2000 Ford Taurus Logo
A
Anonymous Posted on Jan 25, 2018
I have a 2000 Mercury Sable my a/c is blowing hot
I have a 2000 Mercury Sable my a/c is blowing hot air when on ac Max or set to 60 I have replaced the Blend Door Actuator motor i have check all the fuses i have disconnected and reconnected the battery when I cycle the temperature from high to low I do not see the blend motor moving
Rick M
Level 3:
  • Ford Master 4,148 Answers
  • Posted on Jan 25, 2018
Rick M
Ford Master
Level 3:
Answers
4148
Questions
0
Helped
1253289
Points
13941
If the blend door isn't moving then you've got a wiring harness or control head issue.,
toddgilbert
Level 3:
Top Expert:
  • Ford Master 6,360 Answers
toddgilbert
Ford Master
Level 3:
Top Expert:
Answers
6360
Questions
5
Helped
1524546
Points
27737
2000 mercury sable
Try this link here, it's very helpful in repairing your vehicle
5 Related Answers
harley9701ha
Bill
  • 424 Answers
  • Posted on Jan 26, 2009
SOURCE: Temperature Control not working on 1999 Ford Explorer
Sounds like your temperature actuator is not moving or your temp door is broken. On max a-c ,coolant is shut off to your heater core allowing only cold air in.
Anonymous
  • 5 Answers
  • Posted on Oct 06, 2009
SOURCE: Why, after changing the blend door actuator, does
Check all the air hose up to that point look to see if all hose is intack and put to gether right look for holes and cloges
Anonymous
  • 5 Answers
  • Posted on Dec 07, 2009
SOURCE: how to replace blend door actuator in a ford
I recently did mine, I hear you can do it without taking the entire dash apart but I had no luck with it myself. I have to get ready for work but, on mine it was located down and to the left of the radio. its a white box...are you hearing a clicking noise or something? I had to roll the entire dash back and it was still a major pain getting it out.
Manuel Cepeda
  • 3 Answers
  • Posted on Jan 24, 2010
SOURCE: 2001 FORD EXPEDITION XLT 4.6L V8 BLOWING MILD WARM
You hot air comes from the water circulated through the heater core. It is like a miniture radiator with water flowing thru it constantly. So by opening the "Blend Door" you are permitting so much of this hot air to pass thru.
Seems like for some reason your heater core is plugged up. Just like a radiator can be. So water may be passing through your heater core but not passing through fully. Your heater core gets hot from water passing throught it from the engine. Then your doors open up, in proportion to how much air is permitted to pass over the heater core.
Suggest to remove the heater core and replace it. Seems the blend doors are working properly but again, if you have a non working heater core then no air can pass over the "Hot Core" for you to recieve hot air.
If you are not mechanically inclined, then go to a local parts store and you can buy a car manual, such as Chilton's or Hane's Car manuals, for your year and make to show you how to replace it. Then you can also have it for any other problems that may arise.
Anonymous
  • 5158 Answers
  • Posted on Nov 27, 2010
SOURCE: 2002 Ford Crown Vic 4.6L. EATCM A/C, Heating
that clicking noise you hear is likely a relay in the fuse panel that needs to be replaced. the easiest way to find out which relay it is would be to put you finger on each relay as you actuate the device not working. once you locate the clicking relay replace it . to reset the computer just unhook the battery for about ten minutes. if you have an anti theft radio make sure you know the code for it and how to enter it before you unhook the battery.
robert
No heat or defrost in my 2000 mercury sable
If you are referring to the air won't blow through the defrost vents or on the floor, you may have a stuck or broken blend door actuator. This part diverts air through the different settings: defrost, vent, floor etc. If you aren't getting warm or hot air regardless of the settings, you may either be low on coolant or have a bad thermostat.
My ac just stopped the fan is blowing hot air 2000 merc. sable
is a/c clutch engaging on front of compressor under hood? And does it kick out after 30 minutes?
Could be a/c clutch.
1helpful
2answers
Can a belt be purchased to by-pass the air conditioning pump in a 2000 mercury sable? the pump is bad and I don't want to use the AC anyhow.
no they did not use a different belt, there is a bypass pulley where the AC pump sets now, just order the AC delete
pulley, not very expensive, u will need to remove the old pump. You can also go to the link to buy the pulley you need.
http://www.1aauto.com/1A/ACBypassPulley/Mercury/Sable/-/-/2000
1helpful
I have climate control on my 2001 Sable. I had my battery replaced today , of course all the electrical in the car went out. When I got in the car my air was off I turned it on it only blows very hot...
try disconneting the battery. take the 2 battery cables and touch them together. Now connect them to the battery, turn key on for 2 minutes, now start car and see if a/c works.
1helpful
2answers
Air conditioning doesn't work. only blows out hot air
Check and see if the clutch on the front of your compressor engages. If not it could have a leak and not have any freon in it. If it has freon then you have an electrical malfunction on the ac system.
10helpful
2answers
AC blows hot air but AC compressor works
if the compressor works and your freon is charged it may be the blower flapper door....disconnect battery for 10 minutes and then re-connect to reset the electronics that control the flapper
2helpful
2answers
2000 Mercury Grand Marquis will only blow hot air when ac is on. The ac system does work lines get cold but will not blow nothing but hot air. Has automatic climate control system. Will direct air from...
needs re-gassing because one line should be hot (feed) and the return cold , This is a specialist job do not attempt to do it yourself because its extremely dangerous with very high pressures involved
AC still blows hot air
CYCLING COMPRESSOR COULD MEAN TOO MUCH OR TOO LITTLE FREON.TAKE IT TO AN A/C SHOP
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
