Battery has a electrical draw on it
Are you familiar with removing battery cable from battery + and installing a 12 volt test light from cable end to battery post ? If the light is on bright, you have a good draw. Now start removing fuses you suspect may be causing the draw, and when light goes real dim, or out, you found the circuit with the draw. Keep in mind radio memory will cause small draw as well. Just keep track of where they came from.
