Question about HP OfficeJet 7410 All-In-One InkJet Printer
RJ45 Port Hi there Just purchased a HP Officejet 7140xi all-in-one unit. I want to connect it to my office network. As far as I understood, there was to be an RJ45 port on the printer to connect to my network using CAT cable. There is only 1 USB, 3 ASDL and 1 empty parrallel connector card slot at the rear, no RJ45. Can I connect to my ethernet connection with one of these or am I missing something?
You needed the network version. The model number ends with an "N".
Posted on May 02, 2008
    Genius:
  • 2,785 Answers
Without the port you cant connect
Posted on Apr 23, 2008
Will my hp officejet 6110 work on chromebook
Yes your hp office jet 6110 works on chrome book by following the below methods:
Method 1: Check system requirements
• Chrome book connected to the network with an active Internet connection.
• Create Google account in the latest version of chrome browser.
• The printer hardware is set up and connected Chrome book with a USB cable or wireless network.
USB connection: Make sure the cable is securely connected to the printer and to a working USB port on your Chrome book or computer.
Wireless network connection: On the printer, make sure the wireless signal is turned on and the printer is connected to your network. Make sure the printer is connected to the same network the Chrome book or computer connects to.
Method 2: Install HP Print for Chrome
1. Open the Chrome browser, and then go to the HP Print for Chrome
2. Click ADD TO CHROME.
A confirmation message displays. Adding the HP Print for Chrome app
3. In the Add "HP Print for Chrome" window, click Add app to confirm the new app.
Feb 01, 2017 | HP OfficeJet 6110 All-In-One InkJet...
Our hp7140xi fax maching has a error message saying carraige error close door and press enter and does not work please help
Follow this document
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00310229&cc=us&lc=en&dlc=en&product=91463
After following the document if the issue is not fixed, try this final step
1. Disconnected power cord from back of printer ( while printer is Power on)
2. Press and Hold # and 6 Button together
3. While holding the button, connect the power cord
4. Leave the #6 button after 5 seconds.
5. Follow the instructions to align the printer.
( Hopefully this should fix the issue, else consider your printer as broken unit which cannot be fixed )
If you still get the error message, Your printer is broken. Contact www.hp.com/support and enter 7140xi in product and choose chat or email to let HP know the issue.
Jun 16, 2010 | HP OfficeJet 7140xi All-In-One InkJet...
I have an HP LaserJet printer 4050N with RJ45 and Parallel Port. The Printer is kind of far from the WireLess router and I can't connect it. Unfortunately, my PC doesn't have a parallel port. The best...
Another option is to find an old laptop, with "wireless" capabilities and a Parallel Port.
Connect the printer to the laptop.
Connect the laptop to your wireless network.
Tell the laptop to "share" the printer.
Then, any computer on your network can "find" the networked printer, and can print to it.
Jun 12, 2010 | HP LaserJet 4050 Printer
Where is the battery on 7140xi
It's on the main logic pcb on the right side. You have to remove the back cover, unplug the scanner cables, remove the scanner and top cover and then the right side cover. The battery is on the circuit board on the inside side, so you have to remove the board to see it.
Oct 30, 2009 | HP OfficeJet 7410 All-In-One InkJet...
New LJ 4200N Install
simply connect the rj45 cable and create the printer using hp network printer software. you can download it from the hp website
May 30, 2008 | HP LaserJet 4300n Printer
How do i connect my printer with a usb to a Ethernet (RJ45) cable
Hi Tony,
I assumed you'd like to share the printer on network. I recommend to buy a printer server device that will connect USB port of printer and that device has RJ45 port that can be connected to router or switch hub to share the purpose. Hope this gives you an idea.
Best regards,
Rosener
Jan 31, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Network Interface
test the printer network cable for connectivity,but if the network interface fails u can use other ports like the usb port with the usb network interface adaptor to connect to the network once uve confirmed that the RJ45 network interface is bad
Dec 24, 2007 | HP Officejet 7210 All-In-One InkJet...
Scanner failure
All over the web the concensus seems to be disassembly and cleaning bulb, mirros and/or the glass and a calibration strip. Mine has the same error, and I'm gonna try the cleaning those locations. This forum mentioned a disassembly procedure for the D145, I hope it's the same for the 7100 series (7140XI) I'll post back my success.
Dec 06, 2007 | HP OfficeJet 7140xi All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
74 people viewed this question
Ben Johnson
