After approx half an hr being on the computer and alarm sounds this has been happening for the past week.
  • al-berto56 Nov 15, 2008
    Same problem with a friend's 5150 PC, maybe an extra fan would suffice??
  • triciabellin Jan 25, 2009
    i play wow on my desktop and its ok for awhile then all of a sudden the fan just starts going crazy and cpu shuts dowwn
    Genius:
  • 2,785 Answers
Plz check is your pc is overheating
Posted on Apr 23, 2008
Metallic clicking noise from wheel area when turning left.
This noise sounds like one of the constant velocity joints in the half shaft. The joint is probably dry or worn out and needs to be replaced.
Apr 05, 2015 | 1993 Ford Tempo
My ken wood dishwasher model number is KDW60 S12 and when I set it on cycle 1 hr for lightly soiled loads it takes approx 2and a half hours. Cheers Brad Brown
A great dishwasher! I'm not that familiar with that model but there is probably a logic(computer) board in that model that governs the cycles and it is defective. What you could try is to open the circuit breaker or turn off the power for a couple of minutes to the dishwasher. If it resets properly that may prove the problem. If it works properly after doing that it will be a logic problem and may reset. If it does work it may happen again and the board will have to be replaced. Sounds like an electrical spike (lightning or something similiar) may be the culprit. Just a good educated guess. I would be interested if you could post the outcome..
Dec 28, 2014 | Kenwood KDW60S12 Full-size Dishwasher -...
When I was driving my Honda odyssey 2004 ex last night it started to make a noise under the hood and then the van would not accelerate past 100 km/hr. After a while like 10 minutes later the noise stopped...
you developed a knock in the engine, sounds confusing but your engine computer can't separate bad bearing from pre-ignition, engine knock, to cure this your computer retards the spark, to the max to stop the knock, confuses the computer to the max
Jan 19, 2014 | Cars & Trucks
I have a 93' LT 1. for the past couple of days ive had a serious problem with my car. it was working fine on sunday, i washed it up, i needed to get the dirt/gravel out of the wheel wells (the motor...
sounds like water in distrubutor cap - pull cap and check for moisture/carbon arcing (gray lines )- engine got hot- water evaporated of back of block- got into cap thru vents on bottom- no escape when cool- repeat
May 11, 2011 | 1993 Chevrolet Corvette
1999 chrysler T & C van; Alarm system keeps it from starting!
TWO MAJOR PROBLEMS I HAVE SEEN IN THE PAST ARE THE RELAYS IN THE BCM JUST ABOVE THE FUSEBOX UNDER THE STEERING WHEEL DASH. AND THE CAR GOING INTO THEFT MODE(THINKS IT IS BEING STOLEN). HOPE THIS HELPS. LET ME KNOW PLEASE. BEST OF LUCK
May 01, 2009 | 1999 Chrysler Town & Country
Acqua Indiglo water resistant watch with alarm 30m
Press and hold the MODE button (bottom left) for approximately 3 seconds.
When the Alarm set time starts flashing, press the MODE button once more. Now the seconds for the watch time should be flashing.
Use the START/STOP button (top right) to move bewteen items and the SPL/RESET button (bottom right) to change the item.
Moving between all items, it will take you through: seconds, minutes, hours, month, date, day of the week. Simply press MODE when your settings are complete.
Jul 25, 2008 | Watches
Computers & Internet Logo
191 people viewed this question
David Payne
David Payne
