Question about Sony MDS-JE480 Mini Disc Player
Output level Hi I use this player as part of a live show (backing tracks which my band play along with) I am going direct to stereo out which has no level control and there does,nt appear to be any physical level control on the player and the disc player/stereo channel is peaking relly bad , when i go into set up i cant see any obvious way how to set the output level, could you please tell me if there is anyway to alter the output leve thank you
You need the S.F. Edit mode [Scale Factor]
Press Menu/NO ... edit menu appears
Turn AMS wheel until S.F. edit appears press 'yes'
Turn AMS wheel until 'Tr Level appears press 'yes'
Turn AMS wheel until the track number you want to change appears ... press 'yes'
You can now adjust the level with the AMS wheel
Press 'yes' 'SF Edit OK?' appears ... press 'yes' ... the deck starts to record over the existing track 'SF Edit appears ... when finished 'complete' appears.
dec@makehits.com
Posted on Apr 30, 2008
Why would the output sound level on a MP3 vary so much?
MP3 songs are recorded at different levels. Many modern tunes have been deliberately recorded loud by the record companies for maximum effect.
If you are recording the songs yourself some recording software has a "normalize" feature. This increases or reduces the volume of the track to a certain level. Especially useful when you have tracks at different levels. By the way this is how they get CD tracks to play at the same levels. So you don't have to turn up the volume or turn it down every time a new track plays.
Nov 11, 2017 | Audio Players & Recorders
My stereo plays but no sound
check for a mute button ,and check if volume switch displays volume increase when turning volume level up
Jan 14, 2014 | 2007 Toyota Camry Hybrid Sedan
Hi folks :-) I'm affraid that we have started up wrong, but I hope we can fix it ! Problem: A band, we've made a que-track (everybody's playing and singing at the same time) now we've...
Real musicians do change tempo throughout a song, so its not necessarily a bad thing. As long as you like the sound it doesn't matter if you don't stick rigidly to a fixed tempo. Unfortunately you won't be able to fix the tempo after the initial recording so you'll have to live with it or re-record. If you need a click track to record along to, try recording yourself hitting drum stick together along to the already recorded track. As a human you can track small tempo changes much easier than a computer. If you need to create a count in, just copy and paste a section of this click track to the start of the track. I hope this makes sense!
Sep 20, 2011 | Tascam 2488 Portastudio Multitrack...
How do I play DVD on the BlueRay player?
According to the Vizio website, your VBR231 CAN play DVDs the same way a lot of Blu-Ray players can. The site blurb suggests the VBR231 is backwards compatible - which means your player should be able to play DVDs as well as Blu-Ray. Generally, most Blu-ray players can play DVDs if they are backwards compatible with them.
I do know Blu-Ray discs will NOT work in most standalone DVD decks.
MODEL NUMBER: VBR231
*Model Features:
* Full HD 1080p Video Playback
* Integrated Dual Band Wi-Fi - 802.11n
* 7.1 Digital Audio Output
* Backwards Compatible (see below)
*Compatibility:
* Plays Blu-ray and DVDs, Audio CDs, MP3s and Jpegs
* Multi-Channel 7.1 Audio Output via HDMI
* Playback and Enjoy Media via back USB Input (JPEGs and MP3s)
*Outputs:
* HDMI 1.3
* Component Video (YCrCB)
* Composite Video
* Stereo Audio
* Coaxial Audio
* Optical Digital Audio
I hope that helps somewhat.
Feb 02, 2011 | Vizio VBR231 Blu-Ray Player
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Car dvd players
sory I did not see that this system will play external vieod, it looks like soumd only not video.
her is a list of specs you ca see for your self.
hope this helps you.
DESCRIPTION
N-CITY DVD-393 In-Dash Car
DVD/VCD/CD/CDRW/MP3/WMA/MP4 Player with Digital
Slot for USB/MMC/SD Memory playback
The New DVD 300 series from N-CITY comes with
everything you expect
Fully featured with Digital Media Slot for
USB/MMC/SD Memory
DIVX Playback, Sub-Woofer output & smart resume function
��. Support USB & MMC/SD Memory Card for direct playback
��.Big size Dot matrix Display
��.DVD/DVD-R+/DIVX/VCD/MP3/ WMA/MP4/CD-RW Compatible
��.Fold Down Detacheble Front Panel
��.MP3 Selection by Sequence Number & Track Name, ID Display
��.Encoder Volume Control
��.Super Electronic Anti-Shock
��.Preset EQ (Flat/Pop/Rock/Classic)
��.AM/FM/MPX PLL Tuning Stereo Receiver
��.30 Memories System (FM18/AM12)
��.Auto Memory Store
��.Repeat/Program/Random/Intro Play
��.Electronic Audio Control
��.8-Times Oversampling
��.Mute / Loud Control / Clock
��.Auto Loading and Ejecting
��. 1- Bit D/A Converter
��. RCA Preamp Output
��. Subwoofer Output
��.ISO Mouting Chasis
��. 4 Channels Output (2V Preout)
��.60W X 4 Power Output
��.Full Function Remote Control
Jan 13, 2009 | Soundstream VDVD-300 DVD/CD/MP3 Player +...
Tascam 788
The 788 can be used to play music from a SCSI attached CD-RW drive, but the record (and all other mixing functions) are disabled so you are not able to record the CD output onto a track using the SCSI attached drive.
Your options are:
1.) Rip tracks files from the CD onto you PC as wav files. You'll have rip (or later convert) those files to mono 16 or 24 bit wav files at 44.1kHz, use the old dos 8.3 naming convention for the filenames, and them burn them onto a CD-R or CD-RW as data files which can then be taken and imported into the 788.
2.) Play the CD through with an external CD player or stereo and route the output into an input on the 788. Assign the input to a track and record. Be careful to use a line level output, like an aux out (or try the CD player's outputs directly into the 788) if you are using a stereo. Avoid using a speaker output as the signal from a speaker output will be too strong and can damage the 788.
Hope this helps.
Cheers.
bd.
Oct 20, 2008 | Tascam 2488 Portastudio Multitrack...
No sound in playback (but can hear click track)
This might seem simple, but just to check: you have switched off the monitor on the track when you go to playback? With track monitor engaged, you will not hear playback, but will continue to hear the live monitor.
Sep 26, 2008 | Tascam US-144 Sound Card
Uploading audio instumentals into the Tascam 2488 II
You can get to the quick start guide here.
www.tascamgiga.com/i-738-232-128-0-BBDFF677.pdf
There is quite a bit to learn to get to the proficient point with this unit. Most of it involves the operator learning the software
Feb 11, 2008 | Tascam 2488 Portastudio Multitrack...
Sony MDS-JE480 Mini Disc Player Logo
216 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
