Linksys Wireless-G WRT54G Router Logo
A
Anonymous Posted on Jul 04, 2010
Hi my office now has cameras and I would like view my office when am away where do I go to put in the static ip address and what port setting should i use.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jul 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
333
Points
5
Just simply run the CD that u get with the camera.
It will walk u through all the steps.
2answers
How to find dvr ip address
what do you want the DVRs local IP address on your LAN or your internets public IP address?
to see the local IP that the DVR is on, check the menu's in the DVR as if configured properly you should have it set up as a static IP on your LAN...
if you can not find it there, you should be able to log into your router and view connected devices... some routers are better than others, but you will probably only be able to see devices that are connected and assigned an IP address from your routers DHCP table..
if you want your public internet IP address then go to http://cmyip.com but in order to view your DVR from a different location on the internet you will need to set up port forwarding on your router - the DVR manual should show what ports need to be forwarded...
you may also want to consider using a dynamic DNS service if you do not have a static IP from your internet provider... most DVRs that I have encountered provide a dynamic DNS service..
Thanks,
5helpful
3answers
I have just installed my Uniden UDW20553 Video Surveillance System. I was under the impression that I would have remote access to view my cameras from anywhere in the world on my laptop. Have looked high...
The only solution I have found is using Remote Desktop Connection and running the Uniden application. On my Iphone I found that using Pocket Cloud Remote Desktop (RDP Itunes download application) works best. You must also download a free application named "Pocket Cloud Companion" on the PC your Uniden software is running. Pocket Cloud Companion must be running for connection to made through 3G, Edge or Wifi networks. Also, you have to configure your remote connections by using your PC's IP address rather then the name of your pc, particularly if making connection on 3G network.
Port forwarding for model number F7D5301
To setup port forwarding on this router your computer needs to have a static ip address. Or you can take alook at our Static IP Address guide to setup a static ip address. When you are finished setting up a static ip address, please come back to this page and enter the ip address you setup in the Static IP Address box below. Open a web browser like Internet Explorer or Firefox. Enter the internal IP address of your router in the address bar of your browser. If you do not know your routers internal IP address please read our How To Find Your Routers IP Address guide.
The address bar has http://www.fixya.com/AnswerQuestions.aspx#top in it. Just replace all of that with the internal IP address of your router. By default the IP address should be set to 10.1.1.1.
We do not currently know the default username and password for your router.
Click the NAT button near the left of the page.
You should now see a new menu. In this new menu, click Port Forwarding.
Enter the name of the program into the Description box. It doesn't really matter what you put into this box, but something that will remind you why these ports are being forwarded would be a good idea.
Enter the port to forward into the Public Port and the LAN Port boxes.
Use the Protocol Type drop down box to select the protocol type of the ports you are forwarding.
Enter the ip address to forward these ports to into the LAN IP Address box. If you are forwarding ports so you can run a program on your computer, you should enter your computer's ip address into that box.
Put a checkmark in the Enable checkbox.
When you're finished, click Save Setting near the top of the screen to save your changes.
And that's it! You're done!
Trying to port forward requests to the IK-WB21A webcam. From inside the house it works great. From outside, port forwarding port 8001 to 80 and I get NO response. Tried tcpdump and there is no response...
What are you using to view the Camera? Is this the only IP camera you are viewing/.accessing on the network? If it is not, are you using different IPs in the non-DHCP pool.
Typically you do not have to set-up port forwarding to gain access to the camera within the network. Normally port forwarding is set-up when you are outside your network and need to gain access to different applications/devices in your network using the same static IP address.
Let say you have a camera ip on 192.168.1.20.
You can connect to the camera with your web browser inside your network with the IP 192.168.1.20 (obviously), but if you have the camera set up to only be triggered on a specific port (other than the browser's default 80) let's say 100, then you would enter 192.168.1.20:100.
If the only thing on your network is the camera that you want to access from outside. you would setup in your router to route all incoming requests from port 80 (which is the web browser default) to the IP of the camera. Sometimes routers ask for a range just enter 80 to 80.
If the camera is working on a different port like 8001 then you would port forward 8001 to 8001 to IP 192.168.1.20. You would enter in your web browser (off-site) your static IP 69.132.54.176:8001. But I would suggest if the camera is the only thing you will be trying to gain remote access to, then leave it at 80 and set up forwarding for port 80 to the IP.
That way you can set up a free DNS service and not worry about paying extra for a static.
2answers
How do i install ip cameras so that i can see them over the internet? I have a dvr connected to my 2wire modem and I do have static ips
You need to find out what ports your ip cameras use, and then setup port forwarding on your router. If you have 1 box that controls all the cameras, you just need to forward port 80 traffic to that box. If you have multiple cameras with NO main junction box, you will need to go into the setup on each camera, and specify a port to use.
Then in the router, set up port forwarding to forward each different port, to the camera it goes with. Then when you want to see the camera from home you would type the ip address in the browser, then a colon, then the port number --> IPADDRESS:81
2answers
My problem is I cannot access my router to enter my dvr information to view my cameras on line
Get to a command prompt and type 'ipconfig' - no quotes.
You will see some ip addresses listed. The gateway ip address is the ip address of your router. Put that ip address into the address bar of your web browser and it will take you to the router config page. This is where you can do port forwarding if you want to be able to view the cameras from outside your network. Post a comment if you need any more help.
Or did you just forget your router password........or is the router not responding......let me know :)
I have a BL-C131 camera and I need to change the port number. Currently the camera is on port 50000 but this is blocked on my office firewell. how can i change the port and what port should i keep to get...
Good question. It is easy to change the port if you can actually log on to the camera. (Setup/Network(IPv4)/Connection Mode. Then choose either static or DHCP and change the port number.However, I suspect you are asking this because the office firewall will not allow you to connect to the device. Thats a problem, because this camera is a web server and you need to access it through its IP address to change its address!! I have hit this problem with another web server camera and I was able to use port 8080 in that case. What I did was set up the camera at home on my router and locked in the new port number and then used DHCP to let the work network assign a different IP address. However, many network administrators block whole ranges of ports. I presume you have tried simple Port 80? You may need to ask your network Admin what ports are open. There will always be some. I have encountered a problem recently with Viewnetcam and my IP provider...Verizon... which is blocking a whole range of incoming port numbers because their terms of service are that you cannot operate a web server on your residential network so they block all traffic that is trying to access it.
Network routing problem with Axis Camera's
They would need to be on different TCP or UDP port numbers ... in order to access them from the Internet. I'm guestimating that on the LAN you can access all of them because they are on different RFC1918 IP Addresses (e.g. 192.168.1.10, 20, 30) but same port number (e.g. port 80 for web.)
Once you hop through NAT to get to the Internet you now only have one IP Address. The real Internet IP Address. So now you have to have different port numbers for 2 or more cameras. For example use:
#1 port 80
#2 port 8080
#3 port 8081
#4 port 8082
How about that?
And you will have to forward each of those ports to the correct ip address for the correct camera.
Where's my free restaurant dinner? :-)
How view my office cameras using Linksys Wireless-G WRT54G Router
is your office camera connected to the wrt54g? do you know the ip address of your camera? the port number will come from your camera. If the camera is connecting to the wrt54g, you can open the router configuration page and input your settings there. Call linksys technical support for that. If linksys cannot help try http://technicalsupport.blog.friendster.com
Port forwarding
try to use another port number aside from 8080, like 3000 or 5000. make sure that the ip address set on the router is the ip address of your camera (note: it should be set to static).
hope this'll help you
ciao
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
