I have a HP 4250 Printer. You on power button - it will not print - It only generates a 51.10 error code. What is this error coded telling me and how do I correct it. At present I have had to replace it with a Lexmark 4510 in order to keep the workstation in operation.
    Scholar:
  • 75 Answers
this error sounds like a Beam-detect error on your printer, in this case i would suggest If the message persists, contacting your nearest HP Customer Support location.
what you could try is:-
  1. Press the (Select) button to continue.
  2. Turn the printer power off and then turn the printer power on.
  3. then try printing again..
Posted on Apr 23, 2008
    Genius:
  • 2,785 Answers
Dear garthe
the error generally means temporary printing error,to solve this try by switching off then on if the problem persists then your printer needs servicing,contact hp or your vendor.
thanks for contacting
    Brigadier General:
  • 6,966 Answers
Hi garthe,
With the indulgence of Basti ....
To my understanding, error 51.1 indicates a failure in the laser/scanner commonly causing laser beam detection problem. This could be the laser it self, the DC servo controller or often just the reflector assembly. In most instances, the problem could be corrected by cleaning of the some internal parts. This error problem has been attended here at FixYa. Pls refer to this posting and solution.
Additionally, some have reported solving the problem by tightening the laser connectors.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
    Genius:
  • 1,447 Answers
Lets check the hardware first if its working as a stand alone
To test the printer in "standalone" mode, perform the following:
  1. Turn the printer off and unplug any parallel cable from the printer.
  2. Unplug the network cable (if applicable) from the HP Jetdirect card (if equipped) and then remove the card from the formatter.
  3. Power on the printer.
  4. After the printer reaches a Ready status, print the following test pages:
  • Configuration page or Self Test page (list of installed options)
  • Event Log (list of most recent printer events to aid with troubleshooting)
  • Menu Map (lists Printer settings)
  • 3 more comments
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Apr 23, 2008
    try to check errors here as well
    http://h20000.www2.hp.com/bizsupport/Tec...
    By the way how do you connect printer to network? what type of cable are you using, and where are you getting the error message? on the control panel of printer or on computer?
    Here's the link for the error
    its all the way down the page, turn it off then unplug it from power supply and unplug cables at the back of it as well, then repug all cables and turn it back on.
    What exactly happened before this issue occured?
    here's the error.
    Error 50 (fuser malfunction)
  • HP II/III series most likely cause is the ac power module
    is defective. Order the HP II/III Service 50 Error Repair
    Kit Quartz fuser lamp is burned out. Order the replacement
    fuser on specials page. Slight possibility of loose connector
    on DC controller. See tweaking page DC controller could also
    be defective, but this is very rare.
  • HP IIP/IIP+/IIIP most likely cause is burned out quartz
    lamp. Order the HP IIP/IIIP 50 Service Error Repair Kit. Could
    also be a failure of the power supply.
  • HP 4/4+/5 most likely cause is burned out quartz lamp. Order
    the HP 4 Service 50 Error Repair Kit. Could also be a failure
  • 4L/4P/5L/5P/6L/6P most likely cause is a bad ceramic heating
    element.
  • All other printers most likely cause is burned out quartz
    lamp. In rare instances the ac power supply has failed. Even
    rarer, the DC controller is defective.
Model 4225 shows error code only
'Ink System Failure,' or a '0x...' - HP Customer Support
support.hp.com/us-en/document/c03081973
Example: "Laserjet P1102w driver" or "HP Pavilion 17-f002na will not turn on" ... For example, 'Error 0xc18a0001' or 'B8000094' might display on the printer ... The error code or message is not 'Problem with Printhead,' 'Printer Failure,' or 'Ink ...
[PDF]hp officejet 4200 series all-in-one user guide
www.hp.com/ctg/Manual/c00095626.pdf
Hewlett?Packarduse the attached handset (hp officejet 4250 series only) . . . . . . . . . . . .50 answer incoming calls ..... Help button that appears on some error messages and in the. Troubleshooting .... a call waiting (handset model only). 9. Photo Fit to Page: ...
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
Dec 18, 2015 | HP Office Equipment & Supplies
Hp 4250 error code 55.4
error code 55.4 on HP Laserjet 4250:-The dc controller is not communicating with
the formatter. The problem could be caused
by a timing error or an intermittent
connection
Repair:-
switch off the unit - disconnect power cord
unsrew the two screws holding the formatter in place
( silver plate to rear right)
remove the plastic side panel by sliding
remove the formatter ( silver box you just unscrewed) by sliding toward the rear.
reinstall the Formatter
and re-test
more often than not just reconnecting the controller is enough to clear the problem. theres a good chance it has moved out of position as time has gone by.
