Question about Minolta Office Equipment & Supplies
My QMS Magicolor 330 printer just reads DISK & FLASH SYS LOADER 1.4 - how do I get it to work from this state?
    Problem Solver:
  • 6 Answers
The hard drive has crashed. You need to reload the firmware onto a new hard drive. Finding a drive and the firmware could be a problem. Look on ebay to get the parts you need. Or leave a post to let me know yopu still need help (I've got bits)
Posted on Mar 13, 2009
Magicolor 330 ex firmware
Legacy machine from Minolta they branch QMS, no longer in service, Minolta now Konica Minolta, tray below Self Help Product Support Konica Minolta Business Solutions Inc
Oct 13, 2012 | Minolta magicolor 330 EX Laser Printer
Cyan toner missing message. on magicolor 330
Firstly - remove and reseat the cartridge. If problem remains: Replace the cartridge with a new one. It is possible the new cart is faulty. If problem remains: Cart Sensor unit should be replaced as follows (If you need a copy of the service manual, contact http://www.TheServiceManualShop.com) Removal 1. Remove the Fuser Assembly (RRP 9.80). 2. Reach inside the empty Fuser cavity and slide the Cartridge Sensor Holder forward to unlatch the Holder from the printer frame (Figure 1). 3. Move the Holder around until the side latches on the Holder line up with the cutouts in the frame and the Holder is free of the frame. 4. Disconnect P/J 87 from the Cartridge Sensor. 5. Remove the screw securing the Cartridge Sensor to the Cartridge Sensor Holder and remove the Sensor (Figure 2). Replacement 1. Position the Cartridge Sensor onto the Sensor Holder so the LEDs face out. 2. Line up the position tab and screw hole on the Sensor with the two holes in the Holder. 3. Use one screw to secure the Cartridge Sensor to the Sensor Holder. 4. Reconnect P/J 87 to the Cartridge Sensor. 5. Position the Holder against the Holder cutout in the printer frame. 6. Move the Sensor wire harness so it exit through the cutout at the rear of the Holder. 7. Move the Holder around until the side latches on the Holder line up with the cutouts in the frame. 8. Push the Holder forward until the front latch secures the Holder to the frame. 9. Reinstall the Fuser Assembly (RRP 9.80). If the problem remains, then the MCU PWB will need replacing. This could put the machine Beyond Economical Repair.
Jun 12, 2007 | Minolta magicolor 330 EX Laser Printer
There's a message appeared the minolta qms 9100 "disk & flash loader v1.1" what does it mean.. and pls. help to fix my minolta qms
Your soft ware that one the machine mite be corrupted. I don't know where you would go to get it firmware reloaded it is a Minolta Legacy machine using windows 95 or xp at best. Try konicaminolta web site.
Jun 03, 2011 | Minolta QMS PagePro 9100 Laser Printer
1. Disk & flash system loader v.1.0.1; 2. Verifying image; 3.Jumping to SYS entry point.
HI GUYS,
I GOT SAME PROBLEM WITH QMS PAGEPRO 9100, BUT IT DOSE NOT HAVE HARD DRIVE, AND I TRIED TO RESET BY DISSEMBLING THE WHOLE MACHINE BUT WITH NO LUCK, CAN ANY ONE HELP TO RESOLVE THIS ISSUE STILL LOOKING ALSO FOR FIRMWARE TOO BUT NO CHANCE TO FIND IT.
Jun 01, 2011 | Minolta QMS PagePro 9100 Laser Printer
NAND FLASH ROM ERROR IA CODE CHECK SUM
you need to update the firmware here is the link http://www.fixya.com/ftp://ftp.minolta-qms.com/pub/drivers/other/MC2490MF/
install the printer and SCANNER driver via usb
Mar 15, 2011 | Konica Minolta magicolor 2490MF Laser...
Minolta QMS printer service manual
Here is the Technical Manual (click here)[QMS Magicolor 3300], you can read it in your browser or you can download it, click "Download (9MB)" to download the file. It's a pdf file, you'll need a pdf reader to read the contents on your computer. Download Adobe Reader here (click here).
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Oct 03, 2010 | Office Equipment & Supplies
Minolta Pagepro 9100. The control panel seems to be stuck in a loop at initialization. It shows the following; 1. Disk & flash system loader v.1.0.1 2. Verifying image 3.Jumping to SYS entry point. It...
sound like the printer operating system failed nothing to do with drivers get a Konica Minolta tech out to look at it, mite be able to get a firmware from secured web site to re flash the machine.
Feb 28, 2010 | Minolta magicolor 3300 Laser Printer
Problem w/3300 laser printer
Take the unit out right away and reseat it again,repeat if nessecary.
Oct 01, 2008 | Minolta magicolor 3300 Laser Printer
Printing issue
In order to proceed with the solution to your problem, we'll need to save the current settings on your Crown printer and then restore the printer to its original factory settings as shipped. Your current settings will be saved, and can be restored after we finish this troubleshooting session. You will need to access the printers front panel in order to perform the following settings.
Procedure to save your current printer settings
Procedure to restore printers original factory settings
Procedure to restore your saved printer settings
1. Make sure the Online light is lit and that the display reads Idle.
2. Press the Online/Offline button to take your printer offline.
3. Press the Menu button once. The display should read Operator Control.
4. Press the Right Arrow button once. The display should read Administration.
5. Press the Select button once. The display should read Communications.
6. Press the Left Arrow button until you see Miscellaneous in the display.
7. Press the Select button once. The display should read Save Defaults.
8. Press the Select button again. The display should read No.
9. Press the Left Arrow button once. The display should read Yes.
10. Press the Select button.
11. A few seconds should pass until the display reads Yes Is Selected.
12. Press the Online button twice to take the printer online while the display reads Idle. Your current printer settings are now saved and you are ready to proceed with returning the printer to its original factory settings.
6. Press the Left Arrow button until you read Miscellaneous in the display.
8. Press the Right Arrow button. The display should read Restore Defaults.
9. Press the Select button once. The display should read Factory Defaults.
10. Press the Select button again. The display should read No.
11. Press the Left Arrow button once. The display should read Yes.
12. Press the Select button. Yes Is Selected will appear in the display.
13. A few seconds will pass and the printers display should read Disk And Flash Sys Loader.
14. Your printer will reboot with the original factory settings and return to Idle.
Try a test print. Does the problem still exist?
10. Press the Right Arrow button. The display should read Custom Defaults.
11. Press the Select button. The display should read NO.
12. Press the Left Arrow button once. The display should read Yes.
13. Press the Select button. Yes Is Selected will appear in the display.
14. A few seconds will pass and the printers display should read Disk And Flash Sys Loader. Your printer settings are now restored to their original saved settings
Try a test print, does the problem still exist?
Sep 24, 2008 | Minolta magicolor 3100 Laser Printer
188 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
