Question about Video Game Consoles & Games
Xbox360 4red lights flashing on console
  • 107 Answers
This is what has become the RED RING of DEATH. The console has to be sent to Microsoft for repairs. It is a fatal software issue.There are two options for you.
# 1= send unit back to Microsoft for repair
# 2= buy a new unit @ BEST BUY or Circuit City an purchase the extended warranty.
The second option is what I did after my sons crashed the first time.
Posted on Apr 23, 2008
My scooter wont go all of a sudden and the red light on the console is blinking a sequence of 4 times
Amigo Scooter Oxygen Tank Holder Light flash key turned ...
www.fixya.com > ... > Amigo > Amigo Scooter Oxygen Tank Holder
... key on my phoenix 3 scooter the red light flashes 5 times and the scooter will ...scooter wont move,although on the little speedo there is a red light flashing on ... ...light is flashing when the key is turned on. the scooter does not move at all ... flash up and down the console light and you at this point have to turn the key off ...
My pharmore wizard diagnostic light flashes 9 times and my ...
www.fixya.com/.../t25197681-pharmore_wizard_diagnostic_light_flashe...
Oct 8, 2014 - my pharmore wizard diagnostic light flashes 9 times and my scooterdoes not go, can someone help me please - Mobility Scooters question. ... Have no manual for pharmore 4 wheeled wizzard light on but wont move ... Why did it stop working suddenly and is blinking console light in 5-blink sequence?
Jan 31, 2016 | Video Game Consoles & Games
Flashing red light on the bottom right of the ring and an error code 73 picture on the screen
Hi,Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
This solution will fix your problem for sure. Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
When i turn my xbox 360 on it starts running hard then the controller lights on the device start flashing red.
Four lights around the power button flash red on your Xbox 360 console. Four flashing lights indicates that the console does not detect an audio/video (AV) cable.
Note Four flashing red lights will not appear on consoles that have both an AV port and an HDMI port.
Solution
http://support.microsoft.com/kb/906652
Mar 24, 2010 | Microsoft Xbox 360 Console
I HAVE 4 RED RING WHEN I TURN ON MY XBOX
Solution
Mar 23, 2010 | Microsoft Xbox 360 Console
What is wrong with my xbox it says error 65?
Error 65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot.
Flashing red:
1.the av cable cannot be detected
Make sure that the AV cable is correctly connected to the Xbox 360 console.
Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
2.general hardware failure
Try restarting the console.
If restarting the console does not resolve the behavior, follow these steps:
Turn the console off.
Unplug all the power and AV cables from the console.
Unplug the power cord from the wall socket.
Firmly reconnect all the cables.
Turn on the console.
If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
Also examine the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the RoL flash red.
The specific type of hardware failure can be determined by a "hidden" error code
Turn the xbox 360 on, and wait till the 3 red lights are flashing.
Press and hold the sync up button (the small white one), while holding that button press the eject button.
The LEDs will now blink the first number in the code (as described below).
Release the eject button and press it again.
The LEDs will now blink the second number of the code.
The LEDs will now blink the third number of the code.
The LEDs will now blink the forth number of the code.
The LEDs will go back to the 3 red flashing lights.
You should be able to determine the difference between the 3 flashing lights and the error code lights by the rate in which they flash.
Here is how you interpret the LEDs to get the code number:
All four lights flashing - 0
One light flashing - 1
Two Lights flashing - 2
Three lights flashing - 3
0001 power supply problem
0002 Network Interface problem
0003 Power problem could be the PSU could be the GPU/CPU, somehow the console isn't getting clean power from the power supply.
0010 over heating
0011 over heating - If you are receiving this error after disassembling your console make sure to all 8 of the heatsync screws are tightened securely to the board/heatsink holes.
0012 over heating
0013 over heating
0021 DVD Drive Time out - Can be caused by problems with a firmware flash. This is also speculated to sometime be caused by a problem with the southbridge chipset on the motherboard.
0022 GPU Error / GPU Overheating
Feb 08, 2010 | Microsoft Xbox Console
RED RING WHEN TURNED ON OFF FOR A WEEK
SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Nov 26, 2008 | Microsoft Xbox 360 Console
Three red lights
Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. CAUSE: The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. MORE INFORMATION: If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 08, 2008 | Video Game Consoles & Games
Three flashing red lights on xbox 360 console
Wow, 4th? That's horrible! Hopefully the following helps you out! SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. MORE INFORMATION loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 05, 2008 | Microsoft Xbox 360 Console
My xbox 360
Call Microsoft and send it back or go to www.llama.com to get the parts and instructions to fix it yourself.
Aug 22, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
18 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
