Question about Logitech Trackman Marble FX Trackball
Everytime I turn my computer off or restart I have to reset my trackball back to left hand setting. How can I stop this form happening?
    President:
  • 2,712 Answers
Hello cathyfry9091,
First, make sure you have downloaded and installed the latest version of MouseWare for your trackball. You can do that from HERE. Just choose your operating system and proceed to download the software.
Please see THIS utility as well, It is called MouseWare Advanced Setting Utility and if you scroll toward the bottom of this page, it tells you how to keep right/left button swap assignments. This article also shows you how to install the utility.
Should you have any further questions, please feel free to post them here.
P.S. Before you assign a rating, please make sure that the issue is resolved or you are satisfied. If not, please post back as to what you did, and/or any other questions you may have, and I will try to assist you as best I can. Please do not assign an ‘Inappropriate’ or ‘Thanks for trying’ rating if your issue is not resolved after the first response itself, as sometimes a bit of to and fro dialogue may be necessary before we can find a fix or an answer to your query.
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! or Helpful rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
"Discover How to Achieve Your WILDEST DREAMS"...Free Download
FREE SOFTWARE GIVEAWAY
Windows Utilities - Software Street
Posted on Apr 23, 2008
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    post them here.
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
TFT-5600 RKM Trackball not fully functional
Trackball? Think on these computers that there should be a small ring around the outside of the trackball. This ring turns? quarter or half turn then you can remove it and gain access to the inside rollers where the ball sits. Clean the rollers out and then put it back together and ytou should be good for a few more months. then just repeat when the problem gets to bad. Remember this is all "I THINK" Hard to remember back that far.
Dec 15, 2012 | Compaq TFT 5600 RKM - 15 w/ Keyboard,...
I took out the battery and place it back in, now there's a lil black clock showing off an on then disappears. When i flip the phone open app ERROR 523 and Reset shows up on the screen
How to Reset a Blackberry
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information before hand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry Below.
software112.com/products/blackberry-desktop-software.html
Hope this Tip helps. If so please do leave a vote for the solution.
Thanks.
May 23, 2011 | RIM BlackBerry Pearl Flip 8220 Cellular...
Need Drivers for a Nexxtech RF Wireless Optical Trackball \ Model # 2616533. I have plugged the USB receiver in to my netbook turned both trackball & receiver on all lites turn on on both components,...
You may need to go into the computer settings and find the mouse settings and do the "test" functions.
You may need to restart your computer with the mouse already connected and see if that helps.
Feb 12, 2011 | NexxTech Computers & Internet
My BB Bold 9700 Does not respond with the soft reset
There are three ways you can reset the black berry phone.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry right here.
Nov 23, 2010 | RIM BlackBerry Bold 9700 Smartphone
RESET APPLE LAPTOP
You can either do a soft or hard reset. If u find no go even after the reset, You can reinstall the OS if i like to do so.
Soft reset
  • Close all applications.
  • Click on the apple in the upper left-hand corner of the screen. Select "Restart" from the menu.
  • Press restart button located on the upper right-hand corner of the keyboard. Your computer will turn back on.
  • Hard reset
  • Press the power button located in the upper right hand side of the keyboard, just above the eject button.
  • Continue to depress the button for 10 seconds. The computer will power off.
  • Press the power button again to turn your laptop back on.
  • Oct 09, 2010 | Computers & Internet
    Blackberry 8900 can't open messenger
    Hi, you can and reset the phone.
    Sep 26, 2010 | RIM BlackBerry Bold 9000 Smartphone
    When i turn on my blackberry curve 8520, it says app error 523 and has a reset option... but when i click reset it takes me back to the same thing
    Hi, there are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
    Thanks.
    Sep 16, 2010 | Cell Phones
    Blackberry 9000 smartphone - says bluetooth disabled - and when go into options to enable bluetooth - the screens says enabling bluetooth but nothing further happens
    Hi, reset phone after resetting phone if nothing happens,Go to blackberry sites for update.
    Thanks.
    Aug 25, 2010 | RIM BlackBerry Bold 9000 Smartphone
    My blackberry bold 9700 has an error message 102. This happened when I rebooted the device after a software upgrade prompted by a blackberry message. How can I sort this out?
    Thanks.
    Jun 28, 2010 | RIM BlackBerry Bold 9700 Smartphone
    Logitech Trackman Marble FX Trackball Logo
    69 people viewed this question
    Top Logitech Computers & Internet Experts
    micky dee
    Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
