Question about HTC P3300 Smartphone
Problem with voice commander htc P3300
As i start the voice commander before giving any command, sometimes it automatically starts dialing any contact no or any music in the media player and sometime it does not recognize the voice tag also and dials some other contact no
  • bbatchu Oct 18, 2008
    I am using HTC touch phone, have problem with voice commander as this application is all of sudden popping up and calls r getting disconnected. Whenever I am listening music/applciation, those applications are closing and voice commander application is poping up.
    I wanted to disable the voice commander application, please help us on resolving this issue.
    Problem Solver:
  • 6 Answers
Its a common problem with voice commanders...as one cannot expect a low end processing device to process your voice with 100% accuracy...even the best of best voice processors that run on high end computers are about 80-90% accurate...I suggest you reinstall the voice commander and re-create the voice tags...
Posted on May 19, 2008
Hi, am using htc touch, wenevr i connect my headphones,which ever is the last call ,.it gets automically dialled.this is because of voice commander... PLS let me know how to disable this voice...
Hi, you can remove the voice command by using the manual for instruction. You can download the manual from the below link:
member.america.htc.com/download/web_materials/Manual/HTC_Touch_Viva/Opal_HTC_English_UM_1013.pdf.
hope it helped.
Oct 13, 2010 | HTC Touch Viva Cell Phone
How to reinstall voice commander on htc p3400
1. Contact nearest HTC service Center.
OR
2. Call HTC support - Tall free Number - 1800113377
OR
3. Find this software and install it.
OR
4. formate your mobile with factory setting for that vist: www.htc.com login & get support with your model.
with regards.
Mar 01, 2009 | HTC P3300 Smartphone
VOICE DIALING
You need to Add Voice to Contact first
for that find out the key which is works for Voice Commands.
By default if you hold Volume Up key or 1 or * keys any of these keys may work for Voice Commands.
Sort out then you will get an option enter voice command ..
let me know the result..
Regards,
Suraj.
Feb 19, 2009 | Motorola Mobility RAZR V3
I have recorded my voice dial but cannot get it to make calls. How do I use this feature
you need to train the voice command setup under _tools _voice command _Train words, then _start command then set the _command mode to normal or speed.
when you want to call someone, you will have to tap menu, tools, voice command, start command
"call someone"
or set up a softkey to go to call someone
Dec 28, 2008 | LG Cell Phones
Motokrzr k1m adding voice commands for voice dialing
You should be able to add a voice tag while editing the contact. You may also be able to simply activate voice dialing and press the voice dial button and say the name of the person and it will automatically dial for you. Try doing that.
Dec 18, 2008 | Motorola Mobility KRZR K1m Cellular Phone
Voice mail does not respond to commands from auto dialer screen
when on your phone vertically press the track ball and your keypads will show up thus allowing you to use you voicemail commands
Oct 28, 2008 | HTC G1
How do I use the voice command?
HI Con613,
Voice command is one of the feature of the mobile. It is important and if u understand it, it is very easy and useful to us.
Voice command is used to perform some sort of function (such as to open apps, camera, voice recorder, etc. and to call peoples) by giving voice command.
For it u need to go to voice command in tools in menu, then a list of apps appears. In it, u choose 1 apps, then it gives command to record voice. Record any voice of urs as command for it. When in standby mode or desktop, hold right soft key until voice command appears. Then give the same voice as recorded before to open the choosen apps.
Same process is to be applied for the apps.
For dialling people from voice command, u need to go to the person's contact. Go to options of it and add a voice as command for it. And same process is to be applied as to open the apps.
thank you
It is for mobile users.
If it is helpful for u, u can feedback me.
And i will help u later in other problems.
SAJAN
May 04, 2008 | GPS
Htc p3300 disable blocker
i rang customer services - its somewere in the regestry, i dont know where but you can access the regestry with total commander
Feb 22, 2008 | HTC P3300 Smartphone
HTC P3300 Smartphone Logo
190 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
