11, 2008
Helpful)
Andy71uk
Rank: Apprentice
Rating: 88%, 2 votes
Hi .....F26 means the flood switch within the base has been activated ..........ya need to rmove base and raise of the floor and test on cycle looking for a water leak.
Comments:
Aug 10, 2008
- if the drain pump was jammed u would not get f26 but either FOA or the red warning light on the display would be on .............F26 means float in base as been activated .
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on Dec 27, 2009
Not Rated)
nightmare64
Rank: Apprentice
Rating: 0%, 0 votes
F76 Indicates that the float switch has activated.
Switch off the machine, roll it over on its side and remove the bottom panel.
Dry the inside and check all the hose conections and tighten as required.
I also drilled a hole in the base under the float switch to prevent it happening again
Was this helpful?
Yes
No
Solution #5
posted on May 28, 2009
Not Rated)
paulbn
Rank: Apprentice
Rating: 0%, 0 votes
please could you tell me what I need to do?
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
kitchen aid model number kudco31vbs is it good
Answer
we are about to buy new dishdrawer lookin fisher and paykel
Answer
i need operating instructions for a teka dw6 45fi dishwasher please help
Answer
diswasher is beeping with a f70 ...why?
Answer
I have a Kenmore 665.110729521 Dishwasher. It counts down to 42 minutes and remains there and will... (More)
Describe your Dishwashers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
