Question about Panasonic SA-HE7 Receiver
Overloading the amplifier isnt connected to anything just plugged into the mains. once turned on it clicks like 3-6 times and then saysoverloading please could you help thanks matt
Hi mate, ive had the same problem before with this amp. i bought it new aout 6 years ago and bought another new one about 1 year ago, new, for £70!
on the first amp there was a problem with the surround sound aspect, it kept overloading when turned up even a fraction, it would tick 4 times and power off. Eventually the surround sound stopped working all together and whenever selected made a VERY VERY loud hissing/crashing noise through all my speakers, blowing one of them, SO BE VERY CAREFULL.
when that happened i assumed was broken so bought another one, and had same overload trouble when i got a new speaker package.
Im pretty dam sure it was the ohmage ratings being different on 2 of the surround sound speakers that srewed the 1st one, so id suggest you check theyre all ok, as well as the speaker watt-age.
what are the specs on all your speakers (ohms and watts RMS)??
do you listen to LOUD music through the 5.1 option??
hope this helps, if all else fails buy a new one mate, theyre so cheap. go into panasonic shops and see if they have any left.
Posted on Mar 24, 2009
  • theslim01 Mar 24, 2009
    whoops, just noticed you said youi have nothing connected?? wow that is strange... cant you take it back? or was it ebay or something??
    what does it say when u press the "help button?" if i remember this is by the left hand side next to the "spakers" button
Technics stereo Integrated Amplifier SU-G75 powers up few seconds then overload light appears and a clickng noise coming out of metal boxq with tag FP-3 M V RTP1P5C015 on it iis it supposed nto make c
If the receiver works at low volume, but goes into OVERLOAD and shuts down at higher volume, it means you are player the unit too long and too loud. Try yo keep the volume down to a reasonable volume.
Nov 15, 2014 | Audio Players & Recorders
Without any audio source or speakers on output attached, the Crown CH1 Amplifier (as soon as you put the on/off switch to the ON position, the CLIP light blinks a couple times and the FAULT lights blink...
It's very likely that the main power amp section has a faulty part on it that is presumably causing an overload. You should check the devices on the main heat sink of the amp section.
Oct 11, 2013 | Crown CE1000 2-Channel Amplifier
RX9010v overload message on powerup
Check your speaker connections to see if anything is touching -shorting- If no difference you might have damaged a semi-conductor located on the main amp board, or on the heat sink.
Mar 28, 2013 | JVC Audio Players & Recorders
What causes cracking, popping sounds on most zones of a MZC 66 amplifier controller?
Try this to isolate where it is coming from. Either the zone amps are defective, which is not likely, or the main amp is at fault. Hard to believe they are mis-wired, they typically are foolproof in this area.
At the main controller, try the two zones that are good and plug them into the 4 bad zones one at a time and see if you get the same symptom. If you do, then it is not the main controller and something common to the 4 zones is causing the issue. If they are wireless, then you my have interference so check if you can select different channels.
e
Nov 08, 2011 | SpeakerCraft MZC-66 Amplifier
I have "cooked" (i think)
When the fuses blow like that suspect an overload in either the power supply or main amp stages. I think you might have damaged one or more of the output devices. They can develop faults quick if you're using the wrong type speakers or have faulty wiring to them. The main cause of fuse blowing is a semi-conductor device that is acting like it is a piece of wire. For instance an output transistor when connected to a multi-meter on the ohm scale, will show a full scale deflection, just like if you had touch the two test probes together.
Nov 20, 2010 | AudioSource AMP-100 2-Channel Amplifier
The fuse keeps blowing in my amp, changed the fuse several times but just keeps blowing!!!
You have an overload in either the power supply section or Main amp section. Culprits in the power supply are the transformer, the Large Capacitors, rectifier, voltage regulator.
In the Main amp anything on the heat sink.
Look carefully for burnt or damaged parts. If there's more than one fuse, follow the path of the one that is blowing it might lead you to the suspect.
Dec 15, 2009 | Alesis RA-150 Amplifier
Fridge/Freezer keps turning itself off
Pull the refrig out and remove the back panel . If the fan motor , cooling the compressor is working , then the overload/relay is bad . This is the piece plugged onto the compressor , with 2 or 3 wires attached to it . You can easily replace . If you had given the brand and complete model number , I could have given you the part number .
If the fan is not running , the overload will click off , thereby , causing the compressor to get too hot , making the overload click off .
Sep 27, 2009 | Refrigerators
Same problem
The overload indication tells us that there is a problem in the final stage of the amplifier section. This model uses an AMP-PAC or large amplifier IC (part number RSN-3305) which is now defective. If you can solder, try resoldering the pins on this IC. Sometimes a poor solder connection can cause a voltage offset that will be detected as a fault and shutdown the system like this. If the resoldering fails, the IC will need to be replaced. Parts cost will be in the $75-$95 range.
Dan
Sep 14, 2009 | Technics SA-AX720 Receiver
Alpine MRP M450 Problem
Sounds like it is getting too hot and a thermal overheat protection switch is shutting it off. Check to make sure your gain isnt over 3/4.
Dec 05, 2007 | Alpine MRP-M450 Car Audio Amplifier
On and off switch
This is the thermal overload for the amplifier section. unplug unit and check all speaker connections for a crossed wire. After all connections are checked and are in good condition, plug the amp back in and power up. Note: the polarity of the speakers when the wires are plugged in. Use the painted line on the speaker wire as a guide for which one is positive(+) and negative (-). If an amplifier is operated out of phase for too long ( positive and negative reversed), you can damage the amp. A bad speaker coil can cause the overload as well. If it still does it, disconnect all speakers and power it up. If these remedies do not solve it, you amplifier IC is shorted and needs replaced.
Apr 10, 2007 | Kenwood AR-304
Panasonic SA-HE7 Receiver Logo
359 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
