It seems like you might be hearing the motor running but the belt might be off the roller or broken. If it is like the dryers I have had, you can pull out the lint filter then push the two clips that hold the top down, and lift the top of the dryer, you can get a flashlight and look down into the dryer to see if the belt is OK. You can also lower the lid but not latch it then press start and open the lid to see if the motor is running, if you can see the pulley on the end of the shaft it should be spinning. The hardest part of fixing a belt problem is reaching back in the dryer to get to it. Best of luck.
