Question about HP LaserJet 3000n Printer
HP CLJ 3000
Print cartridges jammed on the right hand side ?flaps do not move
  • 22 Answers
Down near front, hinge which front door/transfer belt pivots on also moves a vertical bar (inside left?) up + down to release cartridges/open flaps. There may be a linear gear meshed with a round gear down in the left side. everything has to be meshed and start from home position to work properly. follow the mechanism from the hinge(s) to see where it came loose.
Posted on Jul 06, 2008
  • TRANSCORP99 Jul 06, 2008
    Or right swing guide problem. Fairly complex mechanical issue. You'll need a manual. I'm a little mixed up between the various models (left hinge 3700? right swing arm3500?) here. Sorry.
    Genius:
  • 2,785 Answers
Your printer needs servicing
Posted on Apr 23, 2008
Printer only prints on left hand side of paper. Toner cartridges have been checked and replaced the Cyan cartridge since it was leaking. I also replaced the fuser and I am still having the same problem.
Other than tec guy are not advisable to do this exercise :Corosol align distrubed,open the printer up to corosol mechanism check rotary swing shoft left and right gears, there are markings which was exatly matching with rotary right & left disc markings. If its distrubed print quality issue will comes.
You are facing the same complaint. Before opening the machine ensure that read carefully service manual hp clj 2820/2840.. Best of luck.
Sep 07, 2011 | HP LaserJet 2820 Printer
Jam cartrige Area
Clear jams from the print-cartridge area
1. Open the print-cartridge door, and remove the print cartridge.
Figure 18: removing print cartridge
2. With both hands, grasp the side of the media that is most visible (this includes the middle), and carefully pull it free from the product.
Figure 19: removing jammed media
3. Replace the print cartridge and close the print-cartridge door.
Figure 20: reinstalling the print cartridge
For any other Jam types Visit the following link : HP Lasterjet M1522
Regards,
Shrey
May 30, 2011 | HP LaserJet M1522nf Multifunction Printer...
I am currently getting the message that the cartridge is jammed and there is no papaer in the printer. Theres no obstruction for the cartridge, it slides across easily manually, just jams when printing. It...
First of all please check inside of the printer. You have to look for any piece of paper, paperclip or something like this. Then, please remove your printer cartridge and try to print with another one. There is an option that your printer "FUSER FIXING FILM" is damaged and that's why the paper sticks in that place. You have to find a skilled person for further assistance.
pif
Feb 19, 2011 | HP LaserJet 1000 Printer
It says paper jam but we do not see any paper anywhere
did you switch the machine on and off
one of the paper sensors may be stuck pr damaged
Feb 14, 2011 | HP Officejet Pro 850 InkJet Printer
Printer says "Open Door Clear Cartridge Jam" How
You might wanna try removing and reinserting the cartridges and make sure that they are properly fitted in.
Sometimes cleaning the cartridge and the carriage where you took out the cartridges from with a damp lint free cloth does the trick.
If you still have that message, open the cartridge access door.
If the carriage is stuck at the right side of the printer, move the carriage to the left side by hand. If it's stuck on the left side, try moving it by hand in the right side of the printer. Then while the printer is turned on, unplug it from the wall outlet and then plug it back in.
If the printer does not turn on, use the power button.
Try printing again.
Feb 03, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Printer displays 10.002 error
10.000x Supply error E-label cannot be read or print cartridge is
not properly installed.
10.0000 = Black print cartridge
10.0001 = Cyan print cartridge
10.0002 = Magenta print cartridge
10.0003 = Yellow print cartridge
1 Reinstall print cartridge.
2 Turn on the printer.
3 If the problem is not solved, replace the
cartridge.
Dec 24, 2010 | HP Color LaserJet 2600n Printer
Ink cartridge cradle will not move from right hand side
on right hand side there is adjusment lever just press it . this will move the cartridge
Feb 07, 2009 | HP DeskJet 970cse InkJet Printer
Cannot remember how to load new print cartridge on to my HP Photosmart D5160 series printer
keep the printer ON.then open the flap on the front side.there is a small gap made in the flap to get it opened.as u open the flap the cartridges will automatically move and come in the position where u can remove the cartridges.just pull the cartridge to the dwn side near to you and it will come out.in the same way insert the new cartridge.
Nov 30, 2008 | HP Photosmart D5160 InkJet Printer
Printer not printing says to see user guide unable 34
i had this problem, paper was jammed in between printer cartrage and the right wall ( when lookin at it from front).
open top flap of the printer, u will have access to the cartrage (the thing that moves side to side whilst printing) move that to the left and have a look on the right hand wall. you should see quite a bit of paper jammed up in that area, make sure u clean throughly, get a torch if psooible, close flap then ure eon ure way
Sep 12, 2008 | Office Equipment & Supplies
HP 7660 "Print Cartridge Cradle is Stuck" Message
I was having same problem but it was a paper jam all the time and then it started to state Cairrage Jam. And what was happening was the unit the cartridges sit in was not going all the way to the right. A little nudge and you could feel it move. Closed lid and sometimes it would print but eventually it would fail. Just replaced but I suspect if you can get to the cairrage you could clean/repair whatever was keeping it from going all the way to the right.
Hope that helps!
Dec 18, 2007 | HP Photosmart 7660v InkJet Printer
HP LaserJet 3000n Printer Logo
70 people viewed this question
Ben Johnson
