I have a DT 100 Sharp projector. The lamp needed to be replaced. We did that but projector will not turn on. In reading the book--after the fact-- it says that if the lamp needs to be replace (projector tells you) if you turn the projector on without replacing the lamp after the 4th time the projector will not turn on. Now how do I over ride that or reset the projector? Tried unpluging it overnight did not work I still have 20 days left on my year warrenty, but would like it to work now.
  • Paulie B Apr 24, 2008
    Thank you so much for the warranty advice. We did take it in for service and we found out that we were not resetting the lamp correctly. Once that was done it works. We were then told that we should put the old lamp back in to see if we could still use it, as the new lamps are so expensive. I was able to find a new lamp for $370.00 delivered to my door. The service person for Sharp products was wonder -- we now have our projector working with the old lamp which should get 5000 hours, at 1000 the timer tells you to replace the lamp. So if someone has a projector that is requesting to replace the lamp try to reset the timer as long as the lamp is in good shape, not blown or broken.
    Sergeant:
    Champion:
  • 319 Answers
Take advantage of warranty. Best solution in the long run
Posted on Apr 23, 2008
I replaced the lamp on my sharp dt100 projector and now it will not turn on
Have reset the lamp hours after installing the new lamp? If, not the projector has treated the new lamp as old lamp & refusing to light further. So, reset the lamp hours to zero. To reset the lamp timer do as follows. Plug the power cord into the AC socket of the projector. Switch ON the power of the socket. (not projector) While pressing simultaneously MENU/HELP, ENTER & DOWN (button near MENU/HELP) on the projector, press STANDBY/ON on the projector. "LAMP 000H" is displayed, indicating that the lamp timer is reset. If this does not correct your problem then the problem lies in other area. Let me know so that further I can provide you solution. Above things are preliminary.
Aug 06, 2011 | Sharp Office Equipment & Supplies
I have a Sharp DT400 projector. I replaced the lamp, and the unit powers on, and displays a picture during warm up but only for a few seconds. The lamp indicator and power lights go back to red and unit...
If you try to turn on the projector a fourth time without replacing the lamp, the projector will not turn on.
Press ON, INPUT, UNDO, left arrow, ENTER and right arrow on the projector in order, and then press ON.
The lamp 0000H is displayed on the lower left of the screen.
Mar 26, 2011 | Sharp DT-400 Multimedia Projector
How to replace a ballast on the sharp projector DT
Flip over the projector with the bottom up to you. you will see a panel door front right of the lens. There is one screw to be removed from the lamp panel door. There will be two holding screws that hold the lamp housing in place, remove these. grab the handle and pull up towards you thus releasing the lamp housing assy. Then place the new lamp and firmly press down and then tighten the two screws that held the lamp assy, then replace the cover.
You will then need to reset the lamp timer. by pressing the menu+enter+the arrow button between the keystone and menu button simultaneously.
Jun 05, 2010 | Sharp XR-10X Multimedia Projector
My projector blew a bulb after installation what the problem generic bulb
Hello :
Check out the Power supply to the lamp . It must not be high . . Check if the voltages are correct to the lamp's unit and it's PCB [printed circuit board]. I recommend using a service manual .
Check for manual here please :
Sharp DT-100 Multimedia Projector manual .
Here is how to replace a projector's bulb correctly :
1:Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
2:In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
3:Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
Please note that in some projectors a small inside filter should also be replaced.
4:Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
5:Reassemble the access panel, repluge the cables and power up the projector.
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
avoid touching the bare projector lamp
I hope this will help .
rate please !
Mar 21, 2010 | Sharp DT-100 Multimedia Projector
My projector suddenly stopped working
The instruction manual says that to reset the timer you have to hold down (simultaneously) the Menu button, then Enter button and the Down arrow...then press the Standby/On button on the projector. This worked the first time I replaced the bulb, but now that I've had to replace it again, its not working. Good Luck.
Mar 21, 2009 | Sharp DT-100 Multimedia Projector
Sharp DT-100 projector bad picture quality
Hi There Not sure what you visually describe as "blurry" This could be two things - a typical white screen will waste all the definition and brighteness unless you sit in a dark room Our ICE Digital Daytime Screens will take any projector and make the image up to 2000% brighter with a resolution reseolving ability of 20 million pixels. So in this case the definition you are alluding to could be lack of contrast, image definition due to insufficient light from the projector relative to the lux level of the room. Alternatively the lamp could be getting old. The brightness of a lamp falls off rapidly so as you use it more and more the image will become duller and duller contributing to a "blurry" or image lacking in punch etc.
The technical lamp hour spec life is only a manufacturers "up to xxx hours" and not what you will achieve in actual life.
If you want we are able to supply lamps as we ship internationally and also the same with our ICE Digital Daytime projection screens. Sharp DT-100 Lamp cost is $US261 delivered. Lamp Code AN-100 http://www.youtube.com/watch?v=HvZ2DlVJ790 http://www.youtube.com/watch?v=qL_44xfK9y8 Regards Kevin Andreassend ICE AV Technology Ltd http://www.digitaldaytime.com iceavtech@gmail.com +64-9-414 2348
Jan 30, 2009 | Sharp DT-100 Multimedia Projector
Projector sharp dt100 not working!
It is possible the lamp has died even though you only got 800 hours. Rated Lamp life is always up to and never a surety of those actual hours in the brochure will be acahieved. If you would like a quote for a replacement lamp let me know as we ship internationally. Regards Kevin Andreassend http://www.iceav.co.nz +0064-9-4142348 iceavtech@gmail.com
Dec 22, 2008 | Sharp DT-100 Multimedia Projector
Televison & Video Logo
217 people viewed this question
Top Televison & Video Experts
