Computer monitor my hp flat screen monitor is'nt powering up again
  • 3 more comments
  • mosse Apr 29, 2008
    moniter coms on then shut of after a while
  • ted linsdell Nov 05, 2008
    Does not power up
    no power
  • Anonymous Nov 13, 2008
    XG-91D-The screen is black, only the blue LED works. I opened the unit and found two small transformers which drive the screen and these are extremely overheated. kiss it goodbye
  • Ictinus Feb 19, 2009
    How do I open my AL1914?? Took the four screws out, but couldn't get it loose.
    Thank for helping out :)
  • 2,785 Answers
Please check the powercord then power supply unit, be carefull when opening the monitor
Posted on Apr 23, 2008
Monitor comes on momentarilly, then screen turns black. when power is turned off and back on again, screen comes on for a second, then goes black again. Is this a bad monitor?
The only problem that causes the power on and off is a bad power supply. Go onto and search for the monitor (power supply). My dad's old LCD screen had a bad power supply, but I found my old printer power cable (HP PSC 750 All-in-One Printer), and the monitor turned on successfully. It's not a bad monitor, unless the PSU hookup is like the PC ATX/Baby-AT PSU cable, then it might be the issue. Monitors before 2004 or 2005 have the ones, like the HP PSC 750 uses. The monitor is either defective, or the power supply is dead.
p.s.: check the voltage, amp usage, etc. on the PSU for the monitor for better results.
Aug 28, 2009 | Gateway FPD 1730 17 in. Flat Panel LCD...
Pc entering power saver mde
This message apears when there is no input coming from your computer. There should be a bution you can puch on the monater that would cnahge it from digatail to analog this may be the problem that you are having problems with
May 21, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion F1503 1503 15in Flat. screen blanks out constantly
THis is a problem of the invertor board.If you are technically able you need to disasseble the monitor and resolder components around the red or yellow inverter transformers.
Mar 04, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
internal power supply failure in the monitor generally repair is more costly then replacement,that can be verified if you can find a tv repair shop that provides free estimates.
Dec 26, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
Power button stay on for 2 seconds, black screen,no picture
hi there, yes, you do have a broken monitor, bring it to qualified service personel how can repair the monitor. or you can just simply replace it. TY
Nov 29, 2007 | HP vs15 15"LCD Flat Panel Monitor
Hp monitor power cord
I purchased a HP Pavillion Slimline computer that was accompanied by and HP flat screen monitor: HPw1858. My problem is that the power cord is missing. Can you help me locate somewhere I can purchase this cord?
Oct 26, 2007 | HP Pavilion F1523 15" LCD Monitor
HP 15 in. Flat panel Problem
plug in a different monitor temporarily, check your display settings (right click background, settings, advanced, monitor) and set refresh rate to 60hz. plug in this monitor again and see if that helps some monitors (lcd's especially) cannot handle beyond 60hz
Aug 14, 2007 | HP vs15 15"LCD Flat Panel Monitor
Monitor screen goes black
try booting the computer in safemode you can do this by pressing f8 continuously when the computer is booting until a menu comes up select safemode. If this is unsuccessful then the monitor has a physical issue.
Aug 08, 2006 | HP Vs17 17" LCD Flat Panel Monitor
Nothing on the screen after power on
Turn on the computer and complete the following steps: Step 1: Check cable connections (If you can see the initial HP or Compaq logo screen but later lose the picture, you can skip to Step 2.) check the video cable connection on the back of the computer and on the monitor. Make sure that it is connected properly and the connecting screws are tight. Turn the monitor off and then back on again (while the computer is on) to see if an image appears. Some Flat Panel monitors have two similar power input connections placed side-by-side on the back of the monitor, which sometimes allows them to get confused for one another. One connector is used to supply power to the speakers with a separate power cord, while the other connector is used for the monitor's power adapter. Ensure that you have the monitor's power adapter cord plugged into the power connector and not the speaker connector. After you have reconnected the power cord, turn on the monitor (while the computer is on) to see if an image appears. If there is still no image, continue to the next Step. Step 2: Resetting the monitor At first setup, or under certain signal conditions, the monitor may not be able to switch to a new display resolution. Do NOT shut down or restart the computer. Instead, perform the following steps: Turn off the monitor using the Power button on the front. If the Power button does not respond, unplug the power cord from the back of monitor and wait five seconds. Plug the power cord back in. You should see the image from the computer on the screen.
Jan 05, 2006 | HP Compaq FP 7317 17" Flat Panel LCD...
Computers & Internet Logo
1,661 people viewed this question
David Payne
David Payne
