Question about Cameras
Flash My Kodak Z650 displys "open flash" even when it is open. The flash won't fire either. Do you have any help for me? Thanks for helping if you can.
It is probably the small micro-switch next to the flash-unit. You need to open the camera carefully (have the on/off switch set to favorites - it makes it easier to pry the front panel off and also when you replace it). Now, locate the small pc-board to the right of the flash-unit. You need to remove one screw and the unplug the little pc-board. The micro-switch sits directly next to a little lever on the side of the flash-unit. Take a small screwdriver and jam the switch to the "flash open" position. You can check if it's working at this time by plugging the little pc-board back in, carefully inserting batteries and setting the camera to on with your little screwdriver. You should now see the A-symbol; indicating that the flash is ready and in the auto-position. You may have to glue the switch n this position, but I didn't and t still works well. Only difference is that the flash is always on, even when it is closed, but this no real problem, as you can still disarm it manually by means of the flash-button directly behind the on/of switch.
Posted on Aug 14, 2009
  • 477 Answers
It can be repaired I have one. cost for me to repair it is 50.00 plus shipping
Posted on Apr 23, 2008
My Kodak EasyShare CX7430 Digital Camera's flash is working, but the picture's background is dark. So, there is no difference even if the we use flash or not. Please help me to solve this issue. Thanks In...
I assume there's a subject in the foreground you want illuminated with the flash?
The light output from the flash falls off with the square of the distance. An object twice as far from the camera only receives a quarter as much light. If you want your foreground subject illuminated then the background won't get much light. In order to get both the foreground and background illuminated the same, turn off the flash. This will probably require you to put the camera on a tripod or other stable support.
You might also want to consider using the Night mode. This mode uses a slow shutter speed to allow the background to illuminate, then fires the flash to illuminate the subject. See http://resources.kodak.com/support/shtml/en/manuals/urg00206/urg00206c2s3.shtml
Aug 24, 2013 | Kodak EasyShare CX7430 Digital Camera
My Kodak z650 is having flash problems. Otherwise it works great. When I go to take a picture it is way to dark, even in daylight or with a bunch of lights on. I have tried putting the flash on manually...
If the flash won't fire no matter what you do, then it's burned out or shorted out. Either way, this is not something you can fix yourself....you need service (or a brand new camera!).
Mar 08, 2011 | Kodak EasyShare Z650 Digital Camera
I am looking for a service manual for Kodak EasyShare Z650. I have a problem vith a self timer button. Thanks a lot in advance. pigy@azet.sk
go here:
http://support.en.kodak.com/app/answers/detail/a_id/18657/kw/z650
You can either view the manual online from that point, or you can click 'view as PDF' and once the .pdf file is loaded in your browser, then you can click on the diskette icon (example shown below) to save it to your own hard drive.
Nov 11, 2010 | Kodak EasyShare Z650 Digital Camera
Need to fix/replace my flash on a Kodak EasyShare
its not a good idear to strip your flash gun down inside the flash gun is a big capsitor that stores the power for the flash tube there is 1,000 of volts in it and unless its discharged first in the right way it will bite you or kill you if you get a jolt off of it, dont just short this capsitor out with a screw driver it will just blow the end off the screw driver,, like i sead, it bites!
Jan 12, 2010 | Kodak EasyShare Z650 Digital Camera
Flash does not work on Kodak z650. no damage history. What can be done?I'm fairly adept at mechanical stuff.
To correct the flash problem, please do the following:
Turn off the camera.
Install a set of new or fully charged batteries into the camera.
Turn on the camera.
Press the Flash Status button to scroll through the flash options until Fill Flash (the lightning bolt icon alone, with no other letter or symbol) is displayed. This forces the camera to use the flash.
if problem still persist contact the tech num 18002356325
Hope this will help
Thanks
Byron
Sep 23, 2009 | Kodak EasyShare Z650 Digital Camera
Kodak flash circut, need one, maybe a manual to show how to replace
Kodak will not sell the service manual or any replacement parts to non authorized contracted service reps.
Most of the fixes in these cameras is replacement of boards. They do not support component level servicing.
Jerry G.
Jun 10, 2008 | Kodak EasyShare Z650 Digital Camera
Kodak EasyShare Z650 flash problem
http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=z650+as+is&category0=
Or I have a flash circuit for 30.00 plus shipping of about 12.00 my contact info is at www.digitalcamrepair.com
Apr 26, 2008 | Kodak EasyShare Z650 Digital Camera
Flash not working
The flash circuit needs to be replaced. you can get a used one for around 20.00 off ebay. I have a few of them from salvaged units.
Apr 18, 2008 | Kodak EasyShare Z650 Digital Camera
Cameras Logo
160 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