Jan 22, 2013 | HP LaserJet 4250n Printer
How to clear error code 49.4c18 on HP laserjet 4250
any 49.xxxx codes are related to firmware crash.
the probable cause is a corrupt file in the print queue. remove the printer from the network then after network is disconnected - cycle the power on the machine ( switch off then wait 10 seconds switch back on)
the 49 error will probably clear . if so Clear All print jobs in Print queue on the computerr workstation. then reconnect printer and away you go!
if however the error remains then you will need to Upgrade the firmware or replace the firmare chip/formatter ( unlikely I've only ever replaced one out of thousands of calls for this fault)
Nov 04, 2012 | HP LaserJet 4250n Printer
Error 50.1 hp 4250 printer
This is a fuser error, it could be a faulty thermal sensor on the fuser but can also be caused by a faulty power supply.
This model commonly has dry joints in the power supply which can be fixed depending on your level of skill.
Mar 02, 2012 | Office Equipment & Supplies
Maximum file size for printing on the hp color laserjet 5500n - having issues with pdf files
If you are getting 49.XXXX error codes while printing PDF files, you can try upgrading the machines firmware.
This seems to be a common "PDF file printing" problem with the LaserJet 4250.
Oct 25, 2010 | HP Color LaserJet 5500 Printer
My hp 4250 laserjet printer displays an printer error 57.4 message when i switch it on. what could be the problem? since it can not continue the printer checkup progress.
<P><A href="http://www.printertechs.com/tech/error-codes/error-codes-index.php">http://www.printertechs.com/tech/error-codes/error-codes-index.php</A></P><P>&nbsp;</P><P>Plz check the the link for the detail error codes.</P>
Aug 28, 2010 | HP 4250 Monochrome LaserJet Printer
59.40 error code
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
Aug 20, 2009 | HP 4250 Monochrome LaserJet Printer
Error code 59.40 on laser jet 4250
Do you mean an HP 4250. If memory serves me right that error number refers to the main drive or cartridge drive. You may have broken the gear on the cartridge while installing it. Especially if your the type to slam it in there. It can happen with genuine and remans so don't go bemoaning reman cartridges...lol. Turn it off...put another cartridge in there...and see if if boots up. I work on printers for a living and had( I'm 95% sure ) that same error code a couple of weeks ago and fixed it for the customer over the phone this same way.
Mar 24, 2009 | Office Equipment & Supplies
Printer stopped printing durring project "Assert Error b52b00b4"
From the HP website:
ISSUE: The printer displays an assert error code. Assert error codes indicate that the printer has an internal condition that may respond to a hard reset of the printer. Beyond that, service may be required. This document applies to the following products:
  • HP Photosmart p1000/1000, p1000xi printers
  • HP Photosmart p1100, p1100xi printers
  • HP Photosmart 1115 Printer
  • HP Photosmart 1215, 1215vm, 1218, and 1218xi printers
  • HP Photosmart 1315 Printer
SOLUTION: Hard reset of the printer A hard reset of the printer may clear the error. Here is how to perform the hard reset:
  1. Shut down the computer.
  2. Open the top cover of the printer and remove the print cartridges.
  3. Close the top cover of the printer.
  4. Press the power button on the printer to turn the printer off.
  5. Disconnect the communications, (USB or Parallel), cable from the back of the printer.
  6. Disconnect the power cord from the back of the printer for one minute.
  7. Reconnect the communications cable to the printer.
  8. Reconnect the power cable to the printer.
  9. Press the printer power button to turn the printer on.
  10. Open the top cover and reinsert the print cartridges.
  11. Close the top cover and print the calibration page.
  12. Restart the computer.
Mar 18, 2009 | HP PhotoSmart 1115 InkJet Printer
My computer tell me that my printer as a error code 20
Error code 20 in HP printers usually means you are trying to print to a non-default printer. try setting your D7200 as the default printer. Here is the direct link to HP about your problem:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00759728&jumpid=reg_R1002_USEN
Jan 07, 2008 | Office Equipment & Supplies
115 people viewed this question
jasbo
jasbo
