Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
My Sony Trinitron shut down last night. I
My Sony Trinitron shut down last night. I unpluged it overnight but it will not power up. The standby light blinks 4 times, the unit clicks when I push the power button but does not come on.
    New Friend:
What is the likely problem if the Standby lights blink twice.
Thanks
Posted on Aug 02, 2010
  • 10,594 Answers
4 times standby light blink shows that tv got problem in vertical deflection section and probably vertical output IC got defective, need to be replaced.
Replacement of parts in circuit board requires soldering work and expertise so call local tv repair shop guy if you are not familiar with soldering work.
Thanks.
Posted on Jul 25, 2010
SOURCE:
Sony FD Trinitron WEGA..won't turn back on TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of an
Visit this site for details. All information about this type of fault [2 blinks of standby light to sony Trinitron]; are described here in detail.
"Electro-help", is the name of the site.
Search for it on Google.
May 02, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony Trinitron won't turn on, Standby/Timer light now blinks 2x
your power unit maybe going bad
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 21, 2009 | Televison & Video
Unit shutdown immediatly then standby light flashes 7 times
check secondary power supply. check eletrolytic capacitor nearby chopper and regulator
Jun 01, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
Tv won't power on, stand-by light blinks 6 times continously
just unplug tv 5 minutes. and plug it again. power on again. if not reset tv.
May 25, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony wega trinitron won't turn on
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • and some times the eprom ic is fulty ...
  • try to unplug your tv from the main power for 5 hours then press the power button and keep pressing for 7 seconds then release ,if this do not work ,you should take your tv to a qualified person
  • i hope this helps ..
  • Jan 01, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
    Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
    Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
    Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
    36 inch sony wega trinitron
    I had the same issue earlier this week. 4 year old sony trinitron wega 32 in. I was told by Sony to call technician to repair and have called tech....could be anywhere from $200-$300 repair. I did research the blinks (google "sony blinking codes" to find out what each means) Ours was 6-7 blinks which meant power surge to tv. I advised to Sony that i saw many of the same issues with many of the newer tv's and suggested a recall issue--they denied and where no help.
    I will buy a new tv now--definitly not a Sony.
    Dec 28, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
    Sony Trinitron KV-28WS3U Dies
    B+ over current protection (OCP), unit goes to the standby mode. Could be a short in the power supply of any of the circuits.
    Nov 05, 2006 | Sony FD Trinitron WEGA KV-32FS100 32" TV
    Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
    736 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Steve Allison
    Steve Allison
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
